Question about Siemens Gigaset SL56 Phone
Voicemail full when someone tries to leave a message they get coicemail full. How can I empty it> Alan Minto
My voice box is full. How do I empty it?
On screen that shows a list of existing voicemails select edit. Then select the voicemails you would like to delete and then select delete
Sep 02, 2014 | Cell Phones
Why does my voicemail say its full and how do I fix it?
After listening to each message, you must delete ones you no longer want by hitting 7 on keypad/dialpad for each message you want to delete. Your voicemail box only holds so many messages. When it gets full, you must empty some out.
Aug 03, 2014 | Tracfone Wireless Alcatel A392G
A mailbox is full message is left when a caller tries to leave a message. The mailbox is empty. How do I reset my mailbox?
Call your number and enter your voicemail password, then make sure all the messages are deleted.
Jul 09, 2013 | iPhone Apps
Voicemail icon will not go away after i delete my voicemail how can i get that to go away?
This happens to me A LOT. It seems to help to delete voicemail messages when I have more than 3 signal bars. To get rid of the Icon you have to leave a voicemail on your phone, use someone elses phone and just leave a message, it should vibrate like it has a new voicemail but the count shouldn't go up, then just delete the message when you have close to full bars.
May 21, 2010 | HTC Touch Pro2 Smartphone
Voicemail icon won't go away.
I've had the same problem as well. I made sure no messages were there, then called and left myself a message from another phone. I went in and listened to the message and waited till the option to delete came on and for the indication there were no more messages. Icon was gone.
Aug 06, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Iphone can't receive calls
check in settings/phone to see if you have maybe turned on call forwarding and it is being forwarded automatic to your voicemail box number
Jul 17, 2008 | Apple iPhone Smartphone
Voicemail box
It has to be ereased for the phone only holds so many messages.
Jun 08, 2008 | Vtech ia5845 Twin Cordless Phone
Resetting company voicemail
Norstar Common Voicemail Features To Check Your Voicemail:
1. Press the Check Voicemail key or press the Feature button, then 981
2. Enter your password
3. From here you can listen to messages, change your greeting, change your password, etc.
To Leave a Message for Someone in Your Office:
1. Press the Leave Message key or Feature 980
2. Enter the mailbox number (extension number. of the person you want to leave a message for
3. The display will show the name of the mailbox owner, press OK
4. Leave message
To Access Your Voicemail box from Another Phone:
2. Press the OTHER softkey
3. At the LOG: prompt, enter your mailbox#(extension #. and your password all together followed by the "#" sign
4. Press the OK softkey
To Access Your Mailbox from Outside of the Office:
1. Call the main office number or your DID (if applicable.
2. If the call is answered by a receptionist, have them transfer you to your voicemail box
3. If the call is answered by the company greeting, or your personal greeting, Enter: * *
4. At the prompt, enter your mailbox #(extension #. and password all together
To Transfer Someone to a Voicemail Box:
1. Press the Transfer to Voicemail key or press the Feature button, then 986
2. Enter the mailbox # (extension#.
3. The display will show: Call Transferred
To Change Your Personal Greeting:
3. Press the ADMIN softkey
4. Press the GREET softkey
5. Press the REC softkey
6. Press the PRIME softkey
7. Press the YES softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording and then the OK softkey again to accept the new recording
To Record Your Alternate Greeting (Used when on vacation or out of the office.:
5. Pres the REC softkey
6. Press the ALT softkey
8. At the tone, record your new greeting, press the OK softkey to end your recording, then the OK softkey again to accept the new recording.
9. You then need to have your voicemail box now play the Alternate Greeting, Press the GREET softkey
10. Press the ChOOSE softkey
11. Press ALT softkey
12. Display will show: "Accept msgs: Y", Press the OK softkey to have your voicemail box accept messages while your Alternate Greeting is turned on, or press the CHNG softkey to change the "Y" to an "N" if you do not want your voicemail box to accept messages.
13. When you return to the office, make sure you go back into your voicemail box and have it play the PRIME greeting
took this from a guide i have, might help you guys out
Jan 07, 2008 | NorStar M7310 Corded Phone
Siemens Gigaset SL56 Phone Logo
41 people viewed this question
Top Siemens Lands Phones Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Siemens Lands Phone Expert? Answer questions, earn points and help others
