Question about Hasbro I-DOG AMP'D
Hasbro I-CAT won't turn off. I use to be able to hold down the nose for a few seconds and that would turn it off but that doesn't turn it off anymore. It meows until I give it attention. Could this mean it needs a new battery?
Yahtzee wild touchscreen doesn't work
if you turn on the light button and it just plays music it is in demo mode. Wait for the music and light to go off and hold down the roll button for three seconds. That should do the trick just hit the light button again pick number of players. if that doesn't work you may have weak batteries try the reset button or your game may just be defective.
Mar 07, 2013 | Hasbro Yahtzee Wild Hand Held Game
Htc evo 4g shift won't charge or turn on and I
Have you attempted taking the battery out and while the battery is out holding down the power button for a few seconds? If this doesn't work,
First test your charger to ensure proper charging. Clean charging ports. Remove battery and clean brass contacts with alcohol and q-tip
Jan 12, 2012 | Lands Phones
The home screen is frozen it doesn't even respond to me trying to turn it off.
Hold the power button for a few seconds. If it still won't turn off, remove the batteries.
Jul 30, 2011 | PANDIGITAL Novel 7
I have forgotten how to turn it off
Hold it's nose down for 3 seconds.
May 11, 2011 | Hasbro Oye Mio Pup
He never truly turns off. What can I do. We can't leave batteries in him.
Hold own his nose for 3 seconds and he will turn off.
Jan 05, 2011 | Hasbro Oye Mio Pup
My idog will not turn on. i just replaced the bat...
Try plugging in your iPod and playing music worked for me and/or put new batteries in it but do NOT press reset
May 20, 2010 | Hasbro I-DOG AMP'D
How do I stop motor motion of my I-Dog Amp'd while still playing music?
While your iDog AMP'D is in "Listening Mode", hold down it's tail, and press it's nose. Make sure that you keep holding it's tail down the entire time, even after you pressed it's nose. You should see a spinning light pattern, that signifys that the motor movements are off. To turn them back on, either turn off/on your iDop AMP'D, or do the same thing but hold it's tail upwards. If your iDog AMP'D growls instead, that means it was not in "Listening Mode", and simply wait for it to start showing light patterns to music, then try again.
Hope this helped!
Jul 22, 2009 | Hasbro I-DOG AMP'D
How do u make it stop moving when u play music?
Hope this helped!
Jul 02, 2009 | Hasbro I-DOG AMP'D
Motion Won't Turn Off
The trick to this is to catch the dog while just playing the music and not while dancing. What this means is that his foot must be down and not moving. Very often he will pause dancing with his foot up, however this is considered "mid-cycle" and he will ignore his stop command. When his foot is down waggle the tail towards his rear. This will produce all but one light turning red and a little beep to indicate him ready for a command. While holding the tail push the nose button for about a second, not long enough to turn him off but more than a quick tap. If his foot is down and music is playing he should respond.
Dec 31, 2008 | Hasbro I-DOG AMP'D
Idog wont do anything
Turn on underside near front legs. TAIL CONTROLS VOLUME FRONT TO BACK. Push nose and rub face. Connect to MP3 or Ipod switch the short cord end to end and sometimes that makes a difference.
Nov 28, 2008 | Hasbro I-DOG AMP'D
Hasbro I-DOG AMP'D Logo
576 people viewed this question
Top Hasbro Toys Experts
thegtw
Antony
Are you a Hasbro Toy Expert? Answer questions, earn points and help others
