Question about LG LMVM2075 1000 Watts Microwave Oven
LG LMVM2085. Extremely noisy. We have had multiple repair men out who have fixed different parts, replaced thing and nothing seems to work. Something rattles every time we use it.
  • 72 Answers
The case screws are more than likely stripped from all the attempted repairs and these units are already loud
Posted on Feb 05, 2010
My microwave with hot heat the food
Could be a lot of things... If it's quiet when you try to zap something, then suspect a blown fuse inside or a burnt wire or the relay board. If it's extremely noisy when you try to zap something, then suspect the Mag tube, HV diode, or HV capacitor. Also, the windings on your HV transformer could be burnt, but that's not as common as the above mentioned items.
Nov 16, 2014 | Microwave Ovens
Buzzing noise
follow this steps and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out t
urntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Oct 23, 2013 | Panasonic Microwave Ovens
Microwave makes sound like something moving inside
follow this steps and use the VOM , and fix it. God bless you
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Jun 18, 2013 | GE JVM1490 Convection/Microwave Oven
When I close the door and begin to try to heat something I immediately hear an abnormal low buzzing sound. If I let it run I smell what seems to be something burning. Obviously this does not sound safe...
There is no easy fix on a micro wave oven. It is an extremely dangerous appliance and any repair is best left in the hands of a qualified repairman.
Jan 30, 2011 | Microwave Ovens
Noisy Microwave
On the right side?
Usually there is a rubber pad on the high voltage transformer which prevents vibration due to the magnetic field of the transformer.
If that falls off, it can make the side vibrate.
Either way, since it's less than one year old, it would be fully covered under warranty. I'd suggest contacting the manufacturer to get it fixed free.
For more Goldstar / LG / L.G. help, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat 8-5 CT) and choose the appropriate prompt from the menu or visit here. You can get warranty info & find a local authorized servicer.
May 19, 2009 | Microwave Ovens
Oven will not work; has no power due to power serge from local utility. Is there a fuse inside the oven? GE repair men says bring in to shop;the manual says laymen should not atempt repair, but the cost of...
hi my name is mark, most microwaves have fuses in them. if you are comfortable taking things apart you can fix it. you will need hand tools, a meter to check the fuse. radio shack sells inexpenive ones. unplug the microwave when you disassemble oven. first make sure the circuit breaker to the oven is not tripped. hope this helps. thank for your question.
Mar 16, 2009 | GE JES1290SK 1.2 Cu. Ft. Countertop...
GE Microwave DEMO MODE
The owner's manual (which can be downloaded here) doesn't show any demo mode, but it may exist.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for maybe an hour. Then let us know if the hard reset does not fix it.
Oct 06, 2008 | GE JE1590 Convection / Microwave Oven
Turntable issues
As you say you are clueless about fixing anything, I suggest you take it to the service center and get it done. Replacing a electrical part has to be done properly, and fixing a turntable prob can be tricky.
Jan 06, 2008 | Frigidaire PLMV169DC Microwave Oven
Microwave oven is noisy during use
Sounds like you have a failing turntable motor. You can contact LG / Goldstar about parts or service at 800-222-6457.
Apr 07, 2007 | Goldstar MA-790W Microwave Oven
Microwave Dead after burning up potato
Chances are the magnetron overheated and blew the thermostat / thermal cutout that monitors it. The magnetron itself may be bad, too. If Sears Service might consider this still under magnetron warranty, then they may replace the mag with no part costs (or just the thermal cutout part cost), but likely would charge labor. You can contact customer service or repair via http://www.sears.com Otherwise, if you or a friend decide to work on it, we have *critical* safety and disassembly info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your base model number (without the suffix) here: http://www3.sears.com or likely cheaper here: http://tinyurl.com/gv383
Feb 06, 2007 | Kenmore 60659 Microwave Oven
LG LMVM2075 1000 Watts Microwave Oven Logo
112 people viewed this question
Top LG Microwave Ovens Experts
William Miller
William Miller
Greg Cann
Greg Cann
Devabhakthuni...
Devabhakthuni...
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
