Question about Brother P-Touch 1180 Label Printer
How do you make the font print larger on P-Touch Model PT-80?
MAKE MY HP OFFICEJET 5610 PRINTER PRINT LARGER
The only way a printer should print larger is that you should WRITE your text with larger fonts.
You should select font size on your word processing application, call it nopepad, wordpad, winword or any other similar application.
If you tell us the application and the version you are using for word processing, might help you select a larger fornt
May 02, 2015 | HP Office Equipment & Supplies
The font won't change. It always prints in the same font no matter what I pick...
Try to reset it. Read the full manual, which you can Google for it online, put in make, model and manual and you should get the .pdf file to save to your computer.
Mar 02, 2015 | Brother P-Touch PT-D200 Label Printer
Need to change font size larger when printing
Change the font on your document before printing
Jan 12, 2015 | Office Equipment & Supplies
How do you change font size of email printout?
Internet Browser Instructions
  • If you open your email account using a browser, there is a very simple way to increase the font. Font size options are located either under "Tools" ("Options" or "Preferences" then "Content") or "View" (text size) on your browser's main menu. Change the font to a larger size, which may be set by number or by selecting "Larger" or "Largest" font from the list of options. You may have to click "Advanced" or the similar option in the "Fonts" section of some browsers to adjust the font properly.
    Next, click "File" then "Print Preview" on your browser's main menu. This will show you how the email will look when printed. Click "Page Setup" and deselect the "Shrink to Fit Page" option. This will allow you to print the email at the new, larger font size. Be sure to return your browser's font size to normal when you are finished printing the email, or else all of your pages will display with a larger font.
Other Email Software
  • If you use a non-browser email software program to view your emails, insert your email contents into Microsoft Word (or a similar word processing program) to print it in large letters. Select the entire message from your email software then go to Word to paste the contents into a blank document. You can then select the text of the email and increase the size of the font. When you're done, print the file as you would normally. You can also perform this action with an email that you open inside of a browser.
Nov 29, 2010 | Canon Office Equipment & Supplies
I have a 105SL connected directly to a pc using Bar Tender. It takes for ever to print and when it does the printed label is 1/4 larger than what I specified. keep it simple, has I am not an IT expert.....
Ok...two items to check:
1. slow print can be caused by using True-Type fonts like Arial, Times New Roman, etc...these fonts do not reside in the firmware of the printer so Bartender has to download the fonts to the printer's memory hence the long print time. Change any text fonts to Zebra's internal fonts which you should be able see as a choice from Bartender.
2. If the print is larger than you expect, then you are using a printer driver that is not correct for the dpi (dots per inch) of the printer than have. If your printer is a 203dpi printer but you use a 300dpi printer driver, then your print will be larger that you expect. Bartender will format the fields for 300dpi but because size is larger on a 203dpi, the print will be larger. The Z105SL comes in both sizes, 203 or 300. Just verify your printer to the driver being used.
Hope that helps !
May 05, 2010 | Zebra Printer 140-751-00000
How do I change the font size on my p-touch 1750??
The shift and up keys together make larger type, while the shift and down keys together will make smaller type.
Oct 29, 2009 | Brother PT-1750 Thermal Label Printer
With a pt 65, how do I reduce the size of the print?
Cook,
With the unit powered up, press and hold the yellow Code button. While holding it down, press the & key and watch the pointer at the top of the screen. Note how it is moving to the various size As. That will increase and decrease your font size.
Mar 05, 2009 | Brother PT-65 Personal P-Touch Electronic...
How to print my web articles in larger font?
You can try print preview. This should show how it will look on paper. Also make sure it's not trying to fit the document on one page. (shrink to fit)
Dec 30, 2008 | HP TouchSmart IQ770 PC Desktop
ERROR appears and won't print
What size tape are you using in the machine?  Some of the fonts won't work if you are using 1/4" tape.  It will say ERROR if you're asking it to print a larger size. This won't be a problem for you if you switch to 1/2" tape, or just use the two smallest font sizes.
Hope that helps!
Nov 17, 2008 | Brother P-Touch 1180 Label Printer
Brother Hl-2040 laser printer
Fonts and sizes are typically controlled by the application you are using. Are you sure you are increasing the font size? I've had some users confused by the zoom feature which is more like a magnifying lens. It just makes thing larger for viewing purposes and does not affect the print size. To change the actual font size of a document already created you would first highlight the text in the document. In Word (other applications are similar) you would then select Format from the main menu bar, then select Font. In the next box that appears you would click on the Font tab, and then in the Size field select a larger font size. After that click on OK and you should see your font size change. Let us know if that was your problem or not.
Aug 02, 2007 | Brother HL-2040 Laser Printer
Brother P-Touch 1180 Label Printer Logo
1,471 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
