Question about Epson Stylus CX6000 All-In-One InkJet Printer
Epson scanner quit working
Epson CX6000 color printer quit scanning. I was going to scan in 5 single page documents. It quit after the third one.
Rebooted PC and Epson several times.
USB port is working fine according to my diagnostics:
lsusb in Linux.
Bus 005 Device 002: ID 04b8:082e Seiko Epson Corp. 0x082e DX-60x0 MFP scanner
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Before going to ebay, what should I try to do next ?
  • mondotofu Feb 05, 2010
    Solved it by uninstalling Xsane and re-installing it along with libsane-extras.
    Next time I started Xsane, I got two drivers to choose from. I chose the new one and it began working again!
    Guru:
  • 689 Answers
Goto your Linux configuration utilities and configure your printer again,sometimes after a crash the drivers are reset.
Utilities differ under different flavours look and see if you can do this
Posted on Sep 06, 2010
How to scan documents to computer EPSON stylus sx410/tx410 ?
Hi Susan,
Basic Scanning
You can scan original documents and photos and save them as files on your
computer using the Epson Scan software. You can also launch Epson Scan from
any TWAIN-compliant application, such as Adobe Photoshop
1. Open the document cover and place your original face-down on the scanner
glass, in the front right corner, as shown on page 9.
2. Close the cover gently so you don't move the original.
3. Do one of the following to start Epson Scan:
Windows:
Double-click the EPSON Scan icon on your desktop.
Macintosh:
Double-click EPSON Scan in the Applications folder.
If you are scanning from an application, start your application. Then
open the File menu, choose Import or Acquire, and select your Epson
product
Select Full Auto Mode as the Mode setting
in the upper right corner. (If you are in
Home, Office, or Professional Mode, you see
a different Epson Scan window.)
5. If you want to restore faded color in a photo
or make other corrections, click Customize.
Then follow the instructions in the next
section.
6. Click the Scan button. The image is scanned
and you see its icon in Windows Explorer or
Macintosh Finder.
May 01, 2014 | Epson Stylus CX6600 All-In-One InkJet...
I WANT TO USE THE SCANNER BUT, I DON'T NOW HOW, It go to the printer all the time, could you please help me ? I have the EPSOM STYLUS BX300F PROFESSIONAL, PRINTER,SCANNER,FAX,PHOTOCOPIER.
Basically, you can use the scanner in two ways. Please open the scanner cover and place the document or image you want to scan face down.
1. Press the SCAN button (color button = color scanning, black button = monochrome scanning). then your scanner will scan the document or image in the scanner tray.
2. Go to the scanner program installed in your computer when you installed the printer. Open it and then click the command button SCAN.
Note: Make sure that you installed the Scanner software when you installed the printer. Without the software, your scanner will not work. Please reinstall the printer including the scanner software.
Feb 06, 2010 | Epson Stylus Multifunction Inkjet Printer/...
The drop down menu does not give the option to have the picture scanned/saved jpg format which is necessary for certain sites such as shutterfly
Please follow the steps below to scan and save a Multi-Page PDF with Epson Scan.
1. Launch Epson Scan from your START, (ALL) PROGRAMS, EPSON SCAN.
2. If prompted, select your scanner model. Epson Scan will now launch.
3. Click the drop down arrow next to SCAN, select FILE SAVE SETTINGS.
4. Select PDF for IMAGE format. Click OK.
5. Click SCAN. Click OK to proceed (if prompted).
6. Once the image has scanned you will be prompted to click ADD PAGE or DONE.
7. Click ADD PAGE to scan more documents.
8. Once you have scanned all your documents, click DONE.
9. Your documents will now appear in the EDITING PAGE window. Click OK.
10. The multi-page PDF is now created.
Jan 16, 2010 | Epson Perfection 4490 Photo Scanner...
Insstructions for sending a Fax on a Brother
You can find the entire user manual by clicking here:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_MFC_240C_EN_249.PDF
Or, here are the instructions for sending a fax:
Entering Fax mode 5
To enter fax mode, press (Fax), and
the key will glow green.
The LCD will show the new job number and
the memory available.The number of pages
you can scan into the memory will vary
depending on the data that is printed on them.
Faxing from the ADF 5
a Make sure you are in Fax mode .
b Put the document face down in the ADF.
c Dial the fax number using the dial pad.
d Press Black Start or Color Start.
The machine starts scanning the
document.
Note
• To cancel, press Stop/Exit.
• If the memory is full, the fax will be sent in
real time.
Faxing from the scanner glass5
You can use the scanner glass to fax pages
of a book one at a time. The documents can
be up to letter or A4 size.
You cannot send multiple pages for color
faxes.
Load your document on the scanner
glass.
Dial the fax number.
If you press Black Start, the
machine starts scanning the first
page. Go to step e.
If you press Color Start, the
machine starts sending the
document.
Do one of the following:
To send a single page, press 2 to
choose No. (or press Black Start
again).
To send more than one page, press
1 to choose Yes and go to step f.
Put the next page on the scanner glass.
Press OK.
starts scanning the page.
Dec 15, 2009 | Brother MFC 240C All-In-One InkJet Printer
I have an Epson Office Bx300F - I have a CV of three pages and want to know how to scan the three pages into one scan file Can you advise ? As you imagine having to scan three times means I then have to...
I have a different all-in-one but the tool used for scanning may be similar. When installing the printer, the MF Toolbox utility was also installed. If I want to scan multiple pages into a single document, I have three options for "Save as type". One is "PDF", another is "PDF (Multiple pages)" the third is "PDF (Add page)". I use the second option for multiple pages. Once the first page is done, a dialog box will appear and prompt me to insert the next page in the scanner and continue.
See if the tools installed with your printer have something similar.
Sep 03, 2009 | Computers & Internet
Don't know how to set scanner for multiple page scan into single pdf file
The supplied Canon software is horrible, but it can be done!
Launch ScanGearStarter, choose advanced tab and click preferences button, then select scan tab.
Untick box "Automatically quit ScanGear....." then click ok.
(This box being ticked totally prevents multipage single file scanning).
Now choose simple mode tab, select the document type, dpi and document size.
Now click the green "Multi Scan" button, place the document on the scanner glas and press next in the new window.
The page will be scanned and the ScanGear window will return, just click "Multi Scan" again and place next document, press next. Keep repeating until all pages are scanned, then close the ScanGear window.
This will bring up a third window showing thumbnails of each page, any of these pages can be deselected if required.
The other important step is to choose from the pull down list Saved as Type: "MultiPagePDF".
Choose the location for saving the file and click save.
Hallelujah! .......stupid software.
Jun 01, 2009 | Canon PIXMA MP780 All-In-One InkJet...
I want to copy a document
How often do you need to "copy" documents. Do you have a document scanner?  Your Epson is a printer.  You'll need a scanner to scan a document into your PC then you can print it out on your Epson.  If you only need a copy once in a blue moon, and you don't have a scanner, save yourself a few bucks and just go to Kinko's or maybe even your local grocery store or library and run your copies there.  They probably cost about 25 cents a page.  A new scanner will run you about $100 bucks.  If you decide that you need a scanner, you might even want to consider investing in a multi function printer which will scan-print-copy-fax.  Hope this helps.  If so, please remember to rate my solution.  Thanks.
Mar 14, 2009 | Epson Stylus Color 600 InkJet Printer
How do I send a fax with cx6000?
I have a CX 6000 also, but i is NOT a fax machine. only copy/scan/print.
Mar 12, 2009 | Epson Stylus CX6000 All-In-One InkJet...
Scanning multiple copies
The trick is to put the scanner in PROFESSIONAL MODE !!!!! Select that option in the top right corner of the Epson Scan application when it first opens up.
http://files.support.epson.com/htmldocs/gt25__/gt25__ug/projs_1.htm
Dec 21, 2007 | Epson Stylus CX4200 All-In-One InkJet...
Epson Stylus  CX6000 All-In-One InkJet Printer Logo
388 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
