Question about Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch
Clicking noise-GSH22JFR/SH200106 my refrigerator is not even 2 years old and it has started making some kind of clicking noise, sounds like compressor does not start. i do not have any extended warranty. can anyone tell me if this kind of problem would be covered under manufacturer warranty, which is 5 years parts n labor. Mine behaves similarly. Compressor fails to start. Lights stay on but dispenser doesn't work. If paddle is pushed the lights dim and any noise of operation in the fridge stops. If I unplug the fridge and plug it back in the clicking will start and after 50 or 60 clicks the unit starts operating. If I wait a few more seconds the dispenser will work (if I hold the paddle in for several seconds). So repeatable that I bought a timer to power down the unit twice a day to prevent spoiling of food if we are not there to restart the fridge. I appreciate the service letter offered by flukmanji.
  • 552 Answers
If you have a 5 year warranty, you should not take anything apart and consult the place where you got the appliance.
They should be able to tell you exactly what is covered under warranty before they work on it.
Posted on Feb 20, 2008
My 7 year old Beko Fridge freezer is making kind of crackling sounds more and more frequently. The sound is coming from a flat square box about the size of a plug socket at the back of the appliance
Hello Marie;
My name is Peter. I am a retired field service refrigeration technician.
I need more information:
What is the full model number of you unit.
1.) Is your unit working?
2.) On top of your compressor is a condensate drain pan. This sometimes falls off and the condensate hits the hot compressor.
3.) If it is a clicking sound, it is your compressor overload relay starting the compressor.
Give me more information and I am sure I can help you.
Peter
Oct 28, 2014 | Refrigerators
Buzzing and clicking sound every few minutes
Compressor start relay - white plastic part - sitting right on the compressor, disconnect it shake it - u'll here it if it's damaged. :)
Oct 01, 2009 | Jenn-Air JCD2389G Side by Side...
REFRIGERATOR IS MAKING A BUZZING SOUND, not cooling
You have one of two problems going on. Your fan is spinning at hitting the sides. Or your compressor is shot which seems to be more the problem and even though it is cold the humming sound is a warning for you that the compressor is shot and it is more affordable to replace the fridge then the compressor. Sometimes compressor can cost more then the fridge.
May 28, 2009 | Maytag 22 cu. ft. Bottom Freezer...
Freezer not working , clicking noise coming from fridge
Clicking was a relay. Replaced relatively inexpensive relay and now working fine.
Jan 17, 2009 | Jenn-Air JCD2389G Side by Side...
Refrigerator noisy after compressor replacement.
There may be too much refrigerant in the system. If he did not use a vacuum pump before adding freon, then air is in the system but does not cause a gurgling sound, it just won't cool properly.
Apr 16, 2017 | Refrigerators
Kenmore Refrigerator making loud noise
Does the sound occur when the compressor is starting or shutting down? and only lasts for a couple of seconds? I had one do the exact same thing. Sometimes it would also wake me up at night. If so, I'm afraid he is right. On the bright side, it worked fine for years. I gave it to a girlfriend when I purchased a bigger one and it is still working today. The only thing you can do is change the compressor, which is probably not $$ practical.
Nov 05, 2007 | Samsung RS2556 Side by Side Refrigerator
Fluk, based on my experience with these refrigerators, I'd bet you the Mother Board has failed. That's where the clicking is coming from. To verify this, pull the refrigerator out away from the wall then remove the aluminum panel back there (there are 4 screws holding it in place). This will expose the mother board. You won't have to use any more tools to diagnose it... you'll hear the clicking sound coming from this board.
Your 5 yr. warranty information only applies to the sealed system components; compressor, condenser, evaporator and freon. The board isn't covered, I'm sorry to say. You can try calling GE at 1-800-GE-CARES (1-800-432-2737) and explain to them that your board has failed, but I doubt you'd get very far. (They will probably try to talk you into having a GE repair company come out and do the repair, though. <-- at a cost of about $275.00.)
You can repair this for the cost of the part... about $120.00. The part number you'll need is WR55X10552 and can be obtained from your local appliance parts store (like Sears) or purchased online. There is an instruction sheet that comes with the replacement part... read it carefully. This is a very easy repair, it can be done in about 20 minutes. Remember... If you repair it yourself, UNPLUG YOUR FRIDGE BEFORE YOU BEGIN!!!
*TIP---> After you have the repair completed, plug your fridge into a quality surge protector, like this one or something similar.
Oct 14, 2007 | GE GSH22JFR Side by Side Refrigerator
Kenmore not freezing nor cooling. humming noise
DONT SAY THAT COMPRESSORS BAD YET !!!! TECHCUMSE AND COPELAND ALL HAVE THE SAME COMPONENTS FOR STARTING THE COMPRESSOR. ALL COMPRESSORS HAVE EITHER A "PIN-TYPE PLUG-IN START RELAY, OR CAPACITOR START ASSIST RELAY" TO GET THE COMPESSOR TURNING.( FROST-FREE REFRIGERATORS ALMOST ALWAYS HAVE A START-CAPACITOR, RELAY, AND T-STAT COMBO ON ALL MAKES. THE IN LINE BI-METAL TYPE T-STAT THAT PREVENTS THE COMPRESSOR FRON OVER HEATING... THEY CAN GO WEAK. THIS IS THE "CLICKING SOUND YOU ARE HEARING !!! CALL A REPUTABLE DEALER THAT IS "FACTORY CERTIFIED" FOR YOUR MAKE AND MODEL AND GET A "FLAT-RATE" DIAGNOSTIC CHECK PERFORMED. NEVER LET A REPAIRMAN TAKE DEFECTIVE PARTS OUT OF YOUR HOUSE FOR ANY REASON. BY LAW THEY HAVE TO LET YOU KEEP THEM UNLESS THEY ARE REPLACING THEM COVERED UNDER WARRANTY FOR EXCHANGE. UNFORTUNATELY HUNDREDS OF CONSUMERS ARE "BILKED" BY THE " DOI-IT-ALL REPAIR-MAN. MOST MANUFACTURES ONLY HAVE 1 YEAR ON COMPRESSORS FOR REFRIGERATORS 5-10 YEARS ON A/C COMP. DONT BE AFFRAID TO WATCH AND ASK QUESTIONS TO REPAIRMEN YOU LET "INTO YOUR HOME".
Apr 27, 2007 | Kenmore 52632 / 52634 / 52639 Side by Side...
Hotpoint HSS25GFT 25.0 Cu. Ft. Side-by-Side Refrigerator with GE SmartWater Filtration, LightTouch Logo
354 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
