Question about Vacuums
Blows out dust - Vacuums
  • 52 Answers
Could be that when you replaced the bag, that it wasn't sealed properly around the intake tube. Try pushing the bag all the way into the neck of the intake tube. If not that, then you may have a broken external intake tube.
Posted on Feb 05, 2010
My new Hoover Wet & Dry Vacuum Cleaner-1800w sucks dust from the carpet but it also blow abt 50% of the dust out into the room. Everything is covered in a layer of white dust. The hose is fitted 100%
It seems it must be blowing out from somewhere. Try to figure out where by feeling for air blowing to try to determine where it's coming from and why.
Mar 16, 2018 | Hoover Vacuums
Kobalt 10 saw blows dust everywhere ,even with a 2 shop vac connected to the dust chute .
It is possible that the dust chute on the Kobalt saw is plugged, not allowing the vacuum to pick up the dust. Run a rod through the dust tube and see if that clears it.
Jun 19, 2015 | Shop Vac Vacuums
Eureka vacuum blowing dust into the air
Check the leak (where the dust come from); maybe you need to tighten or reseat one or more part in that area.
Feb 09, 2014 | Eureka AirSpeed One Turbo Bagless Upright...
Dust will blow out of the front vent of my Dirt Devil Featherlite Bagless Vacuum. It seems to be shooting out dust that I just vacuum up, but I can't be certain.
Dust blows out of the filter vent is usually caused by a plugged filter drop the filter door on the back, replace or for a temporary fix blow out the filter
Jan 17, 2011 | Dirt Devil Featherlite Bagless Vacuum...
It is blowing dust out of the motor
If this is a bagless machine, then the problem is that the really fine dust that you are picking up from your floor is so small that it is going through the filter and dust cup and building up in your vacuum motor. When enough build up collects, then it starts to blow it out the exhaust. I would bet a paper bagged machine for the long run. They are cleaner,
Nov 28, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Hepa filter stopped on Hoover Windtunnel 2 Model #U8361-900
This has a simple solution IF you have a air compressor with a high pressure nozzle. Outside the house, first remove the Dust bin completely and lay the unit down with the dust bin area up. now start blowing the nozzle at the hepa filter, Alot of dust will come out. Now start to rotate the filter while blowing the dust out. The filter will move one way easier, When there is no more dust reinstall the dustbin and check the suction and the rotation of the filter.
Tony
Nov 17, 2009 | Vacuums
Dust blowing right back into the air
You need to check the filter and make sure it's on all the way. To do this take the top off the vac, make sure the filter is all the way up and in place. There should be a plastic nut to hold it in place. If you are using it for fine dust particles such as drywall dust, you need a special filter for small particles. The filter that comes with the vac just won't do it!
Mar 23, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Blows dust
i had this trouble and it turned out someone in my household had tossed out the filter with the rest of the dirt. you may have lost yours along the way since it's relatively easy to throw out.
Mar 01, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Blowing out dust
The reason most vacuums blow dust is because there is little or no suction in the foot of the vac. on this model, check to make sure that the hose is installed in the recepticle on the back to draw vacuum from the floor. verify the filter is clean, and there is no obstruction in the bottom foot.
Jan 18, 2009 | Hoover U5507900 Elite Rewind Bagless...
Dust blowing out of my vaccuum cleaner
Usually when dust is blowing out it is caused by a clog, either the hose, or the dirt inlet down by the brush roll is clogged. Check them and clean them out and you should be ok.
May 30, 2007 | Bissell 3522 PowerForce Bagged Upright...
Vacuums Logo
48 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
