Back to:
Tags:
Garmin Rino 530 GPS Receiver
530 hcx
posted by mobile 1 on Feb 20, 2008
Down loading map sets, i have two saved but when i download only one is available on the unit itself. I need them both what do i do?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Apr 21, 2008
Not Rated (0)
TOLady
Rank:Guru Guru
Rating: 87%, 60 votes
You need to select all the segments at the same time and then transfer to the GPSr. Do not send one set, then another as the second set will overwrite the first set.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on 530 hcx:
I don't want to Accept this solution
Can you Help with these GPS Devices problems?
my new 530 hxc will not pic up any sat.
I have a garmin 530 chx and it has worked fine for a...
my garmin rino 530hcx says "radio...
When I did install the cd included with my new rino 530, I...
I replaced batteries and now will not turn on. I've tried...
Loading problems.
Repair Service
Find GPS Device Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
