Question about HP Compaq Presario 2500 HP Pavilion ZE 5000 NX9010 Series (chassis bottom)319470-001 (319470001) CD-ROM Drive
HP Compaq NX9010
When booting my NX9010 I didn't realize my smart drive was in the computer. It tried to boot from it. It changed something and now it takes forever to boot and the keyboard does not work right.
In the boot screen it says HP Eeprom has been reconfigured. Help!
Yes the problem is solved. I unplugged the computer and removed the battery for a couple minutes. Then replugged in everything and it is working fine. Go figure.
Posted on Feb 22, 2008
Proliant does not boot from raid controller if external SCSI drive is powered on.
Try to disable boot to other device on your bios setting.
Make sure that your Smart Raid is set on the first boot device.
Nov 01, 2011 | HP Compaq ProLiant ML350 G3 Server
When start my laptop, get an error msg. "Grab loading 1.5, please wait.. grab loading error 17. and i can not boot from cd / dvd too..in HP nx9010. Plz help me.
This grub loading error 17 means that the file system type could not be recognised you should be able to boot from a cd make sure the cd or dvd drive is enabled as the first boot device in bios
I hope this helps
Andrew A
Apr 01, 2011 | HP Compaq Business Notebook NX9010
How to boot hp nx9010 from usb to install windows xp because it's cd drive is not working
1. The PC has to support booting from a USB flash/pen/key drive. There may be anywhere from 1-3 items to change in the BIOS to make this possible assuming your BIOS supports it. Some bios's may refer to your flash drive as a USB floppy or USB zip. Of course there are exceptions, perhaps some are covered here.
2. The USB flash drive must support booting from it in general.
3. The flash drive must contain the boot/system files.
4. The flash drive must have bootsector area. This is done with special utilities.
5. References to "A:" drive lines in the autoexec.bat and/or config.sys files you copy to the drive after you make it bootable may result in errors.
6. You "may" have to format your floppy disk first in WinXP before you create a bootdisk as XP may "not" like working later on with a disk formatted otherwise.
7. Included below is a bootable ISO of DOS 7.1 which may be used with some of these methods if you do not have a 1.44 drive.
Nov 17, 2010 | HP Compaq nx9010
I forgot my login password for my Compaq nx9010, is there anyway for me to be able to log in?
During the boot up process you will see on the screen press delete to enter set up
Press either delete or f2 during the boot up process to enter BIOS scroll down to set user password you can change or remove your password from there
hope this helps
Oct 03, 2010 | HP Compaq Presario 2500 HP Pavilion ZE...
My laptop is passing BIOS, then i get the possibility to choose my start up choise. no mather wath i choose, the sreen goes black, and a cursor appears. It does nothing anymore, even a live ubuntu cd...
Remember, there are many things you can do which will make your Windows installation as well as your laptop unstable, or even make it so it will not boot. Try to get into your bios. Different computers have different ways to get there - some have it on the screen, such as "hit delete key toenter bios" or "hit f12 to enter bios" or some other key combination. I think you enter the bios on your computer by pressing F10 repeatedly while booting. You should get to the setup screen. See if your hard drive is listed. You should see a hard drive as well as a dvd drive. If your drive is not listed, either someone has changed your setup so it is not the boot drive, or your drive may have gone bad. While you are in the setup, if it is not already the first choice, make your dvd (or cd) drive the first boot device. If it shows up, make the hard drive the second choice. Then when you boot, the Ubuntu should load. Try not to make any other changes, as you can make your laptop unuseable.
Aug 22, 2010 | HP Compaq nx9010
Problem with compaq presario 2500
hi
go to the Bios setup and set the first booting device as CD drive and it will check the CD first
cheers
pls rate if it was any help
Jul 05, 2009 | HP Compaq Presario 2500 HP Pavilion ZE...
Not booting into windows
while booting press del or F2 to enter BIOS ..then in boot priority change first boot device to hard disk...
Dec 05, 2008 | HP Compaq Business Notebook NX9010
Laptop HP NX9010 will not boot, Will go to bios, powers off after that.
u must have to detect your hard disk.
check u detect your hdisk in bios settings.
then also try to boot option and select hdd .
Oct 15, 2008 | HP Compaq Business Notebook NX9010
Tried to upgrade my hp from windows 98 to xp now it wont come on. It beeps then the monitor goes to sleep.Can not even run my redtore disc.
At start up of computer start tapping the f-2 key until you open the bios.In the bios change your drive order so that the computer boots first to CD-rom.
Mar 18, 2008 | HP Compaq Presario 2500 HP Pavilion ZE...
Computers & Internet Logo
133 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
