Question about Maystar Car Audio & Video
Maystar RS010 Parking Sensor
Hi, Got a Maystar RS010 Parking Sensor(4) fitted to my ca and it sometimes does the continuous beep when there is nothing behind the car Want to get a replacement unit but cant find anything on the internet about this product. Any Ideas?
2 Suggested Answers
alicantecoli
  • 22326 Answers
SOURCE: The rear parking sensor has
change the sensor ,its playing up
Posted on Sep 11, 2010
Where to find fuse for relation of the reverse parking sensors in kia sedona ls 07plate
kia sportage parking sensor - ABMforum.com
abmforum.com/kia-sportage-parking-sensor.html
kia sportage parking sensor installing rear parking sensors fitting rear parking sensor strip ... the pre-drill hole on 07 sportage 2007 kia sportage lx navigation wiringparking sensors. ... I cannot see any fuse which may relate to them. ... with their rear parking sensors Even if all is clear behind I now get a continuous beep and ...
Urgent help needed - towbar electrics - Kia Forum
www.kia-forums.com/kia.../71610-urgent-help-needed-towbar-electrics....
Aug 28, 2011 - 10 posts - ‎3 authors
I'm in the middle of fitting a genuine Kia towbar (made by Witter) to my SW. ... Need help again - Does anyone know the location of the PDC Control unit (parking sensors)? ... Drives: Kia Ceed SW 1.6 MT LX A8 ... with the loom which connects to the fuse box does not seem to attach to the rear lighting loom.
[PDF]2007 Sedona Owner's Manual - Kia Canada
Jan 30, 2016 | Kia Cars & Trucks
How do I eliminate constant beeping from parking sensor while driving?
What do you mean "parking sensor"?
Do you mean the parking brake is on, or is the seat belt not being used?
You should be able to tell where the sound is coming from.
Jul 29, 2015 | Cars & Trucks
Service park assist system
where is the parking assist sensor??
Jan 21, 2013 | 2006 Jeep Grand Cherokee
How to install maystar s20/50
Maystar s20-50 connections.
Red + to permanent supply via 15A fuse
Black - vehicle body earth wire
Pink - negative trigger input, connect to additional earthing (pin) switches for bonnet boot etc.
Violet - for connection to negative switched courtesy light door switchs
Blue - ACC wire connect to an ignition switch positive supply
Yellow- connect one yellow wire to the left indicator and the other to the right inicator. Ensure that you connect to the switch output to the bulbs, not the supply to the switch.
White - Current sense loop- cut for current sense leave intact for non current sense.
Green - Antenna wire must not be cut or terminated.
Quick connect, for connection to additional Maystar control modules and sensor systems, follow the instructions supplied with the additional sensor.
Jan 16, 2013 | Cars & Trucks
I installed the parking sensors yeaterday and now they continue to beep after I put them in reverse. I did the test where you turn on the ignition but not start the car and then put the lever in reverse....
hello i would like to help but can you give me information on the sensor kit you installed. some systems to beep and some only beep when the sensors detect something. also if they work fine with out the engine running but then don't work properly when the engine is run this could be there is to muck voltage for the sensors, some sensor kits are saying they are 12v, this is correct 12 volts, but the charging system on most vehicles are 14 volts, so you may have to fit a regulator to the feed wires to the sensor. you would need a 12 volt regulator board. this will stop any power going over the 12 volts to the device.
Jun 30, 2017 | 2005 Nissan Pathfinder
My 2007 Yukon has a problem with the park assist sensors. When I go in reverse sometimes, the warning beep repeats quickly and the lights flash like crazy but nothing is behind the vehicle. Sometimes the...
Check the system for DTC'S - diagnostic trouble codes should be the first step in the diagnostic process . Then reading factory service repair manual how the system works , viewing wiring diagrams .
Object Detection Description and Operation
Ultrasonic Rear Park Assist Operation
The ultrasonic rear park assist system senses how close the vehicle is to an object. The distance is determined by the 4 object sensors located in the rear bumper. The object detection system will notify the driver when backing up at speeds less than 8 km/h (5 mph). The object detection system will use the rear parking assist (RPA) display and the radio speakers for notification.
When the ignition is ON and the vehicle is placed into reverse, the object detection system performs a bulb check. During the bulb check, the 3 indicators on the RPA will illuminate for approximately 2 seconds to indicate that the system is working. The object detection system performs a bulb check and operates when the following conditions are present:
• The ignition is ON.
• The vehicle is placed in REVERSE (R) for rear parking aid.
• The vehicle speed is less than 8 km/h (5 mph). At speeds greater than 8 km/h (5 mph), the object detection system is disabled. The red indicator flashes to warn the driver that the object detection system is disabled.
The object detection system senses how close the vehicle is to an object. The distance is determined by the 4 object sensors located on the rear bumper. When the system detects an object, one of the following will occur:
• If the object is less than 0.3 m (11 in) away from the vehicle, the amber outside, amber middle, and the red outside indicators flash and the chime sounds continuously for 3 seconds.
• If the object is less than 0.3-0.5 m (11-20 in) away from the vehicle, the amber outside, amber middle, and the red outside indicators are ON.
• If the object is 0.5-1.0 m (20-40 in) away from the vehicle, the amber outside, and the amber middle indicators are ON.
• If the object is 1-2.3 m (40-91 in) away from the vehicle, the amber outside indicator is ON with a single chime when the object is first detected.
Object detection system can detect objects 7.6 cm (3 in) wide and at least 25.4 cm (10 in) tall. It cannot detect objects above the level of the roof.
If the object detection system detects a malfunction, a diagnostic trouble code (DTC) will be stored and the object detection system will send a serial data communication message to the instrument panel (I/P) to SERVICE PARK ASSIST message on the driver information center (DIC). Then the chime will sound and the red indicator on the information telltale center will be lit continuously. The red LED in the rear display will be lit, notifying the driver that a malfunction exists. Message will clear once the driver acknowledges it.
Each object sensor is a three wire sensor that is both a transmitter and a receiver that comprises a signal circuit, a low reference circuit, and an 8-volt supply voltage circuit. The rear object control module supplies 8 volts to the object sensors via the object sensor supply voltage circuit and provides ground via the low reference circuit. The rear object control module triggers the sensors in a sequential loop and after each sensor transmits, the rear object control module uses the echo or signal return to calculate the distance and position of an object from the rear bumper. The rear object control module directly controls the RPA display.
Do you know what DTC'S are ?
DTC B0958 01: Parking Aid Rear Sensor 1 Left Corner Circuit Short to Battery
DTC B0958 06: Parking Aid Rear Sensor 1 Left Corner Circuit Short to Ground or Open
DTC B0958 08: Parking Aid Rear Sensor 1 Left Corner Circuit Signal Invalid
DTC B0958 21: Parking Aid Rear Sensor 1 Left Corner Circuit Incorrect Period
DTC B0959 01: Parking Aid Rear Sensor 1 Left Middle Circuit Short to Battery
DTC B0959 06: Parking Aid Rear Sensor 1 Left Middle Circuit Short to Ground or Open
DTC B0959 08: Parking Aid Rear Sensor 1 Left Middle Circuit Signal Invalid
DTC B0959 21: Parking Aid Rear Sensor 1 Left Middle Circuit Incorrect Period
DTC B0967 02: Parking Aid Switch Circuit Short to Ground
DTC B0968 00: Parking Aid Indicator Circuit
Your best bet , take it to a qualified repair shop.
Feb 04, 2018 | GMC Yukon Cars & Trucks
Renault laguna 2004 put the car in reverse and the parking sensor beeps once but doesnt work
have someone walk behind you when in reverse gear, it bleeps once to tell you its working then only beeps when close to an obstacle.
Mar 19, 2010 | 2006 Renault Le Car
Parking Brake
there is a sensor in the brake fluid resovoir. if the fluid gets low, the brake light comes on. i'd say its borderline low and when you go up a hill it goes below the sensor level. add a little brake fluid to the resovoir and see if that helps
Oct 03, 2009 | 2006 Volkswagen Jetta
Maystar mcd303rds
I have just had the same problem. I have a N reg vectra and just fitted a Maystar radio. I too was getting the PHONE IN message randomly when the ignition was on (fine when not).
I think the PHONE IN is a mute function to cut sound when a call comes in. On my connections it was the brown wire - it should tell you the "Phone in" connection in the manual or on the bottom of the radio. I disconnected this and taped up with insulation tape to avoid connecting with anything else. Worked for me!
Nov 25, 2007 | Car Audio & Video
Car Audio & Video Logo
Top Maystar Car Audio & Video Experts
xxxxxx xxx
Are you a Maystar Car Audio and Video Expert? Answer questions, earn points and help others
