Question about Norelco Advantage 6705 X Electric Shaver
Norelco 6735x trimmer head
Mistakenly i have opened it, where caan i get a manul to essemble the same?
Just pop up the top with the cutters. Next pull the cutters from the shaver in the back prongs. Insert the trimmer head and reverse operation when you are fiished. adrianjpater@usa.net
Posted on Mar 27, 2009
BATTERIES FOR NORELCO 6735X
You will find batteries fro model 6735X on shaveroutlet.com at the link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
Oct 02, 2014 | Norelco Health & Beauty
Find battery for
battery for model 6735X can be found at shaveroutlet.com using the link below
Jun 25, 2014 | Norelco Advantage 6735 X Electric Shaver
Can I replace the trimmer blades (not the shaver heads) on my Philips 8175XL? I use them all the time and they are wearing out. Where do I get them and how do I install them?
You will find a replacement trimmer at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-8100-series-sideburn-trimmer-p-388.html
See disassembly video tutorial at shaveroutlet.com using the link below. You will not have to disassemble as far as the video shows. Just remove the back cover and the trimmer can be 'disjointed' from the cover
http://www.shaveroutlet.com/philips_norelco_shaver_disassembly
Oct 27, 2010 | Philips Norelco 8175XL Electric Shaver
I TOOK THE HEAD APART FOR MY NORELCO T765 TRIMMER.
Go to the URL listed below for a complete owners manual including 20 diagrams. For more assistance with this trimmer, call toll free: 1-800-243-3050
http://download.p4c.philips.com/files/t/t765_60/t765_60_dfu_aen.pdf
Jun 02, 2010 | Health & Beauty
Norelco 6735X shaver:batteries replacing. I removed the 5 screws but the back case remained not removable. How to get to the mounted batteries? Thanks, Guido
If you have removed the 5 screws the back cover will come off. There are seals that make it fit pretty snug. You will need to gently pry the back cover off.
You will find batteries for this model at shaveroutlet.com. See link below
Apr 12, 2010 | Norelco Advantage 6735 X Electric Shaver
How to open case on Norelco T-3000 beard trimmer
Remove the bottom screw. Next, the on/off slide switch has to be lifted off carefully with a small flat screw driver. Its kept in place with a small spring steel clamp. After you've removed it lift off the steel clamp and remove the slide mechanism by carefully twisting it out of position. Once that's done it will twist open easily.
Jul 25, 2009 | Norelco Health & Beauty
How do I change the Battery in My Norelco T3000 Beard Trimer
Remove Phillips head screw at bottom of trimmer. Separate body in two being careful to notice how on/off switch is assembled. Unsolder the ni-cad battery from circuit board. Install new ni-cad battery of the same physical size that has solder tabs on it and solder it to the circuit board. I used a ni-hi (nickle metel hydride) instead of ni-cad which had different charging requirements so I limit charge time to no more than 16 hours for a discharged battery. It had been working fine for over a year. Don't forget to apply a few drops of light oil to the cutting blades to extend cutting life. Replacement blades are about $30.00
Jul 06, 2009 | Norelco T770 Beard Trimmer
Norelco Advantage 6705 X Electric Shaver Logo
171 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Bruce Foote
Level 1 Expert
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
