Question about Jabra BT500 Wireless Headset
Bluetooth help i bought a jabra bluetooth and haven't used it in awhile it says it has a code i don't think i ever got a code
  • Anonymous Mar 19, 2008
    need a code to install in a motorola phone
  • 689 Answers
When you pair the bluetooth headset default passkey (PIN) should be used as "0000" (4 zeros). for further info you can check the user manual as I attached the link below
http://www.jabra.com/sites/Jabra/GNimages/Products/WirelessHeadset/BT500/Documents/UM/BT500_UM_NA_EN_480.pdf
Good Luck
Posted on Feb 20, 2008
I have tried to use 0000 to connect to my moto v710 with the bt500 and it's telling me invalid...
Posted on Mar 21, 2008
Manual for jabra t820
To pair the Jabra with a Verizon Wireless phone, the phone must have Bluetooth. Bluetooth allows a device to communicate and transfer data with another Bluetooth device without having to be physically connected to it. The instructions for connecting the Jabra with the Verizon phone vary slightly depending upon your phone model. Jabra headset instructions don't vary per model.
Jun 19, 2012 | Radio Communications
I just bought a new phone and want to use my old bluetooth,Do I unpair it from my old phone So I can pair it with my new phone?
You don't need to unpair it. Turn off the headset. Hold the power/call button to make it discoverable. Add it from your new phone. It usually uses pin 0000 or 1234.
Jun 13, 2011 | Jabra VBT185Z Bluetooth Headset
Can i pair jabra bt125 with samsung blackjack ??
Mine is a Blackjack II, but i did get it to connect. Hold the clear button down on the Jabra until it lights solid blue, keep holding it with one hand while you use the other hand to operate your Blackjack. I went to Settings, then Connections, then Bluetooth, then "Add new device". As long as my Jabra was lit solid blue, the phone found the headset. Then it will ask you for the pin code, which i found by accident (0000 - four zero's).
Jul 11, 2009 | Jabra BT125 Headset
Jabra vbt2050 won't connect
Jabra VBT2050 - You have to hold the round button in until the light stays lit (about 20 seconds) this will put it in discoverable mode, the pin is 0000, I have AT@T service and it works just fine. Hope this helps out!
Dec 21, 2008 | Radio Communications
Bluetooth wont sync with my bluetooth enabled phone
This is not actually a solution, but when I had the same problem with my Jabra (which I think is one of the best), I took it to my phone store and they synched it for me. Lots of navigating around and knowledge of a code to input. Screw it, let them do it!
Dec 20, 2008 | Jabra BT350 Bluetooth Headset Headset
Bluetooth connection problems
I cannot say I have the answer to this, but I am using a Jabra JX10 and it is working well. I previously had a Nokia 6256i, which I loved, but wouldn't work with the bluetooth at all. If you have not tried a Jabra, I would recommend it. Also, if you haven;t tried for a replacement phone, consider the possibility it might be the phone itself.
Oct 18, 2008 | Palm Treo 500 Centro
Jabra BT135
Firs turn it off then..........
then hold the button for 10 seconds
it will now pair with your phone
the code is "0000"
Apr 25, 2008 | Jabra Bluetooth Headset with Adjustable...
BT350
try turning bluetooth off . first erase bluetooth connections on phone. turn off phone and take out phone's battery for ten seconds. put battery back in and turn on phone. plug bluetooth into charger for ten seconds and unplug it. try re-pairing bluetooth with phone. This worked for me!
Mar 06, 2008 | Jabra BT350 Wireless Headset
Jabra BT500 Wireless Headset Logo
320 people viewed this question
Top Jabra Radio Communications Experts
Greg Cann
Greg Cann
Michael Vincent Cruz
Jerry Greenberg
Jerry Greenberg
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
