Question about Proscan PS27600 27" TV
Picture is closed in and only a vertical line is visable, sound is fine.
    Genius:
  • Proscan Master
  • 1,550 Answers
Vertical IC damaged need to be replaced
Posted on Feb 04, 2010
  • Proscan Master
  • 8,457 Answers
Ur Vertical/Hoizontal IC is cold solders,or it dead.Know how to solders? Make a fist bang on the back cover see if picture flicker back to normal,then it just requiring resolders the IC by tapping around with a back handle of a screw driver PCB on the tv find out where to resolders.If dosen't fliker back IC require replacing,but CRT tv part are hard to find these day,take to the shop they have better connections to buy CRT tv parts.
Tv picture is broken into vertical lines
The TV may have blown out. Time for a new one are you can reset you TV. Hope This Helped
Nov 24, 2013 | Philips Magnavox TS3260C 32" TV
Hi I have a Philips 36PW9525/05 CRT TV. The sound is fine but the top half of the screen is not visable the bottom half seems fine. Can you advise on a fix??
hello sir i already encounter that problem..first remove the cover of your unit then you go to the vertical section of CRT driver when you see the I C that stand vertically it means that section is vertical then if found that section you have to do now is look for leak/bulged top capacitor near the vertical I C then replace with the same value/rate thank you sir
Mar 05, 2011 | Televison & Video
Thin horizontal line of picture
that is a vertical deflection circuit problem. try to check a 470 UF capacitor connected to the vert. yoke coil if it is open or try resoldering the nconnecrtion at the board. if not, try to replace the B+ filter of the vertical amplifier. another is try to chexk if the vertical moscillator is qworking if you know elecrtonics.
Jan 27, 2010 | iLO V27DMBX Television
I have a Sony 26 inch Bravia LCD tv model KDL-V26XBR1.It has thin vertical black and yellow lines about an inch apart across the whole display. Not noticeable from a distance but really see them up...
Well if the panel is bad it would not clear up in any situation, so its not the panel. most likely the t-con board or just poor connections inside. Julio Millenium TV in Las Vegas.
Dec 18, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Good sound no picture just line thru middle of screen
If the line is going across the screen from side to side that means you have lost vertical deflection, and you don't want to run the set like that because you can burn that line into the picture tube. Most likely would be the vertical output ic, probably with a 400 location number, example IC401, could also be a capacitor in the vertical circuit most are close to that IC.
Aug 28, 2009 | Mitsubishi Televison & Video
Polaroid ttm-2401
To me, sounds like a picture tube issue. horizontal / vertical controls don't fix it. then its dead.
Jun 22, 2008 | Polaroid TTM-2401 TV
42" LG Plasma with 4" vertical lines at each end
LG service is non- existent . The only solution that I can suggest is "Give a wide berh to LG products. Dont ever touch any"
Mar 07, 2008 | LG 42PX5D 42 in. Plasma HDTV
Showing black screen with a blue line
Is the blue line running straight across the middle of your screen? If so its a vertical deflection problem. Possible bad Vertical output IC
Feb 20, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Mitsubishis TV Problem
have a Mitsubishi TV 1993. Model CS-35301. The problem is that there is a white line that is running through a blank screen. The sound is fine just no picture. Have you heard of "Vertical Collapse?" I would love to save the TV. Hi nothing to worry just minimise brightness to avoid screen burn. "Vertical Collapse?" means one bright hor.line in the middle of screen. this problem can be solved 1 check vertical yoke connector or wire loose 2 check supply to vertical section which normally comes from EHT transformer check components in vertical section or print loose regards thanks
Sep 10, 2007 | Televison & Video
Proscan PS27600 27" TV Logo
91 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
