Question about Ricoh Aficio 1018D Copier
We have an Aficio 1018 and the copies background is dark and sometimes striped. Problem?
  • 170 Answers
TRY TO CHECK & CLEAN THE CHARGING ASSEMBLY THEN AFTER THAT CHECK THE DRUM CLEANING BLADE
Posted on Feb 05, 2010
What is causing dark background in my copies
1. drum life is due
2. developer due
3. cleaning blade bad
4.primery charger roller faulty.
5.transfer belt claening blade worned out
Jun 26, 2014 | Ricoh Aficio 2035E Digital Copier. 35cpm...
Very dark copy
dark copies or background on the copies
if back ground on the copies need to replace the PCU unit
Apr 07, 2014 | Ricoh Aficio 1013F Copier
Sc:101 problem has been occured , plz..... advice me how to troubleshoot
Please be specif wich model? ie RICOH Aficio 1018.
But generally in most cases that is shading correction problem. You need to unscrew two screws and remove copy glass. Beneath copy glass you will see white stripe that you need to clean and dry. Put all backi in and restart copier.
If that doesnt help call service!
Hope that helps!
Aug 19, 2010 | Office Equipment & Supplies
Background on copies, possible dirty charge roller , I cleaned all optics is there an adjustment to perform to help eliviate this background
yes it could be chatge rollers fault, but how many copies does developer have? I would clean the charge roller with water, dry it, and change the developer. On these digital machine, when you have backround wich is dark, these means that developer is worn out and you need to change it and clean developer cylindar. When the optics is dirty the image will be light, not dark!!!!! Only on analog copiers when optics is dirty the copy is dark, and when the developer is worned out the copy is light!!!!
Aug 03, 2010 | Ricoh Aficio 150 Copier
Aficio 1018 cod.922
tengo una aficio 1018 me sale el codigo sc 922 que puedo hacer de antemano les agradezco
Apr 02, 2010 | Ricoh Aficio 1018 Printer
Functional Problem SC 302
SC 302 has to do with you charge corona wire.  It's unrelated to the toner spill.  It could be a bad conora wire.  Sometimes it's the power supply.  There could be a lot of troubleshooting and repair to do on this one, you might want to contact a dealer in your area since the have the right tools for the right job.
Sep 30, 2008 | Ricoh Aficio 1013F Copier
Ricoh Aficio 1018 - Squeaky noise when it copies.
It could need a fan replacement. Possibly the bearing is going out on it causing the squealing noise
Sep 15, 2008 | Ricoh Aficio 1018D Copier
Ricoh 1018
possibly the process unit and if you look in through the right hand door you can see the drum ...or it could come from a worn out upper heat roller.
all the best
Apr 05, 2008 | Ricoh Aficio 1013F Copier
Toner Is Almost Empty
When you changed the toner bottle, did the cap come out with it? Sometimes the cap gets stuck in the claws that open it up. Remove the toner assembly carefully, and look at the round end with the handle, where the bottle fits in. You should see a set of claws or fingers.
Feb 25, 2008 | Ricoh Aficio 1018 Printer
245 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
