Question about Avanti WC42 Wine Cooler
Temperature began to warm up daily until now it just stopped cooling
  • 3,740 Answers
Hi, I tried to cross the model number you gave with Avanti and it did not do an exact cross reference.
Usually when a cooler slowly warms up the causes can be
1. The Compressor is not running at full speed or has stopped running
2. The PTC start / run relay / Klixon assy mounted on the Compressor has failed
3. The run capacitor has failed.
4. The temperature control has failed.
If the compressor is running and it is NOT cooling then there is a coolant leak or the coolant system had become blocked usually in the capillary tube area.
The current model numbers for parts are here:
http://www.avantiproducts.com/parts-accessories/current/yes
And the Discontinued model parts are here:
Just note there are many aftermarket (like part) sources that will be much cheaper than Avanti sourced replacement parts. Most repair techs would advise you to use locally sourced replacement parts.
Posted on Feb 04, 2010
Why would gauge cluster not funtion until interior temperature reaches a certain level?
Could be a weak connection in the wiring harness going to the cluster, or inside the key switch.
Feb 16, 2015 | Cars & Trucks
Lexus rx 330 air conditioning
possible freezing up of either condenser or evap coil have freon level checked as well a expansion valve replaced
Jul 10, 2012 | Air Conditioning and Heat for Lexus RX 330
Need to know if i need to bleed the cooling system, after installing the radiator?
ADD COOLANT IN THE COOLANT OVERFLOW JUG UNTIL COOLANT LEVEL STOP DROPPING AND COOLANT LEVEL STAY AT THE FULL COLD MARK.PLACE COOLANT OVERFLOW JUG CAP BACK ON JUG.CRANK VECHICLE UNTIL ENGINE START WARMING UP. STOP ENGINE WAIT FOR A WHILE UNTIL COOLANT COOL DOWN TO KEEP FROM GETTING SCALDED. USE A LARGE RAG OVER THE OVERFLOW JUG CAP OPEN OVERFLOW JUG CAP A LITTLE AT A TIME REMOVE OVERJUG CAP CHECK COOLANT LEVEL ADD MORE. COOLANT IN THE OVERFLOW JUG.THEN START VECHICLE AGAIN.LET ENGINE IDLE UNTIL TOP RADIATOR GET HOT.THEN THERMOSTAT WILL BE OPEN.WHILE ENGINE IDLING WATCH THE TEMPERATURE GAUGE IN VECHICLE IF TEMPERATURE GAUGE START CLIMBING IN THE HOT ZONE.TURN OFF VECHICLE LET IT SET A WHILE THEN USE LARGE RAG REMOVE OVERFLOW JUG CAP.ADD MORE COOLANT, PLACE CAP BACK ON START VECHICLE AGAIN KEEP DOING THIS PROCEDURE UNTIL TEMPERATURE STOP CLIMBING HOT ZONE.AND WHEN COOLANT LEVEL STOP DROPPING IN THE COOLANT OVERFLOW JUG.AIR IS OUT THE SYSTEM, BUT KEEP COOLANT LEVEL IN THE COOLANT OVERFLOW JUG AT THE FULL COLD MARK.DONT OVERFILL.DONT LET COOLANT OVERFLOW JUG RUN DRY IF SO AIR WILL ENTER COOLANT SYSTEM BECAUSE COOLANT LEVEL WILL BE LOW ENGINE WILL START OVERHEATING.
Jul 24, 2011 | 2006 Dodge Grand Caravan
Our refrigerator is only about six years old. The problem began after the refrigerator was unplugged for about six weeks and then plugged back in. The freezer side works just fine. The refrigerator side...
Maybe corrosion in the cold control. Could be a fan shutting down. When fresh food side is warming up , is fan running in freezer? My guess with the information given. A simple repair.
Mar 28, 2011 | Refrigerators
When the motor is cold and the outside temperature is below 70 the car will not stay running. Will die with in 30 seconds or so of starting, then you have to wait a minute or two befor the car will start...
Are there any service engine soon lights on associated with this problem?
Possible CTS (Coolant Temperature Sensor) or another sensor giving faulty data for the cool air temperature.
Check spark and gas delivery when cool, below 70 deg. If the spark is not being delivered or the fuel injectors are not delivering fuel at this temperature, it will explain why it doesn't run right until it is warmed up.
Oct 08, 2010 | 2001 Ford Windstar
Car overheating?
in no particular order...
  • water pump
  • clogged radiator
  • stick thermostat
  • low coolant
  • inop cooling fans (stop/go driving)
  • clogged cooling system
  • bad coolant
May 24, 2010 | 1999 Toyota Camry
'04 Chev Silverado 1/2ton Heater only blows warm air when motor is at high RPM. When I stop and its just idling, it blows cool air.
It sounds like your thermostat may be stuck open, with the engine working hard the temperature of the engine comes up thus the warm air, but just at an idle the thermostat is letting the coolant circulate and not holding it their until it reaches a warm enough temp. You are most likely going to need to change the thermostat.
Jan 30, 2010 | 2000 Chevrolet Silverado
Cold starts ok warms up shakes and stalls
check engine coolant temperature when it gets warmer, or at operating temperature, and verify that the temperature gauge is showing warmed up to operating temperature. If the coolant temperature sensor tells the computer the engine is cold it will over fuel and miss and the engine will die. When cooled down it will run fine until it warms up. Also could be coil if it starts missing after warmed up.
Aug 18, 2009 | 1990 Ford Bronco II
Avanti WC42 Wine Cooler Logo
265 people viewed this question
Top Avanti Refrigerators Experts
John Tripp
John Tripp
john h
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
