Question about Copystar CS-2030 Copier
C710 Code on Copystar 2030
After installing new drum & blade it gave me a C710 code. I can get the machine to print 1 copy and then it goes to C710. How can I clear this code?
  • Tammie Duggan
    Tammie Duggan Feb 04, 2009
    after changing developer the unit CS2030 started coding C710. While the unit was running I removed and reinstalled the toner cartridge and this corrected the problem till I turned the unit off. Each time I turn the unit off and restart it, it will come to ready and then the C710 error will flash. I reran the U130 simulation and this did not help.
  • Nick Santini Nov 19, 2012
    If you vacuumed your developer tank, there is a good chance you blew out the Toner Sensor. Disconect Toner sensor before vacuuming or do not vacuum. Also, did you use OEM Developer? Over-toned DV could cause a 710 Code, could try cleaning the sensor may work. Make sure your using the correct toner... CS and KM Toner are the same but the catridge is different. Good Luck
    Genius:
  • 1,665 Answers
C710 Toner sensor problem
• The sensor output voltage is outside
the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run.
Try removing and refitting drum and toner.
if this does not help you may have damaged your toner cartridge or the sensor
Posted on Feb 20, 2008
Call for Service ...... C710
Hi there
I have found various documents which may help you with this problem and possible future problems. This page:
Error Codes Kyocera Mita KM1530 Code C710
can find any code connected with Kyocera mita machines by changing the machine and the error code in the appropriate drop down menus. C710 is identified as:
Description Toner sensor problem
• The sensor output voltage is outside the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run. Causes Defective toner sensor. Poor contact of the toner sensor connector terminals. Developer problem.
Another page showing error codes and their meanings is here;
Kyocera Mita Error Code Messages
and this confirms the above.
Also the link below takes you to a Kyocera web page where you can download various manuals for this machine (KM-1530). By changing the product in the drop down menu to KN-2030 you can get similar manuals for this machine.
Download Center
In your question you mention "Compatible KP23153 Black Toner Cartridge 106153" and that led me to wonder if the compatible cartridge is the cause of your C710 error since that is toner related.
Might be worth trying an original cartridge to see if the error goes away.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 24, 2014 | Kyocera Mita KM 1530/ 2030 Copier Machines...
Troubleshooting a Copystar CG1505 with an error code of C710.
If that doesn't help the toner cartridge or sensor is damaged.
Please take a moment to accept and rate this solution accordingly.
Thanks,
Lee
Sep 26, 2008 | Copystar Office Equipment & Supplies
C710 Interrupted Communication at the Destination. If you're the sender, it's happening outside your machine. Most likely, phone line.
Feb 20, 2008 | Copystar CS-2030 Copier
Error code C400
that code points to your laser unit. you will have to have a tech install a new or refurbished one. then code will clear.
hth,
razoras
May 28, 2009 | Copystar CS-2030 Copier
Can some one tell me where i can get the installation drivers
go to this site:
www.copystar.com
hit download
and look in the product under Legacy product Copier MFP
chosee 2030 and chose the print driver or watever you need.
if you need anything else let me know,
will appreciate your fixya rate.
Mar 29, 2009 | Copystar CS-2030 Copier
Error c710? my machice is a CS2030 whatt is? help me
Double check the connector for image process unit (Drum/DV) White connector to the left when you open front cover. Error code is a toner density sensor prob, could just be that connector isnt plugged in right. power down before reconnecting!
Aug 22, 2008 | Copystar CS-2030 Copier
Copy star 3035
The drum unit may need to have the toner collection blade replaced. not the cleaning blade for the drum but the one below it that catches the toner cleaned off the drum. if this blade is old or damaged it losses its seal to the drum and drops tiny specks of toner onto the page.
Hope this helps...
Lbcoast
Aug 20, 2008 | Copystar CS-2030 Copier
Copy problems
1-if you make a copy on the glass instead of the feeder is it still there?
If no, then clean small 1" glass on copier there is a spot on it. even a pencil or pen dot WILL make a line on all copies. easiest way to find it, line up the paper on the small strip of glass and follow there will be something there ( sometimes it's hard to see since the background is black)
2- the drum has a black toner ring around it replace the drum blade or drum unit
Aug 07, 2008 | Copystar CS-2030 Copier
Set the eject tray
is there a job seperator on this machine (gray tray in middle of paper eject)? If so try this...Press */language key @ left of control panel...Scroll down to "Machine default", press enter key...enter code 2000 or 6482...scroll to ejector of fax (if equipped) or ejector of copy...select what tray ...scroll up to "end"...press enter...that should bounce you back to "Ready to copy" screen.
Jul 06, 2008 | Copystar CS-2030 Copier
Error appearing on screen C710
Did you disconnect telephone line?
C710: Interrupted Communication at the Destination.
Feb 15, 2008 | Copystar CS-2030 Copier
Copystar CS-2030 Copier Logo
334 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
