Question about Nokia E55 Smartphone
My e55 won't turn on anymore. This is my second e55 in 4 months. Is this a comon problem with the model?
Panasonic DMR-E55 DVD Recorder plays does not record
Are you trying to record from a broadcast signal, or via one of the SCART inputs? The E55 has an analogue tuner. If the TV companies in your part of the world have switched to digital broadcasting, the E55 can ONLY be used to record via the SCART and other video inputs, the tuner won't receive anything
Dec 18, 2014 | Panasonic DMR-E55 DVD Recorder
Went down now 4 way flashers come on when either signal is applied
I don't know much about the newer model bikes as I work on the old stuff that the dealers won't mess with anymore. Try this. Press and hold both turn signal switches for a few seconds and let go. That's supposed to turn the 4-way flashers on and off. Maybe it'll "reset" them as well. If not, drop me a note at wd4ity@bellsouth.net and I'll send you everything I have about turn signal units and how to troubleshoot them. Don't forget to tell me what you want.
Steve
Sep 07, 2011 | 2008 Harley Davidson FLHX Street Glide
Hi! My Nikon S570 model won't turn on. I haven't dropped it or anything and I charged the battery and it was complete. I've had this camera since February 2010. What should I do?? -Monica
i have a nikon s570 that is about 18 months old. (not under warantee anymore) it won't turn on, so we bought a brand new battery, charged it and it still won't turn on. Nothing. no motor noise, no lights, nothing. any ideas? nikon wants us to send it to them for evaluation and fixing....any thoughts?
Jan 15, 2011 | Nikon COOLPIX S570 Digital Camera
Ihave dmr-e55 it records advd for 5 minutes and it goes to self check
1) Press and keep [POWER] button on the unit for more than 10 seconds
to turn off the power of the unit.
2) Unplug power cord and wait for approx. 1 minute.
3) Plug power cord in.
4) The display shows [RECOVER] or [SELF CHECK] and it becomes under
recovery. Wait till the message on display disappears.
*When the unit does not recover after taking above procedures (1 to
4), it is needed to be checked and repaired.
Mar 25, 2010 | Panasonic DMR-E55 DVD Recorder
Self checking
I have had a Panasonic DMR-E85 with this exact same problem you are describing. As I bought a Freeview Dual-tuner PVR I just bought a second-hand DMR-E55 as I liked the Panasonic interface. Two months down the line it is now exhibiting the exact same problems, except now as well as the continual self-check rebooting, it's also refusing to eject the disk. Booo. Time for me to buy a new DVD recorder again, and this time certainly not Panasonic... :(
Dec 04, 2009 | Panasonic DMR-E55 DVD Recorder
Recorder keeps 'self checking' then taking dvd back to begining, although only on recordable dvd's, not rented. Are recorders worth repairing or are you better just buying another?
Dec 02, 2009 | Panasonic DMR-E55 DVD Recorder
I entered high speed sim on and my china nokia e55 was off
The phone is bricked. Reflash the firmware with a flash data cable.
Aug 14, 2009 | Samsung SCH-U470 Juke Cellular Phone
Flashes error E55 on display and does not copy
Fusing Error -Either a blown heater lamp, or thermistor. Worst case is a main board problem. problem can only be reset in Service Mode after problem is resolved (SP97)
May 06, 2009 | Office Equipment & Supplies
DVD Recorder keps re-starting self test & will also not finalize discs.
This seems to be a common problem with the E55 and E85 models, could be one of two things, either the RAM Drive or the Power control ic (STRG6353 primary side of PSU), i would suspect its the latter. You'll need an engineer to replace this component.
Oct 29, 2007 | Panasonic DMR-E55 DVD Recorder
Nokia E55 Smartphone Logo
213 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
