Question about Exercise & Fitness
It shuts down when speed reaches 6mph or above
  • 79 Answers
This happens when you have the treadmill connected to a shared outlet, usually consumption may be among the 12AMP to 23AMP depends on the motor drive so I recommend you do a facility dedicated only to the treadmill with a 20amp circuit. maybe need to check the belt and the belt
Posted on Feb 06, 2010
I have the carrier infiniti system. When my thermostat reaches the set temperature it doesn't always shut off. I shut off the main control to let it reset. It works for a while and then it starts
Carrier Infinity system is a variable speed unit that will just slow down as it approaches set point. Unless it overshoots the set temperature (you have it set on 72 and the temperature keeps rising above 72) this just sounds like normal operation.
Nov 13, 2012 | Heating & Cooling
'03 Lincoln Navigator has shut down 3 times in the last few months while driving for no reason. Have to wait about 7 minutes before it will start back up. Happened on the highway also.. How do i fix this...
Spray the Throttle Plate with CRC Throttle Body Cleaner
Not better--Test the TPS Sensor and replace, only if it
fails a test
Clean the MAF Sensor with CRC MAF Cleaner
You have an electronic throttle control motor,
if the throttle plate sticks ,it goes into ETC Failsafe and shuts off
or only goes 6MPH
Dec 20, 2010 | 2005 Lincoln Navigator
Noise at shut down
The noise is caused by the engine running on after the ignition is shut off. It makes noise because the pistons are rattling in the cylinders from incorrect timing. This has nothing to do with the mechanical or electronic timing of the engine. The engine runs on either because of hot glowing carbon deposits in the cylinder head or because the engine was shut down when it was running too fast. Sometimes the carbon can be literally blown out by running the engine at high rpm for a short time. Put it in second gear and run it for a couple of miles on the highway. If this does not work the heads will have to be removed and the carbon cleaned out manually. The shut down when running too fast problem can be caused by the idle being set too high or by shutting the engine off before it has reached idle speed. If you can adjust the idle speed try reducing it. If not always hesitate before shutting the engine down to let it reach idle speed. Good Luck!
Mar 20, 2010 | 2001 Ford F150 Styleside SuperCrew
Too slow how do I speed it up , a Pihsiang shop rider delux
hi, have you tried another charger as this sometimes can lead to batteries not 100% fully charged , I think the scooter in question is 6mph , check battery leads are a good connection and make sure the speed variable pot on the control panel is working correctly , is the speed pot working correctly (Wig wam) , try moving the lever in a upwards motion while moving forward , does it speed up ? if so it needs replacing.
Regards
GeWiz.
Oct 06, 2009 | Health & Beauty
Power shut down when it reaches 100mph
ASD? auto shut down ..computer rev limiter set for 100?
Nov 10, 2008 | 2001 kawasaki ZX-6R Ninja
Exercise & Fitness Logo
65 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
