Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
Cannot get to liitle box to replace the ink cartridges,the box where the cartridges go in, I do not know how to get the cartridges box to stop so I can get them in,I would like advice from start to finish of how to get it done.
  • 677 Answers
You can always do it thru the utility.
click on start, click on printer n faxes
You will see your epson icon with a check mark, double click on that icon, click on printer tab, then slect printing preferences, printing preferences utility will come up. click on tab, Click on the Maintenance Tab as shown below, then select ink replacement icon. I have a red bullit on it for you to see. Follow thru to changing cartridges. It will move the ink station to the proper stop.
If you find this helpful pls rate me.
Thanks and Good Luck.
Posted on Feb 05, 2010
My printer is not reading the black ink and i know it still has an abundance of ink inside
Make sure you are inserting a genuine Lexmark cartridge and not refilled/remanufactured.
Please follow the steps below to fix the issue:
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
6. When the printer turns on, reinsert both cartridges.
9. If the black cartridge ink level is still not recognized, try to insert a different known working black cartridge to determine if the other is faulty. Or replace it with a new cartridge. It could be that it's gone faulty.
Aug 31, 2011 | Lexmark X2670 All-In-One Printer
How do i install my ink cartridges into my epson stylus nx125
Starts on page 23. http://files.support.epson.com/pdf/nx125_/nx125_qr.pdf
Replacing Ink Cartridges Make sure you have a new ink cartridge before you begin. You must install new cartridges immediately after removing the old ones. Caution: Do not open ink cartridge packages until you are ready to install the ink. Cartridges are vacuum packed to maintain reliability. Note: Leave the expended cartridge installed until you have obtained a replacement, or the ink remaining in the print head nozzles may dry out. 1. Turn on your printer. 2. If an ink cartridge is expended, the error and ink lights on the control panel stay on. 3. Open the document cover, then open the ink cover. Caution: Do not remove the ink cartridge guard or you may damage the printer.24 Maintaining Your Printer 4. Press the y Stop button. If a cartridge is low or expended, the print head moves that cartridge to the replacement position to indicate that it should be replaced. The P Power light starts flashing. If two or more ink cartridges are expended, the expended cartridge at the far left moves to the replacement position. The P Power light starts flashing. If no cartridges are low or expended, the print head does not move. Note: Do not hold the y Stop button for more than three seconds, or the printer may start cleaning the print head. 5. Squeeze the tab on the cartridge and lift it up. Dispose of it carefully. Do not take the used cartridge apart or try to refill it. Warning: If ink gets on your hands, wash them thoroughly with soap and water. If ink gets into your eyes, flush them immediately with water. Keep ink cartridges out of the reach of children.Replacing Ink Cartridges 25 6. Before you open the new cartridge package, shake it gently four or five times. Then remove the cartridge from the package. Caution: Do not touch the green chip on the front of the cartridge. This can damage the ink cartridge. 7. Remove the yellow tape from the bottom of the ink cartridge. Caution: Do not remove any other labels or seals, or ink may leak. 8. Insert the new ink cartridge into the holder and push it down until it clicks into place. 9. Press the y Stop button. If another cartridge is low or expended, it moves to the replacement position. Repeat steps 5 through 8 to replace any other cartridges that need to be replaced. When you press the y Stop button and no other cartridges need to be replaced, the print head moves to its home position and the printer starts priming the ink. This takes about 1 1/2 minutes.26 Maintaining Your Printer When the P Power light stops flashing and the error and ink lights go out, ink charging is finished. 10. Close the ink cover, then close the document cover. Caution: Never turn off the your Epson printer while ink is charging or you'll waste ink. If the error and ink lights remain on after the print head moves into its home position, an ink cartridge may not be installed properly. Press the y Stop button again, and then press the ink cartridge down securely. Note: If you replaced a cartridge while copying a document or photo, cancel printing and make sure your original is still placed correctly on the document table. Then copy your original again. If you remove a low or expended ink cartridge, you cannot reinstall and use the cartridge.
Mar 09, 2011 | Epson Stylus Multifunction Inkjet Printer/...
I have HP Officejet 6310 All-in-One I replaced black ink cartridge No 98 just recently, and since then I have problems to print anything. When I try to print I get this message on printer?s...
hello, some of the time the color ink cartridge can cause the problem, especially if its a refilled ink, but at same time, i do know some of the new inks right out of the box will fail. so try with a new color cartridge first.
Sep 30, 2010 | HP Officejet 6310 All-In-One InkJet...
Cannot get ink cartridges to stop at replacement Epson 300 series
If this is a new cartridge, open the front cover and remove all cartridges. Be sure the protective film has been removed from the cartridge prior to installation.
Inspect the contacts on the new cartridge for damage. Replace the cartridges in the correct place, close the front cover and power the printer down and then up again.
Hope this initial information and idea helps. Let me know for any clarification.
Jul 08, 2010 | Epson Stylus NX400 InkJet Printer
How do you replace ink in EPSON TX110? Paul
The procedure is shown on the panel you can see if you open the cartridge compartment of your TX110. However, it can take some effort to decipher the icons. It is known to work if the ink low light is on, untested otherwise.
  1. Turn on the printer.
  2. Press and hold the STOP button until the cartridge tray moves out of its bay. It will stop at the ink low notch pointing to the first cartridge out.
  3. Press STOP again. The cartridge tray will move to show you the next cartridge low on ink.
  4. Repeat until you know all cartridges out. After the last cartridge pointed to, the tray will move again and stop in the area where all cartridges can be accessed by hand.
That's it folks!
Nov 12, 2009 | Epson Stylus NX400 InkJet Printer
Epson sx 200 printer cannot change ink cartridge
Ive just pressed the 'stop' button on mine and it moved the cartridge to show which ink needed replacing and then when pressed again it moved to the replacement gap
Mar 24, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Catridge won't go to right position
Please follow the steps below to replace one or more cartridges.
NOTE: It is necessary to have all four ink cartridges installed and supplied with ink in order for the unit to function properly. The unit will be in an OFFLINE state if the any of the cartridges are expended. This is a protection feature of the unit, to prevent air from being pumped through the print head.
Once you start the ink cartridge replacement procedure, you must complete all the steps in one session.
**NOTE** To avoid damaging the unit, NEVER move the print head by hand.
1. Make sure the unit is turned on, and not printing. The POWER light should be on, but not flashing.
2. Lower the OUTPUT tray, and lift the scanner portion to access the ink cartridges.
3. Press and release the INK button. The print heads will move to the left, and the cartridge that needs to be replaced will stop directly beneath the OUT OF INK symbol. Make a note of which cartridge requires replacement.
4. Press and release the INK button again. If more than one ink cartridge is empty, the next cartridge will move under the OUT OF INK symbol. If no other cartridges are out of ink, the print heads will now move to the REPLACEMENT POSITION.
5. Open the CARTRIDGE COVER. Pinch the front and back tabs of the empty cartridge as you lift it out of the unit. Dispose of this cartridge.
6. Before you remove the new cartridge from its package, shake it four or five times.
7. Remove the new cartridge from its package, and lower it into the cartridge holder. Push down gently until the cartridge clicks into place.
8. Repeat steps 5-7 for each cartridge that you need to replace. Close the
CARTRIDGE COVER once all of the necessary ink cartridges are replaced.
9. Carefully lower the scanner, until it clicks into place
10. Press and release the INK button.
The ON light flashes and the printer makes noise. Charging takes about 30 seconds. When it's finished, the ON light stops flashing and stays on steady.
Caution: Never turn off the EPSON Stylus printer while the ON light is flashing, unless the Stylus printer hasn't moved or made noise for more than 5 minutes.
Jun 12, 2008 | Epson Stylus CX5000 InkJet Photo Printer
Dell 725 printer no manual need to change ink cartridge
Here is the manual
http://support.dell.com/support/edocs/systems/725/en/index.htm
Replacing an Ink Cartridge
  2. Lift the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press down on the ink cartridge lever to raise the ink cartridge lid.
  1. Remove the old ink cartridge.
  1. Dispose of the old cartridge properly.
  2. If you are installing a new ink cartridge, remove the sticker and transparent tape from the back and bottom of the ink cartridge.
  1. Insert the new ink cartridge.
  1. Snap the lid closed.
  1. Close the front cover.
Feb 09, 2008 | Dell 725 InkJet Printer
Pixma 4200 compatible ink cartridge problem help
The ink detection is a critical function of the printer.
Ink actually acts as a lubricant for the heads, and running (Printing) without ink is equavalent to driving a car without oil.
I.E. It will seize eventually....
Hopefully you didn't print much without the ink, and your heads are still in good shape...
Here is a chip reset procedure....
With the original chip now attached to the compatible cartridge (you may need double sided tape to get the chip to stick well to the cartridge), and with the cartridge now in the printer, Press and hold the Reset/OK Button for 5 seconds to reset the chips.
  1. The "Ink Low" dialog box will pop up (similar to photo 1 below)
  2. Continue to print until the "ink has run out" dialog box pops up (similar to photo 2 Below) Click "OK" to continue to print.
  3. The "Ink Low" dialog box may reappear, if so repeat the first 2 steps
  4. Then the "once empty" dialog box will pop up (similar to photo 3 Below) Click "Yes" to continue to print
  5. The "Not Liable" dialog box will pop up (similar to photo 4 below). Click "Yes" to continue to print
  6. Continue to print until the "remaining level of ink" dialog box pops up (similar to photo 5 Below) Click "OK" to continue to print
  7. Another dialog box will pop up with the "press and hold the Resume" or "press and hold the Paper Feed" button (similar to photo 6). Press and hold the "STOP/RESET" button (for Canon MP Series) or "PAPER FEED" button (for Canon IP Series) for 5 seconds. DO NOT Click "Back" or "Cancel Printing"
  8. The "Ink Monitor" dialog box will appear and the printer will continue to print. (similar to photo 7) In the event that that the "press and hold the Resume " dialog box pops up again, Press and hold the Paper Feed Button or Stop/Reset Button for 5 seconds
Feb 05, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Waste ink full
This step is a "reset" step for the Canon CLI8 cartridges. The original Canon CLI8 cartridges have a memory chip on the back of the cartridge, which sends a signal to the printer when the cartridge is empty. Your printer won't be able to determine how much ink is in the compatible cartridges, but you can easily monitor the ink level by noticing the ink level drop in the cartridge as you print (the cartridges are see-through), or by noticing low ink output on the printed pages when you run out of ink. The "reset" procedure below is the best procedure we know of to date to allow your printer to use Uni-Kit cartridges which offer a tremendous savings over the Original Canon products.
Oct 31, 2007 | Canon PIXMA iP3300 InkJet Photo Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
42 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
