Question about Spectra Precision Laser 1242-4 Fully Auto Self-Leveling Grade Laser w/ 1275 Laser Eye, AC Charger
Spectra Precision l1242 laser level wont power up
My laser won't power up. it uses ordinary batteries and i plugged in a power adaptor, did i blow something. can it be repaired easily
  • 677 Answers
Check to see if there is a re-set for the system. There also may be an internal fuse.
Posted on Feb 05, 2010
    Scholar:
  • 87 Answers
There's no internal fuse. Likely, when you plugged in your charger, it popped the alkaline batteries. So not your battery contacts are corroded. Use acidic cleaner, like CLR and clean the contacts. Follow that up by using a fine grit sand paper. Fresh new batteries, and try again. If still noting, you can remove the 4 screws on top and take the top cover off. A quick smell will tell you if you have burnt something out. Otherwise, measure the voltage getting to the board, could still have bad contacts.
If you still cant get it to turn on, likely the keypad or main board are dead. There are no parts for these anymore, but if you talk to a survey/laser shop they may have good used parts.
Posted on Sep 06, 2015
Spectra ll400 laser does not rotate when power is on
There was a problem with the LL400/GL4X2's where the system would level, but not rotate. It is usually intermittent. There's an op amp on the keypad board that sends the power to the head motor. This component fails, and the board has to be replaced. It can be pricey if it's out of warranty.
There are a couple other things that it could be, as well. Like the screws holding the motor in place have come out and the motor is no longer in contact with the rotating head. Or something in the head gears. But usually the keypad
Apr 09, 2014 | Spectra Precision Laser LL400 10 Automatic...
Laser won't turn on.
Could be alot of things. Bad batteries, bad battery contacts. Dead main board, dead compensator.
Clean the battery contacts with acetone and a qtip. in the battery compartment and on the battery door, and install fresh batteries. Good ones, Duracell preferably. If it still wont turn on, you'll need to take it somewhere. Trimble, in their grand wisdom made it so you have to remove the decal on the front, to open the laser. So, that will need replacement even if nothing else does.
Sep 29, 2013 | Spectra Precision Laser LL400 10 Automatic...
The off level light doesn't turn off therefore doesn't level at all,
Your vial and compensator no longer match up. Move the foot screws until you can get your laser to spin, then adjust your leveling vial until it reads level again, using the 3 screws holding the vial inplace.
Aug 18, 2013 | Spectra Precision Laser LL500 Exterior...
I need new clasps for LL500 container box.
Yes part number is Q103224 for the New LL500 blow mold case.
Jan 15, 2013 | Spectra Precision Laser LL500 Exterior...
Laser is level but out of level light blinks and will not spin
Your compensator and leveling vial are no longer aligned. Use your foot screws to find a place where the laser spins, then use the 3 hex head screws on the vial, to adjust it to read level.
Dec 23, 2012 | Spectra Precision Laser LL500 Exterior...
Resetting LL500 SPECTRA PRECISION LAZER
If you mean you cant level the laser, there are 3 T15 torx screws that hold the base assy into the laser, accessible through 3 holes in the base plate. Unscrew the three screws and remove the base, and disassemble it, clean all the dirt out and relubricate the base with a heavy silicone lube. Reassemble and it should all move smoothly.
If you mean something else, please specify
May 06, 2012 | Spectra Precision Laser LL500 Exterior...
How to calibrate spectra precision ll500 laser
There are two brass screws under the upper most metal plate. They are the calibration adjustment screws. The manual tells you how to do a peg test. If your peg test is out, move the corresponding screw until you reach the calibration point you want.
Sep 29, 2011 | Spectra Precision Laser LL500 Exterior...
My beam on laser not very visible and being picked up n sensoe to staff
Does changing the battery make a difference in the signal strength? With my Dewalt, I have to change batteries frequently and also clean the battery connections with a soft eraser to keep a strong beam.
One of the reasons, I went with the Dewalt versus the Spectra, I was told that battery life was better in the Dewalt.
Jun 08, 2011 | Spectra Precision Laser LL300 2 Automatic...
Spectra precision laser turns on but doesn't spin
Its usually a simple ''belt'' that rely the head to a motor. Open it, replace it and if its damaged, go to your nearest electronic parts broker, he will sell you a tape deck belt for it. Sometimes rubberband might be okay too...
Jul 24, 2009 | Spectra Precision Laser 1422 2 Manual...
Spectra Precision Laser 1242-4 Fully Auto Self-Leveling Grade Laser w/ 1275 Laser Eye, AC Charger Logo
817 people viewed this question
Top Spectra Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Spectra Measuring Tool and Sensor Expert? Answer questions, earn points and help others
