Question about Dewalt DW715 Heavy Duty 12" Single - Bevel Compound Miter Saw
Dewalt chop saw spinning half the speed it should? motor bushes gone??
jeffbvegas1
  • 520 Answers
SOURCE: dewalt chop saw blows breaker
You can register with Dewalt ServiceNet(www.dewaltservicenet.com) and order parts direct on-line. In San Antonio Tx there is a local source located at 500 Culebra Ave San Antonio Tx 78201 ph#210-732-1221. The service net also provide exploded parts view of your machine which is very helpfull.You may have warranty an this machine in the event of any factory defect associated with this machine which can be determined on the service net....good luck
Posted on Jul 28, 2009
  • 384 Answers
SOURCE: i have smoke coming from motor of my dewalt dw-708
Stop and unpug it if it hasn't already burnt the house down.
Posted on Aug 05, 2009
SOURCE: Metal chop saw blows breaker
Is there anything else running while you are cutting? If not is the breaker 15 amp or 20 amp. If its 15 amp, I would change it to a 20 amp breaker. Make sure the wires are thick enough to handle the extra load. If this isn't the problem check the cord from the saw to the outlet.
Good luck!!
Posted on Aug 23, 2009
Coleman37
  • 337 Answers
SOURCE: Hi my dewalt 708 lx sliding mitre saw, 110v, seems
I have heard complaints that this saw does not do well on angled cuts because of its low power. Try running a shorter and/or thicker extension cord and checking your input voltage. That's about all I can think of, hope it helps.
Posted on Mar 12, 2010
  • 17 Answers
SOURCE: Does the Dewalt Model 871 14
no fuse
Posted on Jul 22, 2010
Macallister chop saw blade problem, the motor runs but when half way through cutting wood the blade stops ?
I'm not sure if you have a chop saw or circular saw. Either way, it sounds like the nut and washer are not tight enough to hold the blade. If you have a circular saw clockwise will tighten the nut and washer onto the blade and hold it in place. Most chop saws are a left hand thread and then you would turn the nut counter clockwise to hold the blade tighter. The blade wobbles because it is not tight.
Feb 23, 2015 | Saws
How to check the electric brake on a dewalt 706 type 1 chop saw
The power cord can get a break in it. Try moving it when this happens. Otherwise, the plug can fall out of the outlet. Sometimes the switch goes bad.
Jan 25, 2015 | Dewalt Saws
Power is going to the motor on my dewalt 12 mitre saw but the motor is not spinning
Does the saw make any noise? If not it could be an open circuit in the field coils
Feb 22, 2014 | Dewalt Heavy - Duty 12" Double - Bevel...
Dewalt miter saw not running at full speed
Problem will be either low brush lengths or burnt armature. Check for arcing when running and excessive sparking will mean motor over haul or replacement.
Jan 21, 2013 | Dewalt Mitre Saw Workstation
DeWalt 742 Flip over bench/chop saw. 110v. Approx 7 years old, and used infrequently. The saw tries to start and momentarily spins for a second or two. Then it seems to trip out 'internally', and if...
The motor or brushes are burn by symptoms you refer.If you can,try to open the saw case and look inside.At the motor check for the cooper wires and the brushes if there some "carbon like burn".
Nov 10, 2010 | Saws
Sir i m azim from fiji dewalt dw 871 xe model chop saw sparks too much at brush.also sounds different.so what the problem .sir technicians say the coil.we tested its ok.we changed armarture but still the...
Hi and welcome to FixYa. I am Kelly
With power off grab both sides of the blade and try to rocking (NOT SPINNING) the blade in opposide directions on each side of the balde. Then while rocking the blade, see if the armature teeters inside the motor.
It it does have excessive movement then the rear motor bearing is probably worn excessively.
I have to ask if this is a 110V cut off saw and your trying to use it on 220V because it will produce the exact symtoms you described.
I also note that you did not mention if you had changed the brushes. Worn brushes or weak brush springs can also cause the symptom you describe.
Hopefully this gives you something to work with.
Thanks for using FixYa!
Kelly
Feb 21, 2010 | Dewalt Chop Saw D28700
My dw718 chopsaw is making a funny noise, the blade seems to be stuck and smoke coming from the motor. whats wrong and can it be fixed?
Sounds like the brushes have gone bad. You should be able to get new ones from eraplacementparts.com
Feb 01, 2010 | Dewalt Chop Saw D28700
Good luck!!
Jul 28, 2009 | Dewalt Chop Saw D28700
Dewalt chop saw blows breaker after a few minutes of use. Bearings bushes and armature ae good. Is the gear box dragging so much that it powers off and blows the circuit breaker? Where in San Antonio,...
Dewalt DW715 Heavy Duty 12"  Single - Bevel Compound Miter Saw Logo
90 people viewed this question
Top Dewalt Saws Experts
Parson's Repair...
Parson's Repair...
JOHN LAPIER
Are you a Dewalt Saw Expert? Answer questions, earn points and help others
