Question about Navman PiN 570 GPS Receiver
My Pin 570 works fine except for its inability to log on to the satellites. I know that the antenna is working fine. Mike
  • 518 Answers
If you click your windows icon and select from the dropdown box, Settings, then click system, then gps and click on, then exit completely and try again.
Posted on Feb 04, 2010
I have a 2011 Jeep Compass the am/fm will not work but cd and satellite work any ideas?
Check used on the rear of the radio or plug in the antenna cause I might have come unplugged
Aug 02, 2015 | Jeep Cars & Trucks
I continually loose my reception on my xm roady xt, i wiggle it around and then it works again, and so on. do i have a bad base unit and do they wear out over time. mike@fgoh2o.com
You need to resolder your antenna port on the dock connector. It's a really easy repair, all you need is a fine tip soldering iron. The antenna jack is on the right of the dock connector, it has 1 middle pin and 1 n-shaped pin that leads to 2 pads on the PCB. Your middle pin most likely has a cracked joint.
Dec 28, 2010 | Delphi Roady XT XM Radio Receiver
Roady XT "Antenna" problem
one of 3 things, either your antenna is not insight of a skies view to receive the signal, or its wire is broken at the antenna, but if you remove the antenna connection frequently it pulls the center wire out of the connection on the end that fits into the radio when its plugged in push on the conductor at the back of the plug and see if this helps,alos if connection is loose take a safety pin and carefully between the outer plug case ans the ground fingers around the center pin push these in so you get a better ground, and lastly try another substitute antenna, I have re-soldered my connections numerous times to fix this issue, delphi doesn't make a very rugged product, good luck
Nov 17, 2009 | Delphi Roady XT XM Radio Receiver
Antenna not found sirius satellite radio
You may have a defective satellite antenna or cable
Nov 09, 2009 | Sirius Satellite Radio Receiver
I bought navmn pin570 i opened the box try to install maps ask me for actvat key any help
Yes, for activate this maps, you must pay in navman web page this service. but, I am using TOMTOM, in PIN 570, and it's working fine!
Nov 08, 2009 | Navman PiN 570 GPS Receiver
Navman pin 570 navigation not working screen says gps port closed
tap on "GPS Status" (second page of GPS software) and be sure that the box is checked in the upper left hand corner. In the same screen, be sure com 8 and 9600 (baud rate) is shown.
May 28, 2009 | Navman PiN 570 GPS Receiver
Receive "Antenna Fail" on receiver
Same problem on my CX-7. I've had antenna replaced one so far. It takes about 30 minutes in the cold (usually on at night on my commute home) to get signal. I agree, during the summer months, everything works fine.
Dec 31, 2008 | Sirius Satellite Radio Sirius SIR-ALP1...
Naveman PIN 570 gps receiver problem
i get the "waiting for gps" message if the gps unit is sending data to the main unit, but no satellite signal is found.
does the unit have sky view?
Sep 16, 2008 | Navman PiN 570 GPS Receiver
Delphi xm2go internal antenna
Don't use the wearable antenna - reputed to not work well - was not a good design idea - I don't think any of the other receivers have this feature if that tells you anything. Record music you like on the myXM feature, and play that when you would otherwise want to receive on the antenna. If you are listening to live news, etc, there may be no good solution. (I have read there is an antenna headset, but don't know much about it, but some reports that it works.)
Jul 23, 2008 | Delphi MyFi SA10113 XM Radio Receiver with...
Navman PiN 570 GPS Receiver Logo
231 people viewed this question
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
