Question about Kitchen Ranges
What causes black sooty like stuff that is gets on the bottoms of my pans when I cook on my gas range?
  • 552 Answers
Http://www.gutenberg.org/catalog/world/readfile?fk_files=12601&pageno=36
Try this. It tell about gas ranges.
This is an online book.
Posted on Feb 20, 2008
Front burner , yellow, flaring flames and sooty pans
Sounds like the front burner gas jet holes are either blocked in places or the gas regulation (air/gas) mix to that burner needs adjusting. Try removing the hub where the gas burns from and cleaning each hole with something like a paperclip and then blowing through it to expel any particals.
Dec 01, 2013 | Rangemaster Classic 90 (Electric) Kitchen...
Glass turns black inside
You don't indicate where the glass is that becomes black/sooty but you can get cleaner specifically intended for cleaning glass fireplace doors. It is more effective than using ordinary glass cleaners
Apr 29, 2013 | Napoleon Fireplaces Napoleon Prestige PRO...
How tp clean black soot off bottom of turkey pot
If you are cooking with propane or natural gas, you may need a new regulator for your range, the black soot is most likely too much gas being used to make the flame. But, as for the soot on the bottom of your pans, try letting the pan soak in a mixture of baking soda and water, then attack it with a brillo pad. Hope this helps!
Apr 10, 2012 | Kitchen Ranges
When our oven is heating up especially and
I'll check the oven bottom pan first, the bottom of the bottom pan ( flame spreader ) must broken off, check the welded area it must cracked. You can either reweld it back on or buy a new pan. Dynasty / Jade ph # 800-884-5233
Nov 30, 2009 | Dynasty DGRSC 36-4CB Gas Kitchen Range
Black soot on bottoms of pans
Wellif you uninstalled and reinstalled the same appliance it should work the same.. thats weird that it changed. however the black soot is usually from flames that are to high. you could try tightening down the orifice where the gas comes out.
Dec 01, 2008 | GE Spectra JGBP35 Gas Kitchen Range
White glass cooktop hard to clean
First thing I thought of was that your pots have oil or build-up of some kind on the bottom. Try cleaning them with a solvent of some kind. As an experiment, try using a pyrex pot to see if that makes a difference. As for cleaning the cook top, I use a vinegar and water solution with a soft cloth or very low abrasive scrubber as you can scratch the glass quite easily on some kinds.
Sep 17, 2017 | Jenn-Air JES9860 Electric Kitchen Range
The oven is constantly burning things I cook. If I reduce the heat - food doesn't cook properly and when you use the correct heat, the bottom on the food is burnt black. Can anyone help. Also no way of...
There are other possibilities, but,..... this sounds like what will happen if you use too large of a pan or cookie sheet(s) in your oven. If there is not much space on the sides and front and back of the pans, the heat gets trapped under the pan (causing burning) because not enough hot air is getting to the top of the oven where the oven thermostat is located.
Sep 23, 2008 | Kitchen Ranges
Burn marks on pot and pans
Just got a Garland 6 burner stove w/single oven. It was Natural gas need to convert to propane. Need supplier for conversion kit
Sep 05, 2008 | Garland H283 Gas Kitchen Range
Cast iron pans
Cast iron cookware is NOT recommended due to the weight and the potential damage it can cause to the glass top surface. There's nothing better than a good old-fashioned cast iron skillet that's been broken in over a number of years of use, but they are better suited for gas ranges rather than electric. I hate it. I have several cast iron skillets that I only use on the outdoor grill, because I currently own a glass top electric range.
Aluminum bottom pans and copper bottom pans heat well, but can leave metal transfer marks on the cook top surface. If the marks are cleaned after use with an approved stove top cleaner, you shouldn't have any problem retaining the condition of the glass surface, however. Stainless Steel seems to offer good resistance to metal transfer, but takes a little longer to heat than aluminum or copper. So...you have somewhat of a trade off. Baked enamel cookware seems to be the best recommendation because it heats wells and causes the least amount of damage to your glass top surface.
IMPORTANT: Make sure the bottom of your cookware is FLAT. If your pans are warped or bowed, this can cause uneven heat transfer on the heating elements and potentially cause the cook top to crack. Most manufacturers will not replace the top if it still under warranty if it is determined that your cookware caused the problem.
A little over kill, but I hope this helps you.
Feb 14, 2008 | Maytag MER5770 Electric Kitchen Range
Kitchen Ranges Logo
357 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
