Question about Husqvarna Garden
Iput a new chain on my 350 chainsaw now the cover won't go back on it seem like the brake band won't fit over the clu.
    President:
  • 2,220 Answers
The chain brake is released. try this:
Reset Chain Brake by Dolfoff
Please follow this link, http://www.fixya.com/support/t3102817-re_install_side_cover_after_chain
Cursor down to “Best Solution”, while there click the “Was this helpful? [Yes]” button
If you do not have a vise a large C clamp to a work surface might work, you may still need a block or two of wood.
It requires a fair amount of force. It usually makes a loud click when a keeper engages a detent. Just pull it slowly aft with a little grunt if need be at the rear extreme. HTH
Lou
Posted on Feb 05, 2010
    Sniper:
  • 197 Answers
Use an allen wrench to remove the brake handle screws on the power head.Once handle is removed from saw slip it into the brake cover firmly and pull handle back until it clicks.
How do you replace clutch on cs 350 echo chain saw
I am guessing what you are calling the clutch band is the anti kickback brake. It is operated by a "lever" in front of the hand grip on the front of the saw. Pull that lever towards the rear of the saw to get more slack in the band.
Jul 31, 2014 | Echo Garden
Tip
Replacing brake band on Husqvarna 357/359/340/345/350/346/445 and many others
Before attempting to repair any chain brake, eye protection should always be worn, these machines all have an out board chain brake, known as a knee link brake due to its actuating mechanism, start by makeing sure the brake is off, by pulling the brake handle fully back to the top handle, now remove the bar securing nuts, remove the brake/side cover, the hand guard stays with the saw, so the cover is quite difficult to hold when removing the spring, so take two 8 mm bolts, clamp the hex heads in a vice, spacing them out the same as the fixing holes in the brake, now fit the brake /cover band up onto the up standing bolts, use the two bar nuts to secure the brake to the bolts, now insert special tool part no. 502522202 into the actuating quadrant and turn to activate the brake ( this will remove much of the spring tention ) if you do not have the tool you can remove the hand guard from the saw and use that, or a sturdy pair of long nose pliers, now remove the cross head screws from the spring cover, edge the back of the spring up enough to insert a suitable screw driver into the end, lever the spring up and onto the screw driver shaft ( this will stop it flying out ) remove the c clip securing the actuating quadrant to the brake cover, gently lever out the roll pin in the anchor end of the band, the band will now lift out of the cover, remove the single cross head screw securing the knee link mechanism to the band. Refit the new band into the knee link and re fit the screw, re fit the quadrant onto the post in the cover and re fit the e clip, press the anchor end of the band back into the cover, insert the spring back onto the knee link spigot, compress the spring and push it back into the cover, the best way to compress the spring is to use a good pair of long nose pliers, push the closed jaws into the end of the spring ( this will stop the spring flying out ) now push the pliers in to compress the spring against the knee link, and back into the cover, refit the spring cover screws, you now need to load the brake before it can be put back onto the saw, use the special tool, or the removed hand guard to do this, it will take a fair amount of force to re load the brake, once loaded re fit to the saw.
on May 12, 2011 | Garden
Problem chain / break cover chainsaw
Hi, hold the cover in a vice where the bar nuts normally tighten up to, then pull the chainbrake lever back in the direction the handle bar would be. You will feel a click and the lever will stay back and the brake band will be released. Then refitted cover to the saw. Regards Phil.
Aug 20, 2012 | Garden
Chain saw brake on husquvarna model 41
To replace the brake band do as follows, remove the bar nuts and take the brake away from the saw, engae the brake to remove as much tention off the internall spring by pushing the hand guard fully forward, remove the allen screw securing the hand guard, do not remove the e clip and pin from the hand guard, tap out the pivot collers and remove the hand guard, remove the cross head screws securing the spring cover, carefully remove the spring from under neath, tap out the silver pivot pin from the knee link activating arm, use a puch from the other side of the brake to remove the roll pin securing the other end of the band, with the band out remove the screw securing the band to the knee link, install the knee link to a new brake band, re fit the roll pin in the band and re fit into the cover, insert the spring, this will have to be compressed to get it back in, re fit the spring cover, you need now to load the brake, fit the hand guard onto the cover, insert a conical puch through the hand guard and cover to enable you to pivot the hand guard back and load the brake, now fit the hand guard properly onto the cover and re fit the collors and screws.
Jul 26, 2012 | Husqvarna Garden
How do I get the brake band ,located inside the chain cover, assembled back onto the chain saw. clutch assembly. The band brake diameter seems too small to fit around the clutch housing.
You need to load the brake, clamp it in a vice, be carefull not to damage the cover, if the hand gaurd is connected to the brake pull it fully back until the locks off, this may take a fair amount of force as it is compressing a large spring, if the hand guard is on the machine, remove it and use this as a tool to load the brake, the only other way is to remoce the clutch and sprocket, now refit the brake onto the saw, now pull the hand guard fully back to load the brake.
Apr 11, 2011 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
How doe the band on my chain break attach to my chainsaw mine is broken and i do not know how to install it. or how to get the clutch off so i can replace it
It can be a little tricky!
If you are referring to chain break band
Tools you will need:
1/2 Socket (to remove bar nuts)
T25(torq) or you can use a Flathead screw driver but is a little harder.
Remove 2 bar nuts,Clutch cover,bar,chain, 2 screws on black bar handle right behind clutch cover(this is needed because there is a hidden screw there for the chain break) You will need a new chain brake (my guess is that it is part # 530071893 aprox $15) but you will want to verify that with your model number.
You should see the chain break assembly, 3 - T25 screws are visible after the clutch cover is removed(note sometimes you have to clean saw dust to make screw head visible) the other T25 screw is hidden under the black bar handle. Once you remove all 4 screws on the chain brake you will be able to pull it off.
Installing the new one is the tricky part because if it is set(or break is on) you will have a hard time putting it on.One of the easiest ways is to focus on it near the muffler you will see that a metal 3 pronged gear fits into the plastic part of the chain break handle.and if the band is too tight to fit over the clutch drum you will have to carefully reset it by applying pressure onto the area that has the 3 pronged gear and chain break handle make sure that the handle is pushed forward all the way while you apply pressure then slowly pull chain break handle back till you hear a "snap" this resets the chain brake spring and the band should now fit over the clutch drum.Now, proceed with putting back together 4 chain brake assembly screws,2 handle screws,and bar,chain,clutch cover,and 2 bar nuts.
Please note it is important that you apply quite a bit of pressure onto chain break area where metal (3 pronged) gear fits into handle while resetting or when you reset it the metal part can cut into and damage the plastic piece in the chain break handle.
You can see a breakdown here: http://www.searspartsdirect.com/partsdirect/part-model/Poulan-Parts/Chainsaw-Parts/Model-P4018WT/1324/1503220/P0506041/00002?blt=06&prst=0&shdMod=P4018WT
Hope this helps!
Feb 20, 2011 | Poulan 18" Wild Thing Chainsaw
I can't get the cover back on after I fixed the tension on the chain. There is a metal ring and it no longer seems to fit.
take your time with this step! The steel band is part of the brake for the saw. You will need to take very special care and take your time when putting it back together.
The trick is in the braking lever. you will need to pull back on the braking lever, align the steel band over the steel drum, and and align the two contact points that will connect the steel band to the braking lever. After it is in place actuate the lever to see if it is working correctly. This function should cause the chain to stop moving and move when the brake is released. Where strong rawhide gloves to protect yourself from the chain. Good-luck.
Jun 08, 2010 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
The bar and gear cover will not go back on. The
The metal band is the chain brake . It must be compressed so you need to move the brake handle forward.
Feb 01, 2010 | Husqvarna Forest & Garden #952802239 235E...
Garden Logo
85 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
