Question about Splendide 2000S Front Load Washer / Dryer
I am in need of a Water Pump for a Splendide 2000 Washer Dryer/Combo... Amer WD 802. Wondering if you would be able to provide this part.. IF SO, please forward the Cost and Shipping charges. Thank you very much. william A. Rodgers, Sr
  • 736 Answers
SOURCE: Washer heating element????
thats a rather clever machine ..it uses cold water to condense the steam created in the drying process .. so there is no "wet" air exhausted into the room (no external vent needed) .. alas it does not have a "water" heater built in .. just an air heater for drying .. so you would have to use a detergent designed for cold water in your case ... make sure you clean the drain filter often in that model ..
Posted on Aug 17, 2009
SOURCE: splendide 2100 washer/dryer now fails to dry -
Remove the top - two screws in the back then slide forward
In the front right top you will see the air box and the terminals for the heater coil along with other wires and sensors. Start the washer on a dry cycle and check the voltage to the heater terminals. You will be looking for 120 AC. If voltage there but no heat the heating element is bad. If no voltage there follow the wires to the overheat switches and check the voltage on the other side of these switches (round devices with two terminals on top). If there is voltage there then the switch has tripped. Unplug the machine. Look for a spot of paint on this switch, scratch it away and you will see a small hole. Insert a strightened paper clip into this hole and push to reset the switch. Re-power and test the results.
No power to these switches probably means a bad circuit board $$$.
Posted on Dec 21, 2009
blueextc3221
  • 15935 Answers
SOURCE: MANUAL FOR '' ZANUSSI WD-802 ''
Head over to the manufacturer's website.
Typically they have a SUPPORT section - where you enter the FULL model number, and then can download a FREE manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
  • 19 Answers
SOURCE: need a new motor for my Splendide 2000 WD 802 M ,
http://www.splendide.com/wd2000s.htm also try www.westmorlandsales.com .
Posted on Oct 23, 2010
SOURCE: Splendide Model WD 802 . Would not drain water.
I have a Splendid Washer/Dryer combo Model # WD802.
The water is not draining. I have taken the filter out, cleaned it, still does not drain. Gets to the drain cycle and does not go any further. Same in every cycle.
Anyone with suggestions for repair ? Thanks
Posted on Aug 29, 2011
I need a water pump for a Kariba WD 802 washer/dryer combo.
Joan, just enter the name and model of your machine into a web browser, i.e. google, bing, yahoo et al, and the words spare parts, spares, or the like along with your state, / county / city / town and hit the search button, this should throw up plenty of results that you can trawl throygh and select your preferred supplier.
Jun 08, 2016 | Splendide RV Combo Washer Dryer - Vented
Wd2000 washer dryer combo timer advances around timer
If the program selector knob keeps turning, the machine needs to be reset.
Wait a few minutes for the drain pump to empty the tub, switch the washer-dryer OFF. Select one
of the Reset positions on the knob, then switch it back ON.
The link below will take you to the manual.
Hopes this helps.
http://www.splendide.com/manual_wd2100_2000s.pdf
Oct 12, 2014 | Splendide 2100 Vented Washer-Dryer
Aug 01, 2011 | Washing Machines
My Splendide 2000 combo stops midway in the wash cycle. What is the cause and how can I fix it please?
If it doesn't go from the wash to the dry, check to make sure that both the washer and the dryer are set before the start of the cycle. It also could be blowing a fuse.
Michael Lee
Thor Appliance Company
www.thorappliances.com
Sep 13, 2010 | Splendide 2100 Vented Washer-Dryer
Aug 17, 2009 | Splendide 2100 Vented Washer-Dryer
Kariba WD 802, need a part number for the Wash/Dry Selector Timer. The machince works properly when manually rotating the timer, it will not advance on it's own.
head over to repairclinic.com and enter your model # for a complete parts list.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Splendide 2100 Vented Washer-Dryer
Splendide 2000 S runs through cycle but water left in unit (hums)
The drain pump is probably clogged. or drain hose is kinked. I have a trouble shooting guide if you are interested.
Coach Tech RV
734 777 6432
Mar 23, 2009 | Splendide 2000S Vented Washer/Dryer
WDB1043M Bendix Washer/Dryer
I had the same problem. Then I discovered that the Bendix USA WDS1043 / WDC1024 is the same, or almost the same, as a Splendide Comb-o-matic 6000. You can find an extensive parts manual at
http://www.splendide.com/service/Combo_PartsBreakDown.pdf
and an owners manual at http://www.splendide.com/manual_wdc1024m.pdf
I think Splendide is still in business, in which case they may also be able to supply parts for the Bendix WDS 1043 M - check them out at
They can also supply a replacement washer/dryer combo when your present unit finally dies.
Good luck with a great washer combo!
Colin
Jul 28, 2008 | Tricity Bendix WDR1040W Front Load Washer...
Splendide 2000S Front Load Washer / Dryer Logo
271 people viewed this question
Top Splendide Washing Machines Experts
Doug Adams
Doug Adams
JP Services
JP Services
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
