Question about Epson Stylus CX3200 All-In-One InkJet Printer
I have an epson CX3200 about 4 years old. If I do
I have an epson CX3200 about 4 years old. If I do a nozzle check it is fine and paper goes through OK. If I try to print a document the paper is pulled in at a slight angle, it then stops and I get a paper jam message. The paper path is clear as far as I can see.
Many thanks,
    Scholar:
  • 142 Answers
Get a bright flashlight and look for tiny bit of paper, hair or other object.
If you see nothing to remove, try blasting the paper path with compressed air.
Posted on Feb 04, 2010
Why is my Epson WF 2530 double shadow printing?
Allen, that's very unusual. I've been using a workforce printer for years, and haven't ever seen anything like that.
What paper are you using, and what paper setting in your computer?
When you rand a nozzle test, were the nozzle lines even, or did some look kind of out of place? (a deflected nozzle will give that gosting effect, and "underhead cleaning" is the answer)
May 01, 2015 | Epson Office Equipment & Supplies
I have been using an epson stylus color 880 for years. One day it would not print. Replaced the cartridges and still will not print. It goes through the printing procedures but nothing shows up on...
The print head nozzles may be clogged. From the Utility section found in the EPSON printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Perform up to 3 cycles if necessary. If the nozzle check is not printing completely, and if the head cleanings do not help the nozzle check pattern to print completely, try replacing the ink cartridge. Any ink cartridge installed into the printer must have a blue label on top of it. If the blue label has been removed from the ink cartridge, do not install the cartridge. Using an ink cartridge, which does not have the blue label on it, may damage the printer. Caution: If you have already installed a cartridge which is missing the blue label, or if a previously installed ink cartridge was missing its blue label at the time it was installed, and now head cleanings do not help the nozzle check pattern to print completely, your printer may require service and you should contact the EPSON Connection for further assistance.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 08, 2011 | Epson Stylus 880 InkJet Color Printer
Hi My Epson Stylus R200 print is nearly unreadable. The status monitor says status is OK and the nozzle check is fine
Ensure the nozzle check has 6 colours if it doesn't you will need to try head cleaning. you may also need to align the print head. All this can be found in the same place as the option for nozzle check.
If that is ok try a different paper type, ensure you are using relativly fresh ink.
Feb 02, 2010 | Epson Stylus Photo R200 InkJet Printer
I'm using an iMac G5 with an Epson an Epson RX595 printer. Everything worked well for a long time. Now ... the printer just shoots paper through constantly without printing. I've re-installed the newest...
hi,,
the nozzles of the printer might be clogged by dried inks thats why when your printing, its feeding the paper, as if its printing but no inks on the paper. print a nozzle check to see which part or color have clogs, if there are gaps or breaks, do head cleaning untill no more gaps then try printing.
click this link to see how to print a nozzle check and run a head cleaning, click the search box and type nozzle check, select "check the print head nozzles"
type head and select "clean the print head nozzles"
http://files.support.epson.com/htmldocs/rx595_/rx595_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
pls come back and give me a vote. I would really appreciate that,thanks in advance. good luck.
Dec 03, 2009 | Epson RX595 Photo All-In-One Printer
Printer is only printing one color
possible printhead issue. Cartridges maybe outdated too. If you haven't used the printer in a while, the inks on the nozzles will dry out, thus clogging the printhead nozzles. If your cartridges are installed over 6 months now, it may be outdated. Replace cartridges if they are already outdated.
Do a printer check by printing a nozzle check pattern from the printer. To print a nozzle check pattern, turn the printer off. load 10 sheets of regular paper into your printer. hold down the paper button while you turn the printer on, keep on holding down the paper button. let go of the paper button when the powerlight is already blinking. If there are gaps or missing colors on the nozzle check pattern, please do 3 head cleanings. compare the nozzle check pattern over the last printout. If you see improvement on the pattern, continue cleaning the printhead till you get a perfect nozzle check pattern.
If there are no improvements, your printer may need service.
If your printer is not under warranty anymore, log on to support.epson.com. Click on help me find a service center to the bottom right of the page to find epson certified servicers near to your area.
The printer has a one year warranty from the date of purchase. Pls call epson if your unit is still under warranty.
Apr 16, 2009 | Epson Stylus C120 Color Printer InkJet
Epson RX620 yellow lines/blocks on page
Try to print the nozzle check, and see what your out put is like.
If it is not giving you a regular pattern, then have the nozzle
replaced. Most times when the nozzle is clogged with ink, you
get such out-puts. So follow this steps.
How to print the nozzle check:
1. Press the Setup button.
2. Use the arrow buttons to select Nozzle Check, then press the OK button.
3. Confirm the message on the display, then press the OK button to print the Nozzle Check.
Shown below are some examples of what the nozzle check may look like.
Nozzle check pattern with no gaps
Nozzle check pattern with gaps
Apr 14, 2009 | Epson Stylus DX6050 All-In-One InkJet...
My pictureMate 500 prints green only
Hi
Try running a head cleaning cycle from the maintenance menu, then print a nozzle check. try to run 3 head cleaning cycles then try printing again
. If all fails call epson for replacement.
Hope this helps
Nov 15, 2008 | Epson PictureMate 500 InkJet Photo Printer
Black ink on glossy paper looks like leopard spots
printer need head cleaning , after cleaning check nozzle , if solid color appear w/out space on black color it means good and clean nozzle.
Dec 27, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Epson CX5400 Printer Error Light and Message
Dont know how it is in the good old US but here in UK - Epson have this super 'swap out' scheme for the more complex devices that die out of warranty. What we do - is to phone Epson and tell them the tale. they will then offer to send FedEx with a new printer and you give the driver your old one all for a quick flash of your plastic friend. If they do it - go for it.
Aug 27, 2007 | Epson Stylus CX5400 All-In-One InkJet...
Epson Stylus CX3200 All-In-One InkJet Printer Logo
121 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
