Question about Dryers
How to remove the bottom front of a kenmore dryer
How to remove the bottom front panel of a Kenmore dryer
  • Dryers Master
  • 8,220 Answers
Check this video out: HOW TO
Posted on Feb 04, 2010
How do you get the bottom panel under the door of the dryer off? It looks like there are clips of some sort there, but can't remove or move the clips enough to remove the door? please give step by step...
Unplug the dryer before attempting any repair works.
The bottom front panel is secured to bottom of the top front panel by two securing clips. Insert a flat-bladed screwdriver between the top front panel and the bottom front panel as shown then pry the panel out then lift it off the cabinet.
Install the bottom of the bottom front panel first when reinstalling then push the top back into position until the clips engage.
Aug 21, 2010 | Kenmore 62982 Electric Dryer
I am haveing problem removing the front panel on my gas dryer?
the panel comes off using a putty knife to release some spring clips 6568d2d.jpg
Mar 07, 2009 | Kenmore 72802 Gas Dryer
How do I remove the front panel from my kenmore 80 series dryer to replace ignitor?
Either you have to pry the top up with a wide flat screw driver or two screws at the very bottom of the front panel. Whichever it needs to be done the other end will be hooked in place. make sure you remove door switch wires before taking front panel off all the way. Good Luck
Feb 28, 2009 | Kenmore 63942 Dryer
Removal of front cabinet panel of washer section
Should be two screws on each side of the bottom of the front panel. Takes those out and push the panel up and out. (There are two "tabs?" in the middle of the front panel that lock into the side panels, so you have to push up and then pull out.)
Jan 08, 2009 | Kenmore 98702 Stacked Washer/Dryer
How do I remove the bottom panel from the Kenmore Elite Quiet Pak II dryer? I need to vent the dryer from the bottom rather than from the back of the unit.
hi. thanks for the question . 2 screws on the bottom of the front panel .remove these screws . pull on panel, lift from bottom . thanks the appliance doc. please rate this answer. thanks the appliance doc
Oct 01, 2008 | Kenmore Dryers
Dryer won't start
hi thanks for the question theres a small thermal fuse located under the door behind the panel to get access remove front bottom panel 2 screws at bottom of panel and on the air duct to the left theres a small thermal fuse check it for continuity if bad replace thanks the appliance doc
Aug 20, 2008 | Kenmore 62872 Electric Dryer
Front cover of my kenmore dryer
Assuming the two top inside screws have been removed, grasp each side of the front panel, slightly tilt away from cabinet and lift up. (may have to rock back and forth a little)
Jun 15, 2008 | Kenmore 62602 Electric Dryer
Kenmore dryer help?
Sounds like motor is stalled. Remove the lint filter, look inside down toward the bottom left corner at the blower wheel. Something may be jammed in the blower wheel. If difficult to see, TURN OFF POWER TO MACHINE, remove bottom access panel. 2 to 3 screws on bottom of panel. Remove lint housing (3 to 4 screws) and inspect blower wheel for debris.
May 27, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
196 people viewed this question
Top Dryers Experts
