PRINTER FAULT CANON MP520 SHOWING PRINTER ERROR 5700
    Genius:
  • 1,019 Answers
I,m not 100% sure on this. But A 5700 error on canon printers.
Would mean that the paper sensor has failed, or is not working.
Hope this Helps.
Regards Mike@Compurepair.
Posted on Feb 20, 2008
What is error code 5700?
I have seen this error a few times through the use of our inklink products.
The error 5700 is as follows:
This error takes place when feeding paper
from the ASF after an error occurred in the
ASF cam sensor.
Make sure that there is no paper jammed in the printer and nothing is blocking the paper path.
Oct 15, 2013 | Canon PIXMA MP520 InkJet Printer
Error code U052. I know this has to do with the chip in the ink cartridge. I changed all cartridges and still the same code. I cannot use any function on this MP530 with this error code.
Please remove all cartridges. Using a moist cloth clean the golden contacts on cartridge as well as printer. DO NOT touch nozzle of cartridge. Dont insert the cartridge yet.
Please do this :
1. Remove the power cable from printer. Remove the USB cable that connects printer to computer (remove it from printer as well as computer's usb port)
2. Press the printer power button and keep pressed for 3 minutes then release
3. Now plug in the power cable and usb cable (connect printer to computer) and power on the printer.
Now insert cartridges and see if error goes away.
Do not forget to rate my answer.
Jul 06, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Error code 5700
the error code you have supplied does not provide enough information to resolve this issue.
download and install this small repair utility from Canon for your printer-
http://software.canon-europe.com/software/0038012_0010487.asp?model=
follow the on-screen instructions and it will diagnose your issue and provide a solution.
if this does not resolve your problem reply to this post with the result of the software's diagnosis.
//javaftper
Aug 01, 2010 | Canon PIXMA MP520 InkJet Printer
EROEE 5B00
Resetting Ink Tank Full Error 5B00 Multifunction Printer: power off. hold stop/reset, hold ON/OFF release stop/reset, push stop/reset twice, quickly, then release ON/OFF wait untill LCD display shows ?Canon Idle?,then push stop/reset four times, quickly then push power twice, quickly power off and power on. You can also get the detailed information of all the errors via manaul located at: http://www.retrevo.com/support/Canon-MP520-Multifunction-Printers-manual/id/3124ci177/t/2/
Sep 11, 2009 | Canon PIXMA MP520 InkJet Printer
Error reading GA80 appears on screen for canon printer PRIXMA MP5
Hello Leslie,
Here is a link to the MP520 Support Page:
Canon MP520
Manuals and guides are available on the Drivers & Downloads tab.
Thaks for using Fixya.
Sep 01, 2009 | Canon Office Equipment & Supplies
Error 5700 on lcd screen tried turning it on and off problems not resolved,its only 6months old
5700 is an error in the paper feeder unit, could be a broken gear, or sensor. The only repair is to replace the sheet feed unit. Canon gives a one year warranty, should be repaired at no charge to you. 1800-OKCanon
Jul 09, 2009 | Canon PIXMA MP520 InkJet Printer
5700 in mp520
Canon is fairly standard with their error codes no matter the model. Error Code 5700 basically means the paper sensor is not working properly. If this is the case then you will need to buy another printer. Most repair shops will charge more to fix the old one then you would spend on a new one. Sorry for the bad news. Although, I would strongly suggest you contact Canon Tech Support to validate this information. You can reach them at the number below between 8AM and 12 Midnight EST. Good Luck!
Canon Tech Support: 800-828-4040
Jun 08, 2009 | Canon MP520 All-In-One InkJet Photo...
It never works cuz the screen says error 5700 and wont do anything
Error 5700 is usually a paper "feed" jam.Check the automatic paper feed area to see if any paper is jammed
May 06, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Printer problem
remove the ink case or catridge then reinsert them again they should work unless something is broken.
May 24, 2008 | Office Equipment & Supplies
ERROR 5700 ON MP520 PRINTER
Hello Sir,
Just re-install the printer driver of the software. U have the printer software cd. Just reinstall it. It will solve the problem. ok
Thanks
Good luck
Feb 20, 2008 | Canon MP520 All-In-One InkJet Photo...
871 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
