Question about RCA HD61LPW165 61" Projection HDTV
I need help in setting up my remote for my HD61LPW165 RCA TV\. Some one erased the "input 1" which was direct from the cable.I only rec. through a Magnavox dvd recorder. with no HI def. can you help. Thank you. Curtis Rainwater
  • tawoodlands Feb 10, 2010
    Yes the Input button works i had "Input 1" for cable "Input 2" Blue ray dvd player "Input 3" dvd recorder "input 4" vcr recorder.
    some one has changed the configuration of "Imput 1" it shows no information.
    Please help me set up my TV so that "imput !' will connect to show the cable channels.
    Thank you for your help.
    Curtis Rainwater
  • tawoodlands Feb 13, 2010
    Please help with your solution #2
    Thank you
    Curtis Rainwater
  • 2,335 Answers
Is this a picture of your remote?
If so, I have been looking at the correct instructions for your remote & can help you setup your remote.
But before I give you all the steps for any particular solution, let me see if I understand your problem correctly. Has someone erased the functionality of your INPUT button on the remote (such as with the learning function of the remote for example), so you are unable to press the INPUT button to select the 'input 1' mode of the TV, to allow you to watch your dvd recorder? In this case I can help you reprogram your remote.
Or does the INPUT button work correctly but someone has changed the configuration of the TV so that 'input 1' doesn't appear on your list of input modes? In this case I can help you setup the TV so that it associates a particular connection to a particular input mode.
Posted on Feb 05, 2010
  • RCA Master
  • 5,138 Answers
Do you still have your owners Manual it will tell you what you need to do? Also Press input to see which input you are using?example AV1 av2 av3 etc... Video 1 ,Video2 Video3?
Posted on Feb 10, 2010
  • ladywinn
    ladywinn Feb 13, 2010
    I really dont do wiring and hookups for componets its not that simple explaing how to CK and connect who,what and where, and problem just may lead back to the TV itself, you need to really get afriend to help you or call a repair shop to CK connections and TV.
I have 37LC50CB LG tv. When I turn on with new DTA remote control come up channel # 56-1 and cloud(nothing) on screen Then I...
Your DTA remote cannot turn on your LG TV. Find the red/white/yellow cable that was in the box with your DTA and connect it between the appropriate RCA outputs on the rear of the DTA and the corresponding RCA inputs on the rear panel of your TV. Disconnect the cable connected between your DTA and the antenna input of your TV. Be sure your DTA is on. Turn on your TV and select your DTA as the input source. You may have to press SET UP on your DTA remote to display the set up screen on your TV. Do a channel search and you should be all set.
Nov 24, 2016 | LG Televison & Video
I have audio but no picture, just "Video 1"
You didn't mention tv make / model so thjis is only a guess . The tv may need tuning to find the direct tv cable.
Jan 07, 2015 | Audio Players & Recorders
I just purchased a Sony flat screen tv and need advice on what wires I need to connect my Denon AVR-3300 to it or to the dish cable box? My remote has these options on the remote to listen in...
Your reciever has three digital optical inputs so, what it comes down to is how many thing do you want to hook up and what input/otput do you have on your TV. Best case scenario would be to hook your cable box directly to your TV Via HDMI out, if you have HD, on your cable box to Sat/cable input on your TV. Next best would be using componenet cables for video and digital optical for audio. Last would be RCA(yellow, white and red, from Cable box to TV input. Then, you would connect your TV to receiver via(best) digital optical, or RCA. You can try to patch the video through the reciever using component or RCA to TV/DBS on receiver then out to TV but. alot of times you will lose the video in the transfer and it uses more cables, thus more margiin for error. You would set your TV menu to cable/sat and your reciever to which ever input you choose.
Jul 03, 2011 | Denon Audio Players & Recorders
I need to know how to hook up my vcr to my dvr to record something off of it onto a vhs tape. directv said i need to contact the maker of the vcr & guess what RCA doesn't help with that. but i...
Ok. You connect the vcr to the televison first. Take an rca cable and connect it to the video out of the vcr then connect the other end to the av input on your television. Then take another set of RCA cables and connect them to the RCA av input on your vcr and connect the other end to the output on your dvr.
Now hopefully your tv has another RCA input you can hook directly to the dvr with another set of RCA cables to another one of the dvrs outputs. If not then don't worry about that.
Now make sure the tv is switched over to the av video RCA input the vcr is connected to and turn the vcr on. The vcr should be in input and when it is you will see the picture from your dvr and you will change channels with your dvr remote. You can now record using the vcr remote.
Jun 14, 2010 | RCA VR546 S-VHS VCR
Lost TV remote while on alternate INPUT
Another expert site answered my question. Since there was no INPUT button on the TV, I need to buy an original remote.
Jul 18, 2009 | Directed 434MHZ Remote Control
I have dynex flat screen hdtv,need to hook up jvc dual dvd-vcr recorder to it need direction pls have no knowledge of hooking up this diagram would also be great
  • find the video input 1 in the back of the tv (this video connector yellow + audio red **audio right channel and white left channel) is known as female RCA conector)
  • get a set of rca wires **known as male RCA*** (yellow red and white)
  • find the RCA female conectors Yellow red and white in the DVD call it video (and audio) output
Connect sets accordingly the TV video input yellow conector with video output yellow with the set of wires RCA yellow. Do the same with audio.
  1. second part of this talking is to find and cable splitter (usually three output and one input
  2. find TWO coax cables (this cable is usually a black wire with a connector each side this fits perfectly in the antena input of the tv)
Now connect your cable into the splitter (input) and your two cables in each output, then send one of them into the TV antena conector and another to the DVD coax input.
To watch your TV only select any regualr channel as you do it.
And to record and actually see Your DVD/tape and what you record also. You have to select in your remote control the video 1
ones you get custome to this configuration you can record a channel and at the ssame time watch any second channel selected in the tv.
I hope was clear.
Apr 21, 2009 | Dynex 20" Digital TV
How do I work my camcorder
What brand of DVD recorder? On my Panasonic, I use RCA cables to connect my camcorder to the yellow and white inputs on the front of the DVR. I have to press "input select" on the remote a few times until I get to L2, I think. This is a "line in" sort of setting and it directs the DVR to get its input from the RCA-style cables. Have your camcorder playing something you've recorded in its Video mode. If your TV is on the correct input (mine is called "Video 2", I think), you should see the camcorder image on your TV screen. Now, just rewind to the beginning of your camcorder tape. Insert a DVD-R disk (that's what mine takes) in your DVR. Hit Play on your camcorder and quickly press REC on the DVR remote. Let me know if this doesn't work.
Apr 03, 2009 | Canon ES400V Camcorder
Hi, I have a RCA 27" console color tv without the original remote. It has the RCA cable ports. I bought a Toshiba DVD and it needs the TV to have an external channel which can only be set by remote? Is...
After market remotes only work the most basic of functions - ie., volume channel changes , on/off. They do not get into menus, change inputs, etc. If you can change channels on the console tune it to 3 or 4 and get an rf adapter for your dvd player outputs, set it to one of those channels, and connect to tv antenna input. Ir will work but the picture will not be as good as it can be.
Mar 03, 2017 | RCA G27647 27" TV
Direct TV Hookup
please help my remote has change language and jumping chanel and pause on mute
Sep 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HD61LPW165 61" Projection HDTV Logo
41 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
