Question about Probasics Digit-Ox Finger Pulse Oximeter
Directions on replacing battery - Probasics Digit-Ox Finger Pulse Oximeter
Found manual online and found page with replacing batteries instruction
Posted on Feb 05, 2010
  • melvina Aug 21, 2010
    I have the instructions but I don't know the terminology. I don't a "battery door tab" as referenced in #1 of install/replace instructions. Help!
Van won't start,rapid clicking heard when key is turned. need help/directions replacing starter relay for gmc vandura 2500, 1991
Check battery connections and battery fuse. Battery may not be large enough for the size of your van
Jan 18, 2013 | GMC Cars & Trucks
Where has the replacement battery CR1620 must be placed?
1) Open the main battery compartment
2) Remove the battery tray
3) Inside the battery compartment directly behind the LCD screen there is a small cover about the same size as the CR1620.
4) Remove the cover
5) Replace the battery
6) Replace the cover
7) Replace the battery tray
Jul 20, 2012 | Polaroid Battery Grip for Canon EOS-7D...
The screen said to replace the batteries. When I put new ones in, the screen did not come back on.
One or both of the batteries may be facing the wrong direction. Remove the batteries and check the battery holder for installing in the proper direction. Also, check the batteries you installed to make sure they are at full power.
Jul 28, 2011 | Honeywell Programmable Thermostat Heater
How do I replace the battery in my thermo scan plus ? cna't seem to figure it out Help I need it as my son is ill and the doctor keeps asking for his temp?
Simply press the small recessed button (a small triangle is pointing it ) directly above the battery door with something slender like a ballpoint pen or a toothpick, while pushing the battery door down, away from the thermometer.
Feb 07, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
New heater motor notwork fuse good
Unplug the new motor from the wiring harness and use a jumper wire from the new motor to the battery. If the new motor won't run with direct battery voltage, it is faulty and should be returned to wherever you bought it for replacement. If it works with direct battery voltage then you may need to replace the heater relay.
Dec 18, 2010 | Chevrolet S 10 Cars & Trucks
Directions to replace the battery in a jet3 power
Unplug the joystick cable under the seat remove the seat if on a post lift handle on right side under seat and lift seat off post if not look for release levers behind front seat post and seat will rotate backwards to give you access to the batteriesdisconnect battery cables and install as on old batteries to new ones and reinstall Hope this helps
Aug 02, 2010 | Jet 3 Ultra Power Chair
How to replace battery for a Latitude X1
The Dell Latitude X1 laptop has a 53 WHr 6 Cell Lithium Ion Battery. Your safest bet is to purchase a replacement battery from Dell directly, in order to avoid confusion and mismatched parts. The Dell Part number for your battery is Dell Part# : 312-0342. The Manufacturer Part# : Y6457. The cost is 135.99 from Dell directly. While you may be able to find a battery elsewhere for cheaper, it is not recommended.
Good Luck,
NOLA Tech
Jan 28, 2010 | Dell Latitude X1 Notebook
Replaced the battery and followed the directions
I have a Chrysler Sebring I can figure out which screws to take out to replace the bulb on the headlight on drivers side.
Jan 14, 2010 | Buick LeSabre Cars & Trucks
I got low battery sign. replaced batterys bith in
round watch style batteries will almost always go with the tapered side touching the tabbed end
Sep 25, 2009 | Omron HEM 650 Wrist Blood Pressure Monitor
When should I replace my backup battery?
The back up battery should be replaced immediately upon seeing the message "Backup Battery Very Low - Your back up battery is very low or missing. Data loss may result from failure to replace the battery very soon. Consult the manufacturer's instructions for directions on replacing or charging the backup battery." Warning: It is important to note that the back up battery in the MobilePro 900 is not rechargeable, thus, to prevent data loss, it is important to change the back up battery immediately when this message is displayed.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Probasics Digit-Ox Finger Pulse Oximeter Logo
808 people viewed this question
Top Probasics Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Probasics Health and Beauty Expert? Answer questions, earn points and help others
