Question about Motorola Mobility V600
Texting when i'm typing a text the phone gives me a list of words i can say, i don't want that i want just to be able to type without it predicting what i want to say.
    Problem Solver:
  • 7 Answers
Turn off predictive text input....
Posted on Feb 23, 2008
How do i set predictive text on samsung m8800
Follow the below mentioned method, also see the advantages of T9 dictionary :
1.
Check your manual to learn more about text messaging
Check your cell phone's user manual to see if your cell phone has the T9 function. While most new phones contain this function, if you have an older phone, you'll want to check to be certain. Look under the Text Messaging section in the manual.
2.
Enable T9 for easy texting
Enable the T9 setting on your cell phone. Some phone require that you enable this function. Check under your cell phone's Options menu and also under the text messaging options. Depending on your cell phone, you may be able to set T9 as the default method of text input or you may have to toggle the text input functions to choose T9 for every text message. Generally, the toggle key will be your asterisk key. Again, check your cell phone's manual for more information.
3.
Choose your language and other preferences for T9 texting
Pick your T9 preferences. Your T9 function may allow you to set several preferences. The most typical preference is language, and you also may able to set whether you want your cell phone to use T9 for word completion only or to predict which word you will type next. You may also be able to set the "delay" - the amount of time before your T9 function changes the letters you are typing to what it thinks they should be. Again, try your Options or Preferences menus in the text messaging module of your cell phone or consult your cell phone's manual. You will want to try different set-ups to determine which works best for you and your style of text messaging.
4.
T9 gives you more then one way to select the right word for your text message
Type your text message, toggling for T9 if your phone requires it. Once the T9 function is enabled or toggled, simply type the word you want. Do not be concerned if the letters do not appear correctly when you first start typing the word - they will correct themselves when you finish typing the word, as long as you spell it correctly. Your phone may offer a drop-down menu with word suggestions as you type. If your word shows up, scroll down and select it if you wish or continue typing your word. If your phone does not offer a drop-down menu, and the word that you type is not the word that you wanted, press the Down arrow key on your cell phone and another word will show up. Keep pressing the Down arrow until your word shows up. When you have the word you want, use the space function to continue typing.
5.
Add your own text expressions to T9
Add your own words to the T9 function. The T9 function comes with an extensive dictionary, but you can add your own words or abbreviations, too. Again, you may have to dig around the Options or Preferences section in the text messaging module of your phone. Once you find it, simply type and add your own special words or expressions to have them at your fingertip when you text.
Use T9 to express yourself in your own unique way!
Jun 12, 2011 | Samsung M8800 Pixon - Unlocked QuadBand...
Blackberry texting prediction problem
what exactly is the text problem...here are some general solution for text prediction
  1. options > auto text > edit > clear the with field ( this solution is used for instance if you keep type hr and it comes out as hour and you want to change that)
  2. options >auto text > new > enter word ( used to add a new word to auto text )
  3. options > SMS > disable auto text : YES ( used to disable auto text or test prediction )
Sep 11, 2010 | RIM BlackBerry Curve 8520 Smartphone
How do I change to simple text type every letter and not joined
I may be wrong but your talking about predicted text right? Where you type a letter and it comes up with a word instead of the actual individual letter? - you need to change your settings in text, you can simply hold # or * on your keypad (you should see a little icon somewhere saying T9, this means predicted text) after holding one of these buttons for about a second or two, it should disappear, allowing you to type without predicted text on.
Hope this helps,
Jake
Jun 30, 2010 | Computers & Internet
When I text I get an underline and I can't get anything but the first letter of a 3 letter set on the keys
You must disable your Predictive text option, T9® predictive text mode allows you to type words with only one keystroke per letter, and the phone interprets what word you want. For example, to type the, press 8, 4, 3. To enable/disable T9® predictive text mode, select Options. Scroll to and select Prediction on or off.
Oct 22, 2009 | Nokia 2610 Cellular Phone
When I start to type a words automatic words come up
I assume you mean when you are writing a text that this happens?
This is predictive text (t9),where the phone automatically tries to predict the word which it thinks you intend to type,
It has its advantages in that it can make typing a text faster but it does take a while to get used to and some people just prefer to text by the method they are already used to,
You can disable the predictive text if you wish and use normal text for your letter input,the option will be on your phone in the settings,if you are unable to locate the option reply back with your make/model of handset and I will tell you how to disable it
Sep 07, 2009 | Lands Phones
How do I switch on predictive text
In settings/general/language - make sure that the only language ticked is English - then you can use the *A/a button
Jan 28, 2009 | Sony Ericsson T303 Mobile Phone (Shadow...
Predictive text
open messages->new message->'options' or 'more'->dictionary->off.
Oct 31, 2008 | Cell Phones
Texts random letters and then sends on it's own
have you tried to change the TEXT T9 from iTap to just ENGLISH
Dec 29, 2007 | Motorola Mobility RAZR V3
Predictive texting
I understand that u r unable to write message according to ur wish, Ur t9 dictionary is activated so pliz turn it off definitely u will  b able to type proper text.
Oct 21, 2007 | LG KG320 Cellular Phone
Open Questions:
See all Motorola Mobility V600 Questions
Motorola Mobility V600 Logo
98 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
