A water mess in my 8 year old Aprilair 550 humidifier. The water goes into the pad and is blown right through and it splashes on the inside of the unit wall and goes down to the floor. The drain that is connected to the unit cannot catch all that water and it is not designed for this messy situation that would harm the furnace if I were to use the unit, which obviously I am not. The pad is the appropriate one and is installed properly with the black mark at the top. The unit is connected to the warm air duct and warm air goes through the pad very rapidly but this has never been a problem. Ihave the original bracket for the pad including the top tray which distributes the water accross the pad. There is a yellow plastic fitting to which the water supply is connected. Before installing the pad I shut down the furnace and the unit itself. As soon as the air starts to blow the the water goes right through the pad in large drpos ( as opposed to a mist).
  • bertrand_roy Feb 05, 2010
    There is no mechanism at all as you have described, to control the airflow.
  • bertrand_roy Feb 08, 2010
    Tonight I will try to check out your idea and if necessary change my old style humidistat.
    It has also been suggested to me to measure the rate of inflow of water. It should take no more,no less than 5 minutes to produce a gallon , according to an Aprilaire 1 800 number . Also, it should take no more than 6 minutes for the water to go through the pad. I have yet to take these measurements. Do you think that this makes sense ? Consider that this the first time I have had this problem.
    The Saints can do no wrong!!! Hurray for Nouvelle-Orléans.
  • 767 Answers
If you put the right pad in an aprilaire replacement pad the water should be running down the inside of the pad and never make it throught the outside when the blower is running. Make sure the top and bottom parts of the bracket that holds the pad in are clean on the top bracket the holes are down the center and have a "V" grove in the make sure the groove is clean so the water can run down the center of the pad. Also make sure the pad is tight to the bracket there is 2 slots in the side bracet the hold the top bracket tight to the pad make sure that both side click into the groove on the side bracket you may have to push the top down hard to get the side into the groove.
Posted on Feb 08, 2010
    President:
  • 2,468 Answers
Your humidity level control is set way too high then or the control is defective,is it the old style or the newer electronic read-out that shows you the humidity level,if not change it over and this will solve your problems
Posted on Feb 06, 2010
  • 43,501 Answers
It sounds like you have too much air flow through the humidifier...Is there a chance that you bumped a damper when changing the pad... obivously you have way more than you need and actually you just want a small amount to "bypass" through there... There should be a small arm sticking out5 the side of the duct from the supply to the humidifier, turn that back a bit to slow down the air flow.. Stright with the pipe is full on and perpendicular to the pipe is full off.
Heatman101
Posted on Feb 04, 2010
Have an HE225A, B By-pass Flow thru humidifier about 9 yrs old. Just change the antimicrobial pad with recommended Aprilair 110/220 and when the furnace comes on, there is a loud, hum-like, vibrating noise...
Make sure the new pad you installed is in the right position. The pad is marked with a black dot about the size of a quarter. This end should be up for proper water flow through the pad.I fwater flow is being restricted at the pad the vibrating nosie that you are hearing is the dry portion of the pad vibrating agaist the platic housing of the humidifier. This noise stops once the pad has absorb enough water in this area of the pad.
Jan 23, 2011 | Honeywell HE220A1019 Whole House...
I just moved iinto my new home. I have never owned a home with aprilair 560 unit. I just got it fixed I hope. But I put a new water filter in monday the 27th. How often should you replace it. ...
It is a bypass humidifer the pad in it should last a couple of years, the water runs over the pad and air pulls moisture off the pad. Putting it into the home. Make sure the damper is open for proper air flow.
Dec 30, 2010 | Aprilaire 550 Humidifier
Water is blown through the pad and ends up on the floor.
I would try a new pad and make sure you are using the aprileaire brand only. not a aftermarket pad
Feb 05, 2010 | Aprilaire 550 Humidifier
The unit makes a water mess which seems the result
Hi is the tube at the bottom blocked or can you turn the flow down going in
Feb 04, 2010 | Aprilaire 550 Humidifier
Water leaking from bottom of 550 aprilair humidifer
Hi they should be a hose going to a drain in the floor there are insrtuctions on the wed just google the make and model and you can down load them
Dec 28, 2009 | Aprilaire 550 Humidifier
My Aprilaire 560 doesn't shut off even if the blower is off.
My Aprilair 560 turns on and off repeatedly.Making a loud banging sound.Changed my water valve worked 1 day and started agin.
Dec 20, 2009 | Aprilaire 550 Humidifier
Aprilair 550 water running but not trickling through filter
it hard to see make sure the filter is in the upright position i believe they mark it with a black strip. you want it so the little v's are catching the dropplets or water otherwise thats normal but make sure you change it every season.
Nov 21, 2009 | Humidifiers
Power is off to aprilaire 550
The Aprilair Hum. donot have a restart button. All there is there is just a 24VAC Solenoid that opens and lets the water flow throu a tube. Check your humidistat, check your wire going to the furnace control board and also your current sensing relay if you have one.
Feb 01, 2009 | Aprilaire 550 Humidifier
No water to my Aprilair model 550.
Some sump pump have a safty switch that will not let the hum. come on if the tank is full of water, I,m not sure if this is the type that you have but make sure that the pump is pumping water. Also your humidistat have an internal switch that it should be set to bypass not to power Note: some humidifier have their own power supply the 550 dose not
Jan 26, 2008 | Aprilaire 550 Humidifier
Heating & Cooling Logo
41 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
