Question about Hoover S3755 WindTunnel Bagless Canister Vacuum
My agitator roll won't roll when on a carpet. It does roll if it's on a hard surface.
    Problem Solver:
  • 13 Answers
Your belt is stretched. The drag from the hard floor is not enough to stop it, but the carpet is. Change the belt, and all should be well.
Posted on Feb 04, 2010
Vacum has suction, but won't pull debris from the floor
The vacuum may not be set for use on carpet.
Jan 19, 2017 | Vacuums
Why does my eureka air speed vacuum not work when in floor mode?
There is an adjustment for carpet and for hard surfaces. Have switched it from carpet to a hard surface. When on carpet it sets up higher on a hard surface it should set lower. If it is to low it work properly either.
Oct 16, 2016 | Eureka Vacuums
How to repair windtunnel hoover agitator that will not turn
Likely a broken belt. Also check the agitator brush roll bearings (in either end under the end caps) for hair, strong, thread, etc. as this will make the brush roll harder to turn and wear/break belts prematurely. If all these check okay, then observe the tensioning roller that causes the V belt (runs from the idler pulley to the brush roller) to be sure it is swinging down when the handle is released to hold tension on the belt, causing it to rotate. These tensioning rollers can break, but often are locked into the "Bare Floor" setting without the user noticing. Slide the carpet brush roll selector (located on top, next to the floor height slide adjustment) back and forth and make certain it is all the way into the "Carpet" setting to allow the tensioning roller to engage. [Note: The tensioning roller is always retracted (in the neutral or off position) when the handle is in the upright position. You must release the handle to allow this tensioing assembly to engage.]
Sep 05, 2014 | Hoover Model U6485900 Upright Vacuum...
How to Turn off beater bar
Hi there, it's Jack at Dyson.
DC44's brush bar is engineered to rotate on both hard floors and carpeting. The brush bar includes stiff nylon bristles to agitate and remove stubborn dirt and pet hair from carpet, and anti-static carbon fibre filaments to remove fine dust from hard floors and crevices.
For this reason, the brush bar is designed to run on all floor surfaces when the machine is in use, and cannot be turned off. You might find our Getting started guide useful:
I hope this answers your question, but if there's anything else we can help you with you're welcome to contact our experts directly on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Aug 21, 2014 | Dyson DC44 Animal Handheld Vacuum Cleaner
Can not select Hard floors
Hi Antony,
From your question, it sounds as if your machine is working correctly. When you select 'Carpets', the brushbar will rotate to agitate trodden-in dirt, debris and pet hair from the carpet pile. However, when you select 'Hard floors', the brushbar is designed to shut off to protect delicate floor surfaces and rugs.
You may find it helps to refer to the user guide supplied with the machine. In case you don't have this to hand, you can download a copy here:
http://support.dyson.co.uk/medialibrary/Files/Dyson/Support/downloads/UK/floorcare/Manuals/dc33_uk_manual_260710 pdf.ashx
I hope this helps - if you have any further concerns about your machine, please call our Helpline on 0800 298 0298 (UK), or 1-866-693-9766 (US) so we can provide assistance. You can also find the answers to questions on using and maintaining your Dyson vacuum by visiting http://www.dyson.com and clicking 'Support'.
Best wishes,
Jack
Dyson Online Customer Support
Mar 08, 2012 | Dyson DC33 Bagged Upright Vacuum
My Vaccuum Hoover U5763-900 wind tunnel Twin Chamber is barely used. Belt is in tact and agitator is not worn. Nothing clogged. Agitator spins fine off the ground or on hard surface or flat rug. Once on...
It's because the belt is stretched out and has lost elasticity. It can turn the brush in the air but is not tight enough to turn it in the carpet. Replace the belt at least once per year even if the vacuum is never used.
Feb 09, 2018 | Hoover U5753-900 WindTunnel Bagless...
Does the vacuum lose suction when in the floor mode if the belt is broken?
To put it simply, no. By floor mode I'm assuming you're stopping the brush roll from turning so that you can clean hard surface floors instead of carpet. When the brush roll doesn't turn you do lose agitation which vibrates the carpet so that the dirt is more easily picked up by the vacuum. But you don't lose suction because the brush is not turning.
May 18, 2010 | Eureka Smartvac 4870 Bagged Upright Vacuum
Hoover WindTunnel Self-Propelled V Belt
when you released the end to slide the new belt on it allows the tension roller to slide into the wrong position. Remove the top so that you can see the roller, at the left side of the roller mechanism there is a screw, loosen it enough to allow the roller to return to the correct position.
good luck
Mar 23, 2009 | Hoover U6441-940 WindTunnel Bagged Upright...
Brush Roll belt won't engage on WindTunnel self-propelled
When you had the brush roll off, did the ends turn freely? If not then the brush won't turn and the belt will just slip. You would have to replace the brush roll if either of the ends are frozen. Other then that you would have to remove the top cover to see if there any broken parts, there is a spring loaded asm, it has a black wheel that will push the V belt when it is in the carpet setting and the handle is in the down position, it could be jammed so the roller is stuck.
Jul 16, 2008 | Hoover U6437-900 / U6439-900 Windtunnel...
Hoover S3755 WindTunnel Bagless Canister Vacuum Logo
245 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
