Question about Sub-Zero 690 Side by Side Refrigerator
Subzero 690 flashing EC and service
The fan went out, so I installed a new one. It flashes EC and service. I've reset it by pushing the bell button and that didn't work. I can turn unit off and back on and it will go away for about 4 or 5 days, but always go's back to EC and service. It seems to be always running. Can you help?
  • Anonymous Mar 26, 2008
    I have the same problem. A tech cleaned the coil and 3 days later it happened again. I shut off the breaker and reset it and its been good for several months now its doing it again. The tech says it must be in the brain box and will cost $375 to fix. I guess I have no choise.
If you replace the fan and clean the coils, and the refrigerator STILL does not cool, then contact SubZero or a service provider for an evaporator coil replacement.  Units manufacturer before mid-2003 had copper+aluminum coils that would corrode and allow all of the coolant to escape.  The (should be warranty) replacement is all aluminum.
Note the freezer does not have this issue due to the lack of liquid water.
Posted on May 12, 2008
  • 26 Answers
EC means extended run time. Find a subzero authorized servicer and he will probably need to replace the refrig section evaporator assembly.
Posted on Mar 31, 2008
    President:
  • 1,314 Answers
Try cleaning the conderser coils and check the codeser fan
Posted on Feb 20, 2008
How do you install or change the water filter.
If you model Sub Zero 690 has a filtration system this is what to look for. Thanks John Tripp Appliance 911
Contact Me Here
Sub Zero 690 Service Manual
Sub Zero Installation User Manual
CONTACT INFORMATION Sub-Zero Customer Service:
800-222-7820
Website: subzero.com
E-mail Address: customerservice@subzero.com
Jul 07, 2014 | Sub-Zero 690 Side by Side Refrigerator
How do you reset the subzero unit after cleaning coils
Hold the alarm pad for 15 seconds. Then when it comes back call an authorized servicer.
Jul 02, 2014 | Sub-Zero 632 / S
Is it possible to clean the condenser with low velocity air compresser . My sub zero 690 side by side fridge flashing VACUME CONDENSER SERVICE.
Yes but this will create a dusting nightmare for the rest of the house. By just cleaning the condenser is not enough for the computer has no knowledge of said act. You must rest the computer after cleaning, your model has a picture of a bell on the panel of the control. Push and hold that bell for 10 seconds, you should hear a beep and the service light will disappear. If this returns, this means either the condenser is dirty or the computer has detected that it takes too long to reach your desired temp. But reset first, less work and see what happens.
Good Luck
Nov 02, 2013 | Sub-Zero 690 Side by Side Refrigerator
My Sub-Zero is flashing error code 36. What is this?
Diarmait --
Technical Service Manual for the SubZero 600 series can be downloaded at:
[https://docstore.fedex.com/subzero]
Username=subzero
Password=subzero
Write back if you still need help.
-- SWT
Aug 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
Sub zero ref 690 s model with error code ec 50 what is that
EC code is on with a flashing service light . Is this a problem that I can fix on my own?
May 26, 2010 | Sub-Zero 690 Side by Side Refrigerator
I have a sub zero 690 series refrigerator. The display shows codes 34 01 and then EC 24 Any idea what this means? Thank you
DEFROST UNDER HEAT IS THE CODE DESCRIPTION. IF YOU HAVE A BELL BUTTON HOLD IT 15-20 SECONDS TO CLEAR. IF THERE IS NO BELL BUTTON POWER OFF THEN POWER ON TO REST AND SEE IF CODE COMES BACK AND THEN CALL FOR SERVICE. 1-800-222-7820
Apr 24, 2010 | Sub-Zero 690 Side by Side Refrigerator
My subzero 650 is flashing EC 24?
Hold alarm key for 15 seconds to clear control and clean the condenser. If the service light comes on call for service as you most ;likely have a leak.
Jun 20, 2009 | Sub-Zero 690 Side by Side Refrigerator
Sub zero 690
Call the factory at 800-222-7820.They will give you a list of the authorized servicers in your area. It sounds like the evaporator and the parts will be covered by the year 6 through 12 parts only warranty. If you are in Westchester County $625 sounds right. The vacuum condensor flashes when the compressor has too long of a run time and will reaapear a day or so after it has been reset. I assume the tech made sure the condensor fan was running and the condensr is actually clean.
Nov 30, 2008 | Sub-Zero 690 Side by Side Refrigerator
Rhino, this is yet another simple fix. You need to call subzero and let them know that your ref section is not cooling properly. 9 out of 10 times it will be a problem with the evaporator coil needing replacement. Sub is aware of this issue and usually picks up the tab for this repair.
Mar 26, 2008 | Sub-Zero 632 / S
690 SubZero Side-by-Side Fridge
You need to reset the controller open the door and press and hold the "Bell" looking symbol for 15secs then release it should go away let me know if that worked
Jan 26, 2008 | Sub-Zero 690 Side by Side Refrigerator
Sub-Zero 690 Side by Side Refrigerator Logo
2,000 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
