Question about Achiever Office Equipment & Supplies
I have a achiever personal paper shredder 5 sheet cap. I have a broken gear need a replacement part.
SOURCE: paper shredder vf1000
I feel for you too, I have the same problem, You have to order the gear at Royal.com
Posted on Jan 19, 2008
fellowesrep
  • 102 Answers
SOURCE: gears
If you are having trouble finding replacement gears check out this. http://www.rushgears.com
Posted on Feb 25, 2008
fellowesrep
  • 102 Answers
SOURCE: paper shredder gear is stripped.....replacements?
Best bet is Royal Customer Service at 888-261-4555
Posted on Mar 02, 2008
  • 329 Answers
SOURCE: Office max paper shredder
You need to find out who made the shreddr, Fellows, GBC, etc. parts are available to brand name machines...
Posted on Jun 24, 2008
SOURCE: Where can you purchase repair parts? the teeth
I appreciate your intent to help solve my printer problem. However, I do not think it should require me to pay a fee to get an address to locate a Company to obtain a replacement part for my Achiever shredder.
Posted on Oct 04, 2009
DX-PS10MC gear broken
Might have to go to eBay or Gumtree.
Mar 05, 2014 | Dynex - 10-Sheet Microcut Paper Shredder
The shredder has started making a whining sound under heavy load - say 10 sheets. It is 5 years old and has had light home usage.
Do you use shredder oil in your device? Even under "light home use" a shredders life is not easy. Ten sheets is a lot of paper to cut.
I use a cross hatch cutter design and I never put in more than 5 sheets and I use shredder oil. Find this product at a FixYa.com advertiser, Staples, Best Buy, Office Depot or any other fine retail outlet.
Thanks for your interest in FixYa.com
Jan 31, 2011 | Achiever CCS5000 Shredder
I have an achiever heavy-duty crosscut shredder that I purchased in 2002. Since that time I have actually used the shredder around 5 times. The shredder turns on, shred for about 2-3 mins., then it stops....
does it finish the sheet of paper then shut off , or does it stop halfway thru the paper?
unplug the unit , open it up and see if theres staples or junk jammed in the cutting wheels/gears
there supose to turn off once its finished with the paper and turn back on when the next paper is inserted , theres a lil sensor that turns it on and a limit switch that turns it off
Jul 11, 2009 | Achiever CCS5000 Shredder
BROKEN GEAR
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Dec 31, 2008 | Aurora Electronics Aurora 5 Sheet...
I need a manual for my shredder
the overload beeper want cut off and there no paper in it
Aug 27, 2008 | Achiever CCS5000 Shredder
Tech Solutions shredder
It sounds like you may have a gear with a broken tooth you should contact the manufacturer to get more info. Usually when this is the case it will shred good for only a few revolutions and then reversing backs the gear up to a position that allows it to turn the cutters until it once again reaches the area where tooth is missing.
Mar 11, 2008 | Winsource Tech Solutions TS-4500 Cross-Cut...
Achiever Shredder CC5-1500
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Dec 06, 2007 | Achiever CCS-1500 Cross-Cut Shredder
Achiever Shredder
Dec 02, 2007 | Achiever CCS-1500 Cross-Cut Shredder
198 people viewed this question
Top Achiever Office Equipment & Supplies Experts
quennie732
ray gallant
Are you an Achiever Office Equipment and Supply Expert? Answer questions, earn points and help others
