Question about Microsoft Xbox Console
Got windows 7,internet is dymanic,to arris cable/dslmodem,to a d-link router,go to test x-box live connection,says there is a problem with connection,please help
  • 360 Answers
I am guessing that you are connecting your xbox to your computer for an internet connection. If yes, then you can not use just any ethernet cable to connect it to your computer, you have to use what is called a "crossover cable". This type of cable has 2 wires that are in different positions than a regular ethernet cable. If you were to connect your xbox directly to your router or modem, you would use a regular ethernet cable. If you are already using a crossover cable, then you have not set up your ICS (Internet Connection Sharing) correctly on your computer. Worthy of mention is also that you need to use "port forwarding" to open ports for a non-strict connection with xbox live. I hope this helps you, if you have further questions regarding this issue, feel free to ask.
Posted on Feb 04, 2010
Windows Vista won't let me config Arris tg862g router options
hope this help you.
you need yo reset the router, there is a reset button on the wireless router that you need to click for 10 sec after that, connect everything to your PC and follow instructions on this link bellow.
https://bendbroadband.com/residential/support/detail.asp?kb=100196
May 06, 2017 | HP Computers & Internet
Setting up xbox live
ARRIS modem is a phone/hsi modem. What youll need to do is first turn power off on xbox then unplug the power supply from the back of the Arris modem and unscrew the coaxil/cable wire from the back of the modem for about a minute. Then plug in the power cord to the modem wait another half minute then screw in the coaxil/cable wire....wait for the lights to come back on make sure the online light is solid green not flashing and follow the ethernet cable (Looks like a thick telephone wire) and make sure you have that ethernet cable seated/snapped into the ethernet port on your xbox. Then turn the xbox on and do connection test. FINISHED..IF it's still not working make sure you have Internet service from your provider and if using a router bypass it at first see if you can get onto xbox live without the router. If you can with just connected directly to your arris modem without the router involved. If you do want to use wireless contact your router manufacture and or xbox support at 800-469-9269.
Apr 24, 2010 | Arris Touchstone 450a (CM450) Modem
Router cannot connect to the internet.
Turn everything off:
Cable modem unplug the power to the modem if it has a battery remove it.
Router unplug the power to the router
Shutdown any and all computers connected to the router
Turn everything on in this order:
Cable modem wait until all the lights are on but the internet act light
Router wait until the lights goes through it's test cycle and the internet light (wan) is on.
Boot up the computers one at a time after the first computer is fully loaded go to the next computer
Hope this helps
Terry
Feb 27, 2009 | Arris Touchstone 450a (CM450) Modem
ARRIS Modem + D-Link router = no internet
when you are on Cable Internet with a "modem" only connected directly to the computer, what the ISP see is the computer's MAC Address (command prompt -> type ipconfig and hit enter).
put a router (which has it's own MAC Address) in-between and the ISP wont let you cause it sees the router not the computer.
check physical connection: cable modem -> router -> computer(hard wire for this troubleshooting)
access the d-link gui and locate the “Clone MAC Address" button (supposed to clone the computers MAC Address - verify if it's the same), save settings & reboot the router.
Jan 26, 2009 | Arris Touchstone 450a (CM450) Modem
Connect internet via ethernet
to use dhcp with several computers, you need to have a box that allows the dhcp mode and which is configure to goes on
Jan 17, 2009 | Apple Power Mac G5 Desktop
I cant get out to the internet when I connect the netgear router.
Be sure that your cable company has enabled your internet. Power down the cable modem, power down any routers and computers. Start cable modem first, after internet connectivity is indicated, power up the router (if you have one) and then power upi the pc
Dec 27, 2008 | Arris Touchstone 450a (CM450) Modem
Connecting xbox live to my d link 1005d
Is the PC's connected to the D-Link able to browse the Internet? Sometimes the MAC Address will bind to certain IP's and must be cleared out when the Router is replaced. Please unplug the power to the router, X-Box and Cable or DSL modem. 1st plug in the power to the DSL/Cable modem until the "Ready" light comes on. 2nd plug in the power to the D-Link Router, wait 30 seconds then plug in the X-Box, power on and test. If a computer plugged into the D-Link will browse Internet then this is the solution to your problem.
Adam
Oct 26, 2008 | D-Link DGS 1005D (DGS-1005D) 5x1000 Mbps...
Connecting my arris modem to x-box live
I have an Arris cable modem and use Xbox live. They work very well together. Most ISP's will only allow one active device at a time. When you switch between you cable modem and your Xbox you need to use a pen and press the reset button on the arris every single time you switch.
Jun 22, 2008 | Arris Touchstone 450a (CM450) Modem
Can't seem to hook up D-link router to my Arris cable properly
hello!
-- who is your internet service provider
-- what is the operating system of your computer?
-- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure your computer is directly connected to the router
Step 1: Shutdown the computer.
Step 2: reset the router while power on then Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and configure the router settings
Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
note:
configuring the router settings will depends who is your provider. if your isp is dsl you need to configure your ISP username and password on the router. if your router is a cable no need to change any settings on the router. it should automatically work
May 29, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Microsoft Xbox Console Logo
27 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
