Question about RIM BlackBerry Pearl 8100
Trackball on 8100 pearl
Will not scroll down. ive tried everything..what can i do?
  • 5 more comments
  • Anonymous Mar 03, 2008
    I want to be able to Clear all Pictures without deleting one at a time.
  • Anonymous Mar 05, 2008
    power off
  • tbone1031 Mar 06, 2008
    wont turn on .Led blinking 4 times
  • Anonymous Jun 12, 2008
    every now and then my track ball on my blackberry doesnt want o work. how do i fix it when it does happen. i can be reached at shade_pheinox@yahoo.com
    robert/shade
    every now and then my track ball on my blackberry doesnt want to scroll down. how do i fix it when it does happen
  • njmichelle Mar 15, 2009
    My trackball won't scroll down...every direction but down. Also, every evening when I am asleep, by Blackberry erases all of the phone #'s in my history as well as any text messages. Why is this happening???
  • ajakiu May 11, 2010
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 43 Answers
Well, you could try pushing down on the "pearl" and scrolling down. if not, get some compressed air, and blow around the little chrome rim part. if all else fails, you can take it out. BE CAREFUL DOING THIS THOUGH.
here is how to do it.
insert your nail or something small that wont scratch it on the TOP part of the little chrome rim. the top is because its the only part without a clip to hold it in place.
try to SLOWLY wedge it out, applying pressure little by little. you'll know when youre doing it right.blow compressed air there, but make sure to keep the actual pearl assembly parts in place. they can come out, but it is a very very hard process to put it back together should it come apart. place the rim back, remember to put the part without the little clamp ON TOP, pointing towards the screen.
hope i was helpful! dont hesitate asking me anything else!
Posted on Feb 26, 2008
  • 113 Answers
Best option is to replace it.
www.blackberry8100parts.com they have them for $9
Posted on Apr 23, 2008
Hi, Help PLease, My blackberry Pearl 8100 , scroll button not working in left direction!!
it can be solved only by opening the trackball and removing the dust in the trackball....it is the most common problem with blackberry mobile... u can be able to see the repairing procedure of the track ball in the youtube videos..
Mar 13, 2010 | RIM BlackBerry Pearl 8100
BB Pearl's trackball scrolls but it will not
There is probably some corrosion underneith the center dome cover on the select button. It is held on by some tape. Simply remove the track ball then remove the center select button dome and clean/scrap both sides with a small screwdriver and reinstall. You will probably have to retape it down. This should get you up and running in no time.
Dec 14, 2009 | RIM BlackBerry Pearl 8100
My pearl on my balckberry wont scroll down
Hi, Trackball doesn't work if you have not selected the sensitivity. To select the sensitivity, kindly follow the steps: 1. Select menu. 2. Select option. 3. Select screen/key board. 4. Scroll down to find horizontal and verticle 5. Select horizontal-100 and verticle-100. I Hope it helped you.
Nov 25, 2009 | RIM BlackBerry Pearl 8100
Trackball will not go down. Pearl 8100
It has been in my experience with the 8100 that if you can't scroll a certain direction, there was debris on the roller preventing it from registering the roll. Turn the phone off, press down on the track ball (as if to press a button) roll the ball down (in your case). This may help dislodge whatever debris is caught in the roller. It has worked for me several times. You may want to try and clean the trackball as well with some rubbing alcohol and a q-tip.
If it were a software problem, then I would imagine you turning off the phone (battery pull) would clear this up anyways.
Best Regards,
Bill
Sep 02, 2009 | RIM BlackBerry Pearl 8100
My Rollerball won't scroll down - tried everything.
Cause: The sensitivity of the trackball/trackwheel might be less Faulty Hardware Resolution: Increase the sensitivity by following procedure Option -> Screen and Keyboard -> Horizontal Sensitivity and Vertical Sensitivity to 100 If not working check with the service center
Aug 11, 2009 | RIM BlackBerry Pearl 8100
Tracking ball is limited in movement. I can scroll across, but not down.
Cause:
Faulty Hardware
Resolution:
Aug 10, 2009 | RIM BlackBerry Pearl 8100
Trackball on 8320 won't scroll down
the better way is to go to a servicing center
Jul 19, 2009 | RIM BlackBerry Pearl 8100
Can't scroll down with track ball. Pl. suggest
Clean your trackball regularly by slightly dipping a cotton swab into rubbing alcohol and using that to clean your trackball.
Unfortunately, dirt and oils on your fingers wear out the trackball over time, causing it to behave in unpredictable ways.
Jun 26, 2009 | RIM BlackBerry Pearl 8100
Lost the Trackball any other way to scroll
no other way to scroll but the trackball it's self only costs 2-5 dollars to replace Amazon even has free shipping.
Mar 30, 2009 | RIM BlackBerry Pearl 8100
Blackberry rollerball
Hi guys I have the solution. I think all your trackballs are stuck. If you cant move it, take the silver ring off with a knife, take off the trackball and put rubbing alcohol on it wth a Q - tip until it works. Can some1 help me? My problem is titled My blackberry pearl wont load up.
May 16, 2008 | RIM BlackBerry Pearl 8100
RIM BlackBerry  Pearl  8100 Logo
306 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
Andrew Wright
David
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
