Question about Fujitsu 24C1 Air Conditioner
WHICH IS BETTER SANYO OR FUJITSU, AIR CONDITIONER WITH TEC INVERTER?
    Problem Solver:
  • 10 Answers
I would suggest fujitsu.
Posted on Jul 15, 2010
I have a fujitsu inverter asta 24jcc every eight seconds the red and green light flashes about five times
Hi Ken,
I hope the following link will help you?
Good luck
http://errorcodeairconditioning.blogspot.com.au/2010/10/fujitsu-air-conditioner-error-codes.html
Dec 13, 2014 | Fujitsu Heating & Cooling
My fujitsu halycon inverter is dripping water in the house. How do I fix it?
First checking out the drainage that comes out is not blocked, and secondly need to open the air conditioner and clean the Wading and finally the third and final case to see if the machine has Freon.
Sep 20, 2011 | Fujitsu 24C1 Air Conditioner
Our Fujitsu inverter although on 18 degrees and "Cooling" on high is not cooling at all. Just feels like a fan on high
First advise not to keep in 18 degree temp.(Please ask me why in separate question)
You will get better cooling in 23 degree itself. There are many reasons for not getting cold.
1. Dirty filter and coil. Clean it. 2. Check compressor is working. 3.If working, check for gas pressure. 4. If gas pressure is good, check out door fan motor working well. 5. And also clean your condenser coil.
Helpful?
Jan 03, 2011 | Fujitsu 18C1 Air Conditioner
Fujitsu Inverter ASTA09LCC Where is the drain tube located? The air con is leaking water and I believe drain may be blocked.
It is directly behind & thru the wall to outside next to the refer. piping.Everything goes outside thru a 3" hole. tube should b there.Blow it out.good luck
Mar 12, 2010 | Fujitsu 18C1 Air Conditioner
I have a sanyo duted split and comes up with code ho2..
have a certified tec try to unstick compressor likely new compressor
Jun 15, 2009 | Sanyo CMH2472 Air Conditioner
Aou18c1 not shutting off
Fujitsu, Mitsubishi, Sanyo mini-split indoor fan motors operate continuoulsy. The room-temperature sensor is inside the unit, so the fan motor needs to circulate air continuouly to sense room-air temperature. This is normal operation.
Sep 12, 2008 | Fujitsu 18C1 Air Conditioner
Fujitsu 24C1 Air Conditioner Logo
70 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
