Question about Rio Forge Sport Digital Media Player
Sd card wont let player turn on,works without it but not with it
  • 6,993 Answers
that's means its not compatible together. Try to get another SD card that would be compatible.
Take care
Posted on Feb 04, 2010
When i put my sd card in my camera wont turn on
The PDR-3300 works with MMC and SD cards. Your new 8GB card is actually an SDHC card. While it fits into the slot, it is electronically incompatible and will not work in the camera. You need to use SD cards, 2GB and smaller.
May 13, 2012 | Toshiba PDR-3300 Digital Camera
Camera locks up with SD card
Put the SD memory card into an USB card reader and plug the card reader into the USB port of a working computer to check if the memory card is working.
If the computer cannot detect the memory card as an external storage device and cannot open the files or folders and it cannot be formatted in FAT32 then the SD memory card is faulty and needs to be replaced..
Mar 24, 2012 | Sanyo Xacti VPC-S770 Digital Camera
I have a samsung digmax s600 i works fine without the sd card inserted but when i insert the sd card the camara wont turn on
Be sure you have a standard SD card to put into this camera, not a SDHC type.
You will be limited to a maximum of 2GB with SD, but it should work perfectly.
If not, check the SD card in a notebook or PC's cardreader and/or replace the
SD card with another one. If this does not work the SD card interface in the
camera may be defective.
Jun 09, 2011 | Samsung Digimax S600 Digital Camera
Fujifilm S1000 wont turn on
your memory card slot is deifinately busted
Jun 23, 2009 | Fuji FinePix S1000FD Digital Camera
I NEED TO FIX THIS
First off, let's talk about the bad news: there are a lot of people who complain about just how picky the Lyra is about which SD cards it can work with. Indeed, the later model Lyra devices on the RCA site itself say "now supports more SD cards" as a feature. Ouch.
Go to a popular memory card vendor like 4AllMemory and you'll find that a search for Lyra-compatible SD cards shows barely a half-dozen matches Lyra-compatible SD Cards
Another issue: Firmware Update 615 you might need to update your firmware to gain better compatibility with various SD cards:targets this specific problem.
While we're listing all the potential problems, it's also worth reporting that there are some reports of Lexar memory cards that require a higher voltage than regular SD cards, meaning that the Lyra either wont start at all, or its battery drains faster than usual.
Comment from the web on this: "Some Lexar memory cards require at least 2.7v to operate. Some Lyra models only use a single AA battery (1.5v). This MAY mean the mp3 player doesn't have enough power to run the card (depends on if RCA used the right parts to temporarily boost the internal voltage to 3v through a booster circuit or capacitors). This may vary between models and even between different releases of the same model. This also may explain why you can hook the device up via usband send/receive files to the card fine but then have problems after you disconnect (a USB wire can provide some amount of power. My previous nexxtech player would actually turn on without a battery when I plugged the usb wire in). "
Generally, you should be hooking your Lyra up to your PC, then running the standard PC disk formatting utility. But even then, here's what RCA warns:
"We have recently discovered an incompatibility with the RD1080/RD1090, windows XP(Service Pack One) and some newer SD cards. We are presently working with microsoftto identify the best approach to correct the issue. Until a solution is implemented, we suggest that you use MMC cards instead of SD. "
To format an external device in Windows XP, just find the device in your "My Computer" window, then right-click on it and choose Format.... You'll see something like this:
windows-format-disk-options.png (since I don't have a Lyra, this shows the default for my second hard drive. Your settings would be similar, but probably a bit smaller!)
RCA offers zero assistance on the best way to format an SD Card for use with the Lyra, as far as I can tell, so I'll say that my expectation is that NTFS will work, you should use a short, letters-only volume label, and you should not choose either "Quick Format" or to "Enable Compression".
When you're ready, click on Start and it should only take a few seconds for the SD card to be ready to roll with your Lyra.
If it works.
please rank if this helps
May 24, 2009 | RCA H100 MP3 Player
Recovery mode
For those with the 4 GB model, try removing the SD card and powering completely off, without selecting any of the recovery options.  You will probably get prompted to recover when the device boots, click OK to recover - do not reinsert the SD card.  Perform a complete power off and power on cycle without the SD card.  If this works, reinsert the SD card and perform a power off/power on cycle.  If it prompts you to recover the system, the SD card is bad (the data can probably be read by the device after it has restarted, but will continue to cause the recovery mode).  Note that reformatting the card in the device does not seem to resolve the issue.  Try reformatting the card in a PC or digital camera (this option worked for me).
Jun 13, 2008 | Archos 605 WiFi Digital Media Player
My gpx wont let me retrieve the songs that i have on it i want the songs off i use to sync with windows 11 but it just shows that the space is used and shuffling the songs doesnt even work.
It is easier to get a SD memory card for it. Drag and drop the music onto the window which represents the SD memory card and then just put the SD memory card into the GPX MP3 player. I have the same MP3 player and it works nice... it was a good deal for the money! Take the savings and invest in a cheap SD memory card and you will be happy.... I was!
:-) Good Luck!
Jan 25, 2008 | GPX MW3836 MP3 Player
Hey my mp4 player the (thick one) that playes AVI and MPEG-4 videos only wont recongize my new 4GB SD-Card but would recongize my 2GB SD-Card everytime i try put it it freezes and wont move i reset it...
I can help! The mp3 player's are only built by standard specifications and they are only built to work with 2gb sd cards at the max. so i suggest using the 2gb sd card or buying an mp3 with more memory space.
Jan 15, 2008 | iLO (2 GB) MP3 Player
Wont turn on
It may be the SD memory card causing the problem. I just bought a G7. When I turned it on without an SD card, no problem. I put it my old cheap SD card and it wont turn on. I take out the memory card and battery, then insert the Canon SD card and battery and turn it on, no problem.
Hope this helps someone.
Dec 09, 2007 | Canon PowerShot G7 Digital Camera
Mp3 player wont read sd card
the reason for your problem is that the rd2312 can only handle a 1 gb card
Apr 15, 2007 | RCA RD2312 (256 MB) MP3 Player
Open Questions:
Rio Forge Sport Digital Media Player Logo
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
