DVD Players
Problem for DVD Players
Generic problem for all DVD Players
Panasonic DVD Recorder recently not upd...
By peteyt on Feb 20, 2008
Just recently my pansonic DVD recorder is not supplying correct TV Guide info and many listings are missing. I have tried all of the suggested fixes found within the manuals but they are not helping.
Same Problem
May 10, 2009
-   The Panasonic TVGOS is not working due to no data being found and even the clock won't set. I'm guessing this is a analog to digital mid-transition crisis. I'll wait until a bit after the June 12 analog to digital transmission changeover takes place. After that if the DTV Pal+ doesn't get guide info to my Panny E85H, it would be time to start a class-action suit. The DTV Pal+ was purchased to work with analog guide equipment as advertised and if it doesn't then there is just cause to get the systems working or a monetary compensation. I'd rather just get the the two devices working in harmony. The basic functions of the DTV Pal+ are satisfactory, but the advanced guide functions are **** so far. -   iphonerulez
Apr 27, 2009
-   I lost the TV guide on my Panasonic DMR-EH75V in early November 08. Tech support at Panasonic told me it was a TV Guide issue but they would try to help me reset system. It worked intermittently until I installed the DTV-Pal+ converter box Panasonic said is the only one that is compatible for TV guide to operat on their recorder. No amount of resets and code changes worked.   I give the techs an A+ for trying to resolve this,( they have never failed to take my call and at least try), but, I'm beginning to think they're as confused as i am why nothing works. I think the honchos at both TV Guide and Panasonic need to get to put their heads together solve the problem. -   vogelfanger
Apr 21, 2009
-   All listing info gone with Charter Cable and TVGOS as of about April 7, 2009. From what i keep reading, is the TVGOS gone for good????-   Guest
Apr 18, 2009
-   Same problems with Panasonic DMR-EH75V recorder - NO TV GUIDE DATA WITH COMCAST IN 94941.-   RON94941
Apr 15, 2009
-   Pannasonic DVD recorder, Cox Communications (NoVA), and the TVGOS just disappeared on April 10. About 3 days prior to that, lots of incorrect data and "no listings" then ...gone. Just the setup screen saying its searching for data. Cable company says they've made no changes and that the signal is coming to my house. Don't know what to do!-   Guest
Best Solution
posted on May 14, 2009
Very Helpful)
MooseMe
Rank: Wiz
Rating: 98%, 109 votes
I have two Panasonic DMR-EH50s and one DMR-E85H. I also have a Sony DHG-HDD250 which also uses TVGOS, but it is a HD recorder (that means full DIGITAL capabilities, including the TVGOS ) My TVGOS went out in the middle of April. I messed around on the support sites for about two weeks and found little real info.
The bottom line: I live in Madison, WI & have Charter Cable. None of my DVRs were receiving the TVGOS. Charter was not processing and/or transmitting the TVGOS properly (doesn't really matter the DVRs couldn't receive them), so I called them up, got to their "Level 3 Technical Support" and explained to them that I could not receive the TVGOS digitally or analog (converted digital) on any of my DVRs. They called me back a week later and told me to try it again....
So, all you need to do (if your local Cable Company is sending it properly):
WARNING - All SCHEDULED programs that you have previously scheduled by using the TVGOS will be deleted (NOTE: not the programs that are already recorded on your hard drive, they will NOT be deleted)
Turn the unit off.
Press the up channel & down channel (on the box, not on your remote control) at the same time & hold them for at least 10 seconds. This will reset the entire TVGOS system back to the default settings that were present when you first plugged in your DVR. This erases all previous info that your DVR had about what station it used to get the signal from and forces it to scan all the channels looking for the new channel. This is the only way to force this to occur.
When you turn on the unit, it will run you through the setup like it did when you plugged it in for the first time. Enter your zip code, etc. and when you are done, turn it off & leave it off overnight.
If your TVGOS has the Station Grid but no listings, be patient, TVGO updates its own firmware on your DVR automatically, and that may be all that happens the first night. It should start updating the listings the following night.
If it found the station grid, this is a great sign!!!! This means that your cable company is working on it!!!! It took my local Cable Company about 7 or 8 days to get it working properly, but now my 3 Panasonics and my HD Sony are all receiving full listings!!!!
If you are still getting nothing, complain to your LOCAL Cable Company. It is up to them to ensure that the signal is converted to analog & sent out over cable.
Was this helpful?
Yes
No
48 people thought this was helpful
Solution #2
posted on Apr 07, 2009
Somewhat Helpful)
Answer Guy
Rank: Apprentice
Rating: 80%, 63 votes
The channel that you have been getting the TVGOS on has gone digital and the TVGOS signal was only coming into your Panasonic DVR as analog. Panasonic has known that this would happen when the digital conversion comes but has chosen not to do anything about it except be evasive.
The people from Comcast have told me personally that my/our issue is with the DVR manuacturer for not providing any form of conversion and the FCC handling the digital conversion debacle.
I have emailed Panasonic and they tell me to call their support center knowing full well that all I will get is some ignorant person that will only frustrate me and that I will give up. FCC has yet to respond. I would encourage someone out there to file some sort of class action lawsuit to recover the value of our now worthless DVRs
Comments:
Apr 09, 2009
- Here's my update:
I talked with Comcast again and they informed me that the TV station
that was carrying the TVGOS has gone digital, There is no way that I
will get the ananlog signal that TVGOS relied-on unless there is some
method for converting the digital TVGOS to analog for my DVR.
I have also talked with Panasonic and was told that they were fully
aware of the problem and have contacted Gemstar to see what can be
done but inferred that it was essentially too bad and really my
problem anyway. Panasonic feels that they have no responsibility do
anything.
My position is that Congress mandated the digital transition in 1996.
Panasonic and all other TVGOS-using device manufacturers knew
full-well when they marketed and sold us our units with the TVGOS that
we would not be able to use them after the transition. I based my
purchase of the Panasonic DMR-EH75 on this service and do not now have
use of it.
I have reported Panasonic to the FCC and am in the process of
attempting to get someone to file a class action lawsuit against
Panasonic to either recover the value of my unit or have Panasonic
responsible for providing a converter for the digital TVGOS signal so
that I might use my DVR according to the way that I used to.
Let me know if anyone else is interested.
Was this helpful?
Yes
No
12 people thought this was helpful
Solution #3
posted on Apr 09, 2009
Somewhat Helpful)
jafieldenen
Rank: Apprentice
Rating: 77%, 49 votes
There is no point in reporting Panasonic to the FCC. It would be better to report Gemstar for not providing any advancewarning that they were turning off the analog feed, and not having thecorrect information in the digital feed for the DTVPal to translate forlegacy TVGOS analog devices. Panasonic licensed TVGOS from Gemstar andit's up to Gemstar to get everything up and running.
The issue relates to the fact that the digital signal does not carry the vertical blanking interval (VBI) that currently carries the TVGOS information in the analog signal broadcast by PBS for Gemstar/Macrovison.
Macrovision turned off the PBS analog signal nationally. It was turned back on recently. Macrovision is working to get the DTVPal conversion of the analog signal working via a standard called SCTE 127 - the standard was created to translate the old VBI info for the digital signal. Here's the bad news - even if they get all the SCTE 127 stuff working with the Dish DTVPal - if you are over the air only (OTA) you will only be able to get the digital TVGOS in markets where the CBS affiliate has agreed to carry the signal. Owners of Sony DVRs have followed this closely at:http://www.spiffspace.com/forum/index.php
If you would like to read about this issue it has been discussed extensively at www.avsforum.com
Here are some relevant threads - and technical specificiation documents.
threads:
TVGOS gone
http://www.avsforum.com/avs-vb/showthread.php?t=1115693
Dish DTVPal Thread
http://www.avsforum.com/avs-vb/showthread.php?t=1001979&page=198
Magic 8 ball on TVGOS
http://www.avsforum.com/avs-vb/showthread.php?t=1093923
TVGOS devices
http://www.avsforum.com/avs-vb/showthread.php?t=1122914
Documents relating to TVGOS and DTV transitionj
http://laurenstephens.net/uploads/3d927cc0e5.pdf
ANSI/SCTE 21 2004 Carriage of NTSC VBI Data in Cable Digital Transport Streams
10. ANSI/SCTE 20 2006 Methods for Carriage of Closed Captions and Non-Real Time Sampled Video
So SCTE 21 appears to be specific to Cable.
Carriage of Vertical Blanking Interval (VBI) Data in North American Digital Television Bitstreams - SCTE doc
http://www.scte.org/documents/standa...CTE1272007.pdf
ATSC Standard: Carriage of Legacy TV Data Services
www.atsc.org/standards/a_99.pdf
Conversion of ATSC Signals for Distribution to NTSC Viewers
www.atsc.org/standards/a_79.pdf (This one has a pretty extensive references section)
5.4.2 ANSI/SCTE 127 Data
ATSC PIRDs should decode ANSI/SCTE 127 [15] payloads carried per ATSCA/99 [17] and should re-encode all the payload data as analog waveformson the appropriate line. When present, CEA-608 [14] data carried perA/53 Part 4 [6] should take precedence over any line 21 (or line 284)data present in ANSI/SCTE 127 [14] payloads.
Section 7 is Broadcast Station Infrastructure Guidelines
Covers closed captioning, content advisory and ANSI/SCTE 127 data
"7.4 ANSI/SCTE 127 Data
And a fabulous white paper on the issue
http://www.tandbergtv.com/uploads/do...og-Turnoff.pdf
Preparing for the Broadcast Analog Television Turn-Of: How to Keep Cable Subscribers’ TVs from Going Dark
It covers the closed captioning and content advisory as well as: on p17
4.3 Other Ancillary Data
AMOL data (which are used to create the well-known Nielsen TV ratingsof program viewers) and TV Guide data (which are used by many analog TVhouseholds that do not subscribe to pay TV services) are carried inwaveforms on various lines of the VBI. ANSI/SCTE 127 [17] defines amethod to carry AMOL-48, AMOL-96 and TVG2X data in the DTV signal. Thisis shown pictorially in Figure 19. The timing of the VBI data-stream issynchronized with the corresponding video and audio data-streams, asapplicable, through the use of common presentation timestamps. Thewaveforms themselves are defined in CEA-2020 [18]. If present in theincoming ATSC/DTV signal, the ATSC-to-NTSC converter/receiver willparse through the ATSC transport stream, locate the VBI data-stream,extract the AMOL-48, AMOL-96, and/or TVG2X data, regenerate thecorresponding VBI waveforms and insert them into the output analog TVsignal.
Comments:
Apr 09, 2009
- One more link:
http://tvgos.custhelp.com/
Which is the Macrovision support site.
Apr 10, 2009
- For a list of which channels will offer TVGOS over the air there is a list available at:
http://www.rabbitears.info/market.php?request=tvgos
Was this helpful?
Yes
No
3 people thought this was helpful
Solution #4
posted on May 01, 2009
Somewhat Helpful)
juneytoo
Rank: Apprentice
Rating: 76%, 50 votes
I had read in another forum that beginning May 1st, Comcast would start to Broadcast the necessary SCTE 127 data for the TVGOS function again. I don't recall if this applied to all Comcast locations. I am in New England and sure enough, sometime between the evening of 4/30 and morning of 5/1, my guide has updated. I am using a Panasonic DMR-EH50. I was suspicious that the equipment might not be capable of updating after the DTV conversion. It had stopped updating the TVGOS in mid-February. This is the first time the guide has updated since then. Glad to report that the equipment is working fine.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #5
posted on Aug 25, 2009
Somewhat Helpful)
drdelazzo
Rank: Apprentice
Rating: 75%, 5 votes
To get limited functionality with the dmr-e85h tell the unit there is no cable box, and on time warner you can get the channel line up but they may not match perfectly, next a custom edit of the channels may work to get updates, the local channels appear to be getting the guide info. ok but other channels just added will take longer if they get the program lineup. The ir blaster failed every time for me.
Was this helpful?
Yes
No
Solution #6
posted on Aug 04, 2009
Somewhat Helpful)
yelmel
Rank: Apprentice
Rating: 75%, 7 votes
I have the DMR-E85H and Charter cable, and received TVGOS solidly until July 2009, when it failed to get listings. I tried the firmware updates and system resets, and further lost the entire channel line up. My unit would never finish setup, still trying to search for channels and programming. But I noticed my TV with a digital tuner was able to pick up local digital signals coming through the cable.
I tried a long shot and borrowed a digital converter box intended for broadcast tv. I set it up, and left it turned off -- also left the DVR set at Cable without a Box. It worked!! When I turned on my DVR later the next day, it stated it had found more than one signal service provider, so I selected Charter Cable and went through a couple of steps to verify setup, and my channel lineup was back, and the TVGOS programming schedule. Hooray!!!!!!!
Was this helpful?
Yes
No
Solution #7
posted on Aug 03, 2009
Somewhat Helpful)
jangona
Rank: Apprentice
I have had this same issue happen to me three years in a row. It seems to happen in July. First I get limited channel information, and then nothing. I've tried resetting the system, and it never helps.
I normally call Panasonic, and go through all their basic steps, and ultimately they escalate it to TV guide. After a period of time (varying from 2 weeks to a month), magically the programming appears...
Last year, when it happened, I contacted Comcast, in Boca Raton, FL, and was promptly told that they do not do any troubleshooting for non-comcast equipment...
Was this helpful?
Yes
No
Solution #8
posted on Feb 21, 2009
Somewhat Helpful)
Yorkart
Rank: Apprentice
Rating: 75%, 46 votes
I just spoke to Comcast cable in Philly.  The channel that carries the on screen tv guide signal was switched from KTCI (analog) to WCCO (digital) on tuesday Feb. 17, 2009.  Coincidentally my onscreen TV Guide listings disappeared in that same time frame (Panasonic Plasma TV and DVR).  Comcast assured me they are aware of the problem and have technicians working to rectify it.
Thanks for the posts.
Was this helpful?
Yes
No
Popular Solutions for DVD Players
Questions and Unsolved Problems for DVD Players
Answer
what sort of scart lead for product dvp3360
Answer
Isn't there a switch or something inside the VHS/DVD recorder that you can flip that will override... (More)
Answer
could you please tell me where the hard drive board is on this model also the ogeam board please... (More)
Answer
my dvd player says line in but it shuts off right after. I have the plug in but the charge light is... (More)
49 Other Users Have The Same Problem - Continued
Comment by Longwing01, posted on Apr 13, 2009
Same problems with Panasonic DMR-EH75V recorder. The TV Guide stopped working about a month before the transition in February. Still no progress 7 tech support calls later with Panasonic including all their resets and "escalation steps" all the way up through the "753159852" code and reading back pages of default tech parameters to them. Cable service provided by Atlantic BroadBand. After 3 months I'm tired of the runaround and the "wait 24 hours then call us back" and empty claims someone is "working on it". Just tell me where the class-action suit is and I'll sign up. I do not see what motivation cable-providers would have to solve this problem since they want to rent you their own cable box with guide system.
Comment by MBKD, posted on Apr 09, 2009
Some points to consider:
Please note that I am on cable (CableOne) and I don't know if this applies to satellite.
1) Here in my area our local CBS station began carrying the TVGOS signal when it was shut down by PBS. I confirmed this by talking to the engineer at our CBS station.
2) After the conversion to digital, our cable operater began receiving all signals in digital but they then convert that digital signal back to analog and transmit both a digital and analog signal to our homes simultaneously. That is in fact how people with only an analog TV can continue to receive programs after the digital transition.
3) I called Panasonic about a week ago to tell them that I again lost the TVGOS. I was told that as of March 1rst, the station carrying the TVGOS would have to make some sort of modification to reinsert the JPEG (MPEG? not sure what they were talking about) back into the signal and until that was completed we would not receive TVGOS, but that Gemstar was working to accomplish it. Panasonic suggested that I contact my cable operator and after I explained that I have called them so many times that they no longer will talk to me, Panasonic then agreed to contact Gemstar (again) to see if they could contact our cable company to get it straightened out.
I suggest that everyone contact Panasonic/Sony to complain and don't let them off the hook. Make them contact Gemstar. I was told that Gemstar cannot be contacted by individual consumers.
Comment by neen13, posted on Apr 09, 2009
Answer guy - count me in your lawsuit -I am really disgusted!
Comment by mdmpress, posted on Apr 07, 2009
Well I'll be damned! After weeks of struggling with the TVGuide disappearance, I caved to Comcast and had them install an HD box. I haven't even checked to see if the TVGOS guide had reappeared until just now when I read JimDogX's post! Mine is back also! However, since Comcast is going to do its "bait and switch" on 6/29 which will remove all my channels above 30, I guess I'll stick with the HD box. The picture is spectacular but the TVGOS guide is better than Comcast's.
Comment by JimDogX, posted on Apr 07, 2009
I know this doesn't help anyone, but here in Denver, my TVGOS just started working again this weekend. I never unplugged it or did anything. It was out (i.e. "No Listing") for about two weeks (maybe three). I can only assume that Comcast was in the middle of an upgrade or something? At least that's what I'm hoping. Hopefully it doesn't go away again.
Comment by Guest, posted on Apr 06, 2009
Same problem here with Panasonic DVD Recorder not downloading programming anymore - Comcast is my provider. And here I thought I was going crazy!!! Hope someone fixes this dilemma soon.
Comment by Guest, posted on Apr 02, 2009
Lost my TV Guide On Screen right around daylight saving time. Comcast doesn't have an answer, nor does Pioneer.
Comment by Guest, posted on Mar 30, 2009
Same in Middletown CT
Comment by myname867, posted on Mar 29, 2009
Same problem in Denver with my Panasonic DMR-EH74V. My onscreen listings stopped about 3 weeks ago. I called Comcast about it. Comcast claims the signal was put out by local PBS station, and since the station went digital in Feb, the signal stopped. BS. The station went digital weeks before the signal stopped. I'm going to try a Comcast engineer, but since Comcast here is generally not cooperativewhen it comes to technical question from customers, I don't have much hope. Any other suggestions?
Comment by MBKD, posted on Mar 28, 2009
Please read my previous posts dated Jan 22 & Jan 24. My TVGOS listings went out back in Jan. I called Panasonic & they gave me a code number to punch in my unit which brought up diagnostic screens and I transferred that data to the lady at Panasonic. She said she would send that info to Gemstar/Macrovision. I also called my cable company . After a week or so, the TVGOS listings reappeared and were working fine up until about the time of the daylight savings time changeover in early March- since then again no listings. (My cable company converted to digital back in Feb and in fact the TVGOS was working fine after that conversion, up until March.) I called Panasonic again and they sent me a firmware (software) upgrade for my unit. Didn't help. If I call my cable company I absolutely must talk directly to the engineer as know one else knows anything about TVGOS. He doesn't want to talk to me anymore and just says " we have not changed anything since Feb". I think the TVGOS is dead and I think it is a cable/Gemstar problem. I think my Panasonic unit is working properly - just no signal coming thru. I will call Panasonic again to complain, as they have to send a complaint to Gemstar, we consumers are unable to.
Comment by Guest, posted on Mar 28, 2009
Please read my posts below from Jan 22 & Jan 24. My TVGuide ON Screen listings went out in Jan. I called Panasonic as well as my cable company. Panasonic had me punch in a code number on my DVDR which brought up diagnostic screens with a bunch of data that I read to the lady on the phone. She said she would send that data to Gemstar/Macrovision. After about a week or so, everything was fine again up until the weekend of Daylight Savings time in early March. Since then, no listings. I have tried everything. Called Panasonic and they sent me a firmware (software) upgrade CD for my unit which I installed. Still did not help. I believe it is something from either Gemstar and/or my cable company (CableOne) that is causing the problem. I do not believe it is a problem with my Panasonic DVDR. My cable company made the conversion to digital back in Feb and in fact the TVGOS was working fine after that conversion up until early March. If I call my cable company I absolutely must talk directly to the engineer because no one else has a clue about TVGOS. The engineer doesn't want to talk to me anymore and just says "we have not changed anything" since mid Feb. Looks like the TVGOS is dead, but I will call Panasonic this week and complain again.
Comment by Guest, posted on Mar 26, 2009
This is not just a problem with the Panasonic DVD Recorder, since I own one. Our new Sony flat screen, which has TV Guide On Screen, is not receiveing the signal either. Both stopped working at approximately the middle of February. After calling the cable company, I was told that the TVGOS signal was being received and broadcast by Educational TV, so I called KET ( KY Education Televison ) and spoke to an engineer. He told me that TVGOS was in negotiations with the Public Television Stations, to continue providing the signal. Hopefully this situation will be resolved soon.
Same problem with my charter cable here in Atlanta. Stopped downloading anything as of last Tuesday. This sucks! Someone needs to fix this.
Comment by garylape, posted on Mar 22, 2009
Same problem with Cox here in Tucson. Samsung TV lost the guide two weeks ago; unplugged set for 10 minutes and got it back. Now its gone for good. One week ago it happened to the Panasonic DVR. Cox Tech support knows nothing about TVGOS, but will rent me a box that gives me their clunky TV Guide.
Comment by Guest, posted on Mar 21, 2009
Using the Sony HD DVR (DHG-HDD250). Same problem here in Spokane Washington. Used to get the info off of 90, but 90, 7, 107 are all no go. Stopped working on 3/19/2009
Comment by JimDogX, posted on Mar 20, 2009
I have an LG HDTV with a built in DVR.  TVGOS (TV Guide On Screen) has worked great for the last few years.  As of about a week ago it stopped working.  My local PBS station said:
"If you are dealing with Gemstar, they have stopped uploading TV Guidedata to their encoders."
I believe Gemstar is the provider of TVGOS (correct me if I'm wrong).  HOWEVER, this link:
http://www.macrovision.com/dtv/10061.htm
Shows me that the cable company (Comcast) in my area is set up to continue sending TVGOS data even after the digital transition.  So it looks like this might be a cable company issue (at least in my case).
Comment by twb311, posted on Mar 20, 2009
same problem here in Kansas City, MO with Time Warner Cable on or around 3/19/09.
Comment by hurrro, posted on Mar 20, 2009
I cannot connect to the TV Guide system with a Pioneer DVR-633H-S
Comment by mdmpress, posted on Mar 19, 2009
I have had no TV Guide for over a week. Screen says" Updated information will be available within 24 hours. The Guide is rebuilding your channel list based on your setup change." Comcast won't own the problem; says I have to call Panasonic. Panasonic agent had me input some code no. and read numbers off from a series of screens that appeared. Said they'd call back. They never did. Store where I bought the TV said to try unplugging the TV for a few minutes. No solution there either. Comcast is a bloodsucker. (I'm in a condo assoc. that has a bulk contract with Comcast who will continue to get $40/mo of homeowner dues even if I switch providers.) I may end up having to put in and pay for one of their boxes even though I neither need nor want ANY of the features beyond a TV Guide. (I get slews of channels, including quite a few HD ones, without a set top box--just a cable into the wall connection.) The other fix is to use the TV Guide that comes in the newspaper, but I hear my SF Chronicle may be on the chopping block soon. Can anyone tell me WHO has the responsibility for providing the TV Guide? Comcast? Panasonic? My local PBS station? Macrovision? TVGOS.com? Other?
Comment by dkonbest, posted on Mar 19, 2009
I have nothing of value to add to this discussion, but if numbers make a difference, I'm one more person with the same problem (no TV Guide On Screen since early March 2009.) Thanks to all who are helping with this. - Diane in Spokane Valley, Washington
Comment by jafieldenen, posted on Mar 12, 2009
Ditto. I am over the air in Denver and have no TVGOS listings after next Tuesday.
Comment by forvickys, posted on Mar 12, 2009
I stopped receiving TV guide listings on 2/17/09 for my Panasonic DVD recorder. I have called them 4 times and finally today they informed me that TV guide online uses an analog signal and our cable company has switched signal to digital. Didn't TV guide or the cable company know over a year ago that this would happen? Why didn't they have a solution to this problem back then? Panasonic feels they informed TV guide of my problem and now it's up to TV guide to fix. I think it's up to Panasonic and our cable company to work out a solution with TV guide. If not then we should all request our money back from the cable company from the time we stopped receiving signal for tv guide and panasonic for a dvd recorder that does not have the features we purchased it for. Maybe then something will be done to correct this problem. Here's TV guide onlines phone number. Lets call our cable company and TV guide online everyday and let them know we want this problem fixed. (TV guide) 1-800-386-7380
Comment by racefan1, posted on Mar 04, 2009
On screen TV Guide just disappeared. my cable provider says that it is a PBS problem and it could be awhile but that PBS will broadcast the analog signal again. I hope so, miss the guide for my DVR!
Comment by hein1234, posted on Feb 18, 2009
I also lost my on screen guide stuff at cox. I am finding out that it does seem to be a Cox problem If we hook up one of those Digital boxes you can buy with the government coupon would that make the dvr work. rather then renting a digital box from cox.
Comment by MBKD, posted on Feb 03, 2009
Yesterday my cable operator confirmed to me that the problem is indeed their equipment (receivers) and his head office is working on a solution.
I found a technical guide from TVGOS dated OCT 2008 targeted toward engineers at cable providers which describes how their equipment must be set up in order to keep TVGOS data flowing. I suggest that each of you the print out this info and deliver it to engineering at your cable provider. Here is the link:
Comment by Guest, posted on Feb 02, 2009
Same problem in Mobile AL. Must be somehting Comcsat did, probab;y to get you to rent theri DRV. It is just not right. CLass Action anybody?
Comment by MBKD, posted on Jan 24, 2009
I called my local PBS station and while discussing this problem, their rep googled and found an article stating that in early 2007, Gemstar/TVGOS reached an agreement with CBS to carry the TVGOS data embedded within the CBS signal in anticipation of the digital changeover in Feb 2009. I.E. looks like TVGOS has switched from PBS to CBS. I called my local CBS station and talked to their engineer who confirmed that they added the TVGOS about a month ago. I explained that I am not getting the data through our local Cable provider, Cableone. The guy from CBS was going to contact CableOne to see if they can work out a solution. As of last night I still had no TVG data coming thru. I would suggest that each of you contact your local CBS affiliate AND local cable AND local PBS to confirm/complain. Ask to talk to someone in engineering, OTW no one will know what you are talking about and will get it confused with the regular scrolling TV Guide found on all cable systems. Also, here is a number for GemStar and I would call them: (781) 276-8855. The more everyone complains the greater chance of solution. I have basic cable, no cable box and a Panasonic DMR-eh55S. I was also informed of something else: even though all broadcasts will be in digital form, your local cable provider has the capability to convert those broadcasts back to analogue. That is in fact why, if you have cable service with an older analogue tuner, and no cable box (like me) you will still not be affected by the digital changeover.
Comment by MBKD, posted on Jan 22, 2009
Same Problem. I am in Southwest Missouri and have a Panasonic DMR-EH55S connected directly to my cable from my cable provider. The TV Guide On Screen system worked perfectly up until about ten days ago. Now it cannot download any TV Guide data.
Comment by Guest, posted on Jan 19, 2009
I have the same problem with a DMR-E95H and a neighbor has the same problem with a Toshiba DVD so it appears the problem is not the DVD, but the cable transmission.
Comment by EH55, posted on Jan 19, 2009
I have a panasonic EH 55 DVD recorder. Feb 2008 I had to get a total redue of my cable hook up with Bresnan in Montana 59427. Finally it worked great. Now since Jan 9th 2009 I have the channle lineup but not the listings. I'd call the cable company, but they would just tell me to call panasonic like last time. But I'm sure the cable company did something. I'll reset the panasonic and try again. But I think TVGOS is gone.
Comment by jmarks, posted on Jan 11, 2009
I have a Panasonic DVD Recorder DMR-EH55. I thought I was the only one with this problem, but now I know better. I lost my TV Guide On Screen several weeks ago. I have Comcast with the cable attached directly to the DVR (no box). I will call Comcast to see if, in fact, they have stopped sending the TV Guide On Screen signal.
Comment by bobcowen, posted on Jan 06, 2009
same problem, Farmington Hills, MI (Brighthouse Network). Panasonic DVR (DMR-EH50), directly connected to cable, worked fine for 3+ years. I've re-set numerous times & can receive correct channel line up but no TV Guide.
Comment by kblh, posted on Jan 03, 2009
Same problem with Cox in Annandale, VA 22003. Cox says that it will work if I get their cable box. Does anyone know if that is true before I go down there and get a box (which I really do not want)?
Comment by Guest, posted on Dec 30, 2008
same problem with panasonic dmr-eh50 using comcast in alexandria, va.
Comment by dcr3, posted on Dec 30, 2008
Same problem in zip code 49525. I've tried everything I can think of without luck!
Comment by Guest, posted on Dec 29, 2008
Same problem witgh Comcast in metro-Detroit.. Guide has not updated in 6 days.. Can't find the guide data that used to be found on PBS channel 97 (local system).. Have EH75V
Comment by jddubick, posted on Dec 29, 2008
Same here. I have the EH50 which has been working great for two years. Last week I turned on the system and no guide just "no listing available" for all channels. Called the local cable provider who told me they have not made any changes recently. In the past I have gotten the "unable to locate guide" message which referred to a set-up problem, but this is clearly different. Right now I think said cable company has done something that they do not even know about.
Comment by neen13, posted on Dec 18, 2008
My DMR EH50 model stopped displaying TV Guide ON-Screen about 2 weeks ago. We turn the unit off every night and left it off for more than 24 hours with no success. Panasonic is no help. I'm thinking about getting a different model. Any help would be appreciated
Comment by Guest, posted on Dec 15, 2008
Just called Panasonic for umpteenth time again today about this. After much holding and waiting, got the same answer. "Sorry, this won't be resolved until the Analog-Digital switchover takes place in February."
My other problem prior to having no listings available was that the unit always changed channels on my at 10:30 each night (PST). Today, they tell me that is the unit updating the guide service and there is nothing that can be done, except that I could move the IR blaster each night at 10:30. I told the guy that Panasonic was crazy if that is their solution. Apparently it's a TV Guide thing and not a firmware option as to when the guide gets downloaded, but it's still bunk.
So much for Panasonics foray into the HDD recorder market.
Comment by dell18064, posted on Dec 06, 2008
same here, but the root of the issue lies in the TV Guide signal being analog broadcast. Many cable companies are converting to Digital and dropping the TV Guide signal...bummer. I have not heard of any way to work around it, but if your cable company still broadcasts the TV Guides signal, you could try the Echo Star DTV PAL. You can get details at www.DTVPAL.com. That is about all that can be done...however if your cable provider doesn't broadcast it anymore, you are SOL
Comment by Guest, posted on Nov 14, 2008
I have the same problem with Charter in zip code 35613. Worked fine until 3-4 months ago, then disappeared. Came back briefly, but is now gone again. No one at Charter seems to have a clue what I'm asking about. Even though Panasonic's manual says to call them, they had no advice to offer (except to reset as you described, but it didn't work). Very frustrating...
Comment by RichAZ, posted on Jun 09, 2008
I have had the DMR-EH-75V for 22 months.  TV Guide On Screen signal has been erratic at best but now it has been out since May 17th. Panasonic customer service tells me there is nothing they can do.  TV Guide On Screen acknowledges the problem in my area, zip 85755.  Said they are working with COMCAST to determine the problem.
I have case numbers from Panasonic and TV Guide On Screen.
I have found no one at COMCAST Customer Service that understands TV Guide On Screen.  (They do try to flog digital service.)  I provided feed back to a SVP at COMCAST, last week, a rep called acknowledging the problem.  I contacted them again this week, no response yet.
Who else can I contact?
Comment by Jakester23, posted on Apr 25, 2008
MIne started showing No Listing, then it would come back, then go away.
Panasonic had me hold down the Up and Down channel buttons until the unit turns off. This resets the TV Guide. Then you wait with the unit off 24 hrs.
I don't know if it worked yet.
I also read other places that the Feed Host Station sometimes quits sending. This I don't think is the issue, since I still am getting movies, and it comes and goes. Sometimes I have two days' worth, now none.
However, if Comcast is interfering with the relay, I think this is a monopoly problem and we should all call our state Attorney General. Comcast tried to get me to get a Digital box (which gives you TV Guide, has nothing to do with On Screen for the DVR), tried to tell me I was not "entitled" to the TV Guide (again, this is the TV Guide channel, not On Screen) and tried to tell me I should rent their DVR. Outrageous.
Comment by drogers14, posted on Mar 13, 2008
I have a sony and a panasonic and both have lost their guides
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top DVD Player Experts
Top TV Repairmen
in New York, NY
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
