Question about Copystar CS-2030 Copier
C710 Code on Copystar 2030
Installed new drum and Cleaning on a Copystar 2030 blade. Now @ startup it gives me a C710 code. How do I clear this code?
  • Anonymous Mar 16, 2014
    km 2030 c710 error code
    c710 kyocera 2030
    Genius:
  • 1,665 Answers
Did you disconnect telephone line?
C710 : Interrupted Communication at the Destination.
If you're the sender, it's happening outside your machine.
Most likely, phone line
Posted on Feb 20, 2008
    Brigadier General:
  • 3,614 Answers
Broken panel around power switch.
  • Copystar Master
  • 19,396 Answers
C710 Interrupted Communication at the Destination. If you're the sender, it's happening outside your machine. Most likely, phone line.
  • 4 more comments
  • Ginko
    Ginko Feb 20, 2008
    Sorry I gave you wrong error code solution. here comes the right one:
    C710
    Toner sensor problem
    • The sensor output voltage is outside
    the range of 0.5 to 4.5 V during toner
    control.
    • The toner sensor control voltage
    cannot be set within the setting rangewhen maintenance item U130 is run.
    C710
    control.
  • Ginko
    Ginko Feb 20, 2008
    Try removing and refitting drum and toner, if this does not help you may have damaged your toner cartridge or the sensor.
  • Ginko
    Ginko Feb 20, 2008
    If you have another toner cartridge try replacing the one inside and see if error code changes or disappears.
    If it does then you may solve the problem with a new toner cartridge.
  • Ginko
    Ginko Feb 20, 2008
    If this does not help you may need to change your toner sensor
  • Ginko
    Ginko Feb 20, 2008
    On your printer C710 definitively means
    Interrupted Communication is a wrong solution as it was meant for a different device. The comments I posted above are the solution for this kind of problem (see also sensor toner error on fixya).
    Hope this have been helpful.
    cheers
  • Ginko
    Ginko Feb 20, 2008
    I tried to find the service manual. You may need it in case you need to change the toner sensor (the part shouldn't be expensive). I didnt find
    Here is the user guide from copystar:
    http://usa.copystar.com/CopyStarPub/jsp/...
    Here another user guide for your model
    http://d.imgsw.com/sw/swchannel/Customer...
    And finally... if you need the service guide there is none for free on internet, you can ask it to copystar or by it on this website
    If this solution has been helpful, then do not forget to give proper rating.
    cheers
Troubleshooting a Copystar CG1505 with an error code of C710.
C710 Toner sensor problem
the range of 0.5 to 4.5 V during toner control.
• The toner sensor control voltage cannot be set within the setting range when maintenance item U130 is run.
Try removing and refitting drum and toner.
If that doesn't help the toner cartridge or sensor is damaged.
Please take a moment to accept and rate this solution accordingly.
Thanks,
Lee
Sep 26, 2008 | Copystar Office Equipment & Supplies
How to reset my copier plz send me a solucation code.
whats the code man if it is c600 then got diagonistic by presssing 10871087 then press 163 press start button 3 times to clear it.machine will restart .this is for fuser . if u require to reset the drum then msg me
May 15, 2011 | Kyocera Copystar CS-1635 Copier
C710 ON A cs 2030
if it appears after replacing the toner then the toner being used is faulty
Apr 26, 2010 | Copystar CS-2030 Copier
Error code C400
that code points to your laser unit. you will have to have a tech install a new or refurbished one. then code will clear.
hth,
razoras
May 28, 2009 | Copystar CS-2030 Copier
Error c710? my machice is a CS2030 whatt is? help me
Double check the connector for image process unit (Drum/DV) White connector to the left when you open front cover. Error code is a toner density sensor prob, could just be that connector isnt plugged in right. power down before reconnecting!
Aug 22, 2008 | Copystar CS-2030 Copier
Copy star 3035
The drum unit may need to have the toner collection blade replaced. not the cleaning blade for the drum but the one below it that catches the toner cleaned off the drum. if this blade is old or damaged it losses its seal to the drum and drops tiny specks of toner onto the page.
Hope this helps...
Lbcoast
Aug 20, 2008 | Copystar CS-2030 Copier
Feb 20, 2008 | Copystar CS-2030 Copier
Error appearing on screen C710
C710: Interrupted Communication at the Destination.
Feb 15, 2008 | Copystar CS-2030 Copier
Copystar CS-2030 Copier Logo
466 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Adorjani Laszlo
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
