Question about Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water
My bottom drawer of my 3 year old Maytag fridge is freezing up all the items I put in it. The fridge is on its lowest setting. What's up?
  • 52 Answers
You mentioned that the fridge is at its lowest settings, try up it a bit so it doesn't freeze up your items.
Posted on Feb 04, 2010
Maytag Dual Cool - fridge side too cold even on lowest setting - freezing vegtables
It's just as previous person, on warmest setting vegetables and meat are freezing in drawers
Apr 10, 2013 | Maytag MSD2651 HE Side by Side...
Fridge freezing items in veg draw
Usually the thermostat stuck closed but can sometimes be drain water freezing after defrost due to blocked drain. Fully defrost and check water drains away.
May 09, 2012 | KitchenAid Whirlpool Kitchen Aid...
Fridge freezing everything
THIS REF. WORKS BEST WITH THE REF. SET ON 4 OR 5 AND THE FREEZER AT 2 1/2 OR 3. HAVING A HIGH FREEZER TEMPATURE CAN HAVE FREEZING IN THE BOTTOM DRAWER OF TH REF. MAINLY BECAUSE OF THE RETURN AIR VENT TO THE FREZER IS BEHIND THAT DRAWER.
Apr 25, 2010 | Maytag 21.9 Cu. Ft. Bottom-Mount...
I have the same problem.
test thermostat. when fridge is running, turn dial to lowest setting , fridge should turn off. then when fridge is not running,turn to highest setting, fridge should turn on. if it fails this test thermostat is faulty and needs to be replaced
Sep 10, 2009 | Maytag MBB2256G Bottom Freezer...
I have a MBF2556HEW Fridge. Various fresh & liquid items in my fridge are freezing. I've turned the temp down to 3 from 6, and it's still doing it. The fridge also makes a clicking sound every few...
Try unplugging fridge for a few minutes then plug back in,if it still does it you could have a relay going out? Also if you have another freezer put frozen items in it and refrigerated items in another fridge unplug othernight then plug back it it could be froze up also when unplugged clean coils with brush and vaccum either underneath or on back,most likely underneath(becarful not to bend anything and make sur unplugged)Try all these tactics before you start changing parts!!!!Best of Luck to You!!!amtnng
Aug 12, 2009 | Maytag MBF2556HEW / MBF2556HEB /...
Food is freezing in the bottom drawer of my Maytag side by side
check to make sure the slide controls for teh bottom drawer is set to vegtables also it is not uncommon for the temps in the bottom drawer of your refrig to drop down to freezing if you have infrequent door openings. you may also try setting the refrig temperature to a warmer setting as well. thx Peyton
Jan 29, 2009 | Hotpoint HTS20GCNWW / HTS20GCNCC Top...
Side by Side, Fridge is freezing at lowest setting
Is you fan in the freezer working I would check it first . if not check for power to the motor ... if you have power replace motor...
Sep 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Produce freezing
I had the same problem when one of my kids changed the setting of the chef's pantry (full-width drawer) to higher setting and everything started freezing. The setting should be at "lowest setting". Give it a try. deborah.
Feb 07, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Open Questions:
See all Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with Questions
Maytag 25.6 cu. ft. Wide-By-Side Refrigerator with PuriClean II Ice and Water Logo
209 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
