Question about ViewSonic VA1912w 19" LCD Monitor
Connect VA1912w Monitor with DELL Laptop
I am trying to connect a VA1912w monitor to a DELL D820 laptop with Nvidia Grpahics card. I am not able to get the native resolution required for the monitor (1440 X 900).I installed the driver for the VA1912W but still the maximum resolution I see for the monitor in Windows is 1024 X 768. Is it the Monitor driver issue or a display adpater issue.
  • Anonymous Mar 18, 2014
    Front panel of my lcd monitor va1912w is damaged Can it be repaced.Where?
  • 436 Answers
I don't think it is a problem with the monitor or its driver.Please adjust the monitor settings on Windows by Right click-Properties-settings-Screen Resolution-1440*900.Now check whether you are getting the native resolution.
Posted on Mar 21, 2010
How can I check my dell d820 screen? It stopped working
Hi, first:
try to connect to a VGA Monitor (it has DB15 Connectors(bing or google it) and usually in blue or black colors) and press and hold windows key then press P on your laptop keyboard or (peripheral PC keyboards) tap these shortcut for 2 or 3 times and see what happened, if you see any changes on monitor or see your screen on the VGA monitor your Graphic card is fine so go to the next step if not
maybe you have chipset problem or bios (UEFI) problem so go to the certified Repair shop,
next step:
some laptops have a shortcut key to turn your LCD off in expanding screen mode for decrease power consumption. try press (fn + keyboard key that sometimes has a rectangular icon with x icon on top of it) if you try but nothing changes or see white screen or glitch
screen pixels then 2 possible things happened,1- your LCD flat cable or 2- may be your Screen LCD damaged in this case go to certified repair shop center
best regards
Jun 16, 2014 | Dell Latitude D820 Notebook
My Dell Latitude D820 has many problems.... The biggest one is that I came home from work to turn it on, and the screen is black... When it turns on, it is completely white. I am so upset! I just got this...
Screen issue:
It sounds like either the lcd screen or video card inside the computer is bad. To isolate the problem try connecting an external monitor to the laptop. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the external monitor displays ok that proves your video card is ok and your lcd screen is the problem. If the external monitor displays the black or white screen like your lcd screen then your video card inside the computer is bad. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
Laptop hot:
Some laptops and the ac adapter get very hot. If the laptop is not shutting down, then it is not overheating, so don't worry about it. You can buy a laptop cooling pad that has fans on it and it plugs into one of the usb ports on the laptop. The laptop sits on it to keep cooler.
Your battery is probably dead so that is why you can only power it up using the ac adapter power cord. Once the power cord is removed, the laptop will turn off. Batteries only have a useful life, and after that, they have to be replaced.
May 21, 2012 | Dell Computers & Internet
Dell Latitude D630 Problem With The Screen has a D630 with nvidia nvs135 and it dont show nothing on the screen, i tried to connect it to a lcd monitor none works. The displays are working, but its just a...
If you don't get a display on the external monitor, then most likely your video circuit is the problem. If your laptop has a plug-in video card it can be replaced. However if it's integrated into the motherboard then you'll have to have that replaced.
Jan 26, 2011 | Dell Latitude D630 Notebook
How do i get rid of vertical lines in my latitude d820 laptop
try to update BIOS and uninstlal reinstall video driver. connect external monitor to check if have same problem. perform Built in self test on LCD - to do it, make sure computer is off then press and hold "D" and press power button. if still have vertical lines on screen, need to replace LCD
Feb 20, 2010 | Dell Latitude D820 Notebook
I have a laptop HP pavillion dv6000 with Nvidia 8600 M GS videocard. When I tried to connect it to TV with Svideo cable it is not Identifying the TV as second monitor.
Greetings,
You need to configure the nvidia software for dual monitor mode. And refer the manual of the laptop to find the hotkey to enable external display device. If you provide the exact model number of the laptop I will be able to provide much information to you.
Revert back for clarifications.
Warm Regards,
Zulfir Sadat M
Apr 13, 2009 | Nvidia 64MB GeForce3 AGP Video Card with...
Getting audio from a Dell LCD Monitor when connected to a Laptop
connect the audio cable to laptop and LCD monitor...
.35mm male to male jack
connect the cable to your laptops headphone jack and the other end of cable to the monitor
the VGA and DVI cable are for video only
Apr 02, 2009 | Computers & Internet
Multiple monitor problem
1: First check wether your graphics card is able to support 2 monitors. Not all built-in ones can do that.
2: If you re sure it should be able to work, try restarting the pc after you connect the monitor, it should open a popup and ask what you want to do.
3: If not try updating your drivers and repeat step 2.
As for the tv as a monitor, most digital tv's are able to do that, yes.
I hope this helps,
Yannick
Feb 17, 2009 | Sony Computers & Internet
External display not displaying!
When you are able to view a video clip on the external monitor, We can rule out the issue with the software. Probably you need to check the connections and also the external monitor settings in the display. The reload might have changed the old setup
Feb 03, 2009 | Dell Latitude D820 Notebook
Cannot display anything at all,sounds it is working but, cannot dispaly boot screen and rest???
Try connecting an external monitor to the Dell Latitude D820. If the monitor display is fine, then your laptop’s LCD display panel is defective. If the monitor has no display, then your problem is with either the video card or motherboard located inside your laptop.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 07, 2008 | Dell Latitude D820 Notebook
How to connect my compaq presario V6000 to my dell monitor.
try hitting Function (FN key next to the control) and F7 at the same time on the laptop. Also, is the dell monitor's input set to VGA (some have multiple inputs like DVI, VGA, HDMI, etc)
Jul 08, 2008 | Computers & Internet
ViewSonic VA1912w 19" LCD Monitor Logo
133 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
