Its defrost problem, the freezer should cool,
then freeze, then defrost cycle should start. In your case freezer is cooling,
then freezing, but its not defrosting. That's why fridge section is not
cooling.-------
Click this link below and follow the
troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
When the freezer section gets cold and reaches
its required cooling temperature, after that the frost on freezer section
starts defrosting and the cooling fan in the freezer section blows this cool
air from freezer to fridge. But if the defrost cycle does not start then over ice will get collected on freezer ventilations and that will block the air passing section from freezer to fridge, so the
freezer gets cool but fridge section does not cool.Try manual defrost by unplugging the
refrigerator from main power outlet for 4 hours then reconnect it and check, if
the same problem is noticed again,. If yes then its defrost board problem. The
defrost board located in the back of fridge section. You can get required parts
from www.repairclinic.com or from online sears part site. ------------- Thank
you.
