Question about Craftsman 10" Table Saw
My 10" Craftsman table saw will not start.
Power is getting to the on/off switch, but the motor will not start or make any kind of noise. Is there a most likely cause of this problem?
Model#137.248100/with stand
The switch is prone to load up with sawdust. UNPLUG the saw. Remove switch from stand, (you will have to remove ground screws as well). clean out. Reassemble
Posted on Mar 01, 2010
    Scholar:
  • 84 Answers
Check to make sure that the power is going though the switch. Check for power at the motor. If there is power going into motor, then the armature is probable shot.
Posted on Feb 04, 2010
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
forum.woodenboat.com/showthread.php?...table-saw...I...
WoodenBoat
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ...
www.shopyourway.com > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
I plugged in my table saw and everything worked just fine. I unplugged it, and then came back a few minutes later and turned on the table saw again. This time the motor was not running. Power was getting...
First of all, how did you determine that power was getting to the motor? If you can test for power with a voltmeter at the motor connections themselves and show power then the switch is OK and the circuit breaker is not tripped. Turn off power and attempt to turn the blade " CAREFULLY" and if it moves easily then the motor is probably defective and will have to be replaced. After turning the motor and finding it easy to turn, then turn the power back on and try to start the saw again. Be carefull because the saw may start. If the blade will not turn then the motor is definitely defective and will have to be replaced.
Good Luck!
Mar 14, 2011 | Craftsman 10" Table Saw
My craftsman 10" table saw will not start. i flip the switch and recently it would "ping"...blade would spin briefly then stop. I could find "the spot" when turning on the switch to get it started but it...
No, it is more likely the motor. To check it tho, bypass the switch and see if it kicks right in when direct wired. That way you kno if it is the switch or the motor. J.
Jun 28, 2010 | Skil 10" Table Saw
Table saw does not start.
if it just hummmms then check for a start capacitor on the motor body,if none,then check for a bad centrifigual motor switch on the end of the motor
May 14, 2010 | Craftsman 10" Table Saw
Craftsman 10' table saw model # 137.248830 will not start
Reset button on the motor, push till it clicks. How about the breaker? What kind of switch is it? Is it plugged in? Check this stuff out. Hope it helps.
May 09, 2010 | Craftsman Saws
Key switch on Craftsman table saw
Switch is filled with sawdust. Disassemble and clean out.
Sep 14, 2009 | Craftsman 10" Table Saw
Motor base needed for 10" table saw
My 10" Craftsman saw started life with a 1 hp motor. I'm on number 3 motor which is 1 1/2 or 2 hp. 1 hp seems to weak. The pulley diameter is about 2". The motor needs to rotate as the blade is moved from vertical. Mine is mounted to back of the blade arbor. The mounts needs to be adjustable for adjusting tension to the belt. McMaster Carr would have the start of a motor and base.
Sep 11, 2009 | Craftsman 10" Table Saw
I have a 10' Craftsman table saw model 315-218290. I ordered new belts I removed the motor how do you attach the belts, I tried to stretch it won't work
Jun 20, 2009 | Craftsman 10" Table Saw
Craftsman 10" Table Saw Logo
460 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
