Question about Mitsubishi WD-52628 52" Projection HDTV
52" DLP - TIled Picture
I bought a 52" Mitsubishi from Tweeter a few years back, and quickly noticed that the picture projected on the screen was tilted about 5 degrees to the left. Didn't think too much of it at the time, but it has started to bug me. Is this something as simple as adjusting the bulb (tile adjustments or seating), or something more complex that would require a service visit. Thanks!!
  • 3 more comments
  • rpkiefer Feb 20, 2008
    Wow! I was hoping to hear that! I just double checked and the model # is actually WD-52725. My email is rpkiefer@gmail.com. Thanks again!!
  • chriszygaj Nov 25, 2008
    mitsubishi dlp 52525 has a tilted-slanted picture
  • bowrider22t Feb 06, 2009
    I have the same problem with my Mit 52" DLP. Not sure of the exact model but it's about 3 years old,720p,1080i,with the DVI input.If you're looking at the tv,the heading at the top of the screen is apprx 1 inch lower on the left than the right.My email is bowrider22t@yahoo.com.Thanks
  • Peter Nason Jul 14, 2013
    Can so one email me the instructions on how adjust for a tilted picture on a Mitsubishi 52628? Peter_nason@yahoo.com Thanks in advance.
    Can someone please email me the instructions for adjusting a tilted picture on a Mitsubishi 52628? Thanks in advance.
    Champion:
  • 206 Answers
There is a simple tilt adjustment for this set if we could get a e-mail adress will send it to you
Posted on Feb 20, 2008
  • timtils
    timtils Nov 23, 2013
    timtils@hotmail.com
I have the 60 inch mitsubishi dlp. There was a sound just like a light bulb going out. Then there was no picture or sound. I replaced the lamp and still no picture or sound. I hear clicks when trying to...
If the status led is blinking yellow its indicating that the filter cover on the side is open. If its the lamp indicator thats blinking yellow its indicating the lamp door cover isnt attached properly.
Sep 24, 2011 | Mitsubishi WD-52825 52" Rear Projection...
Just paid to replace the lamp 2 weeks ago in our mitsubishi 73 dlp 1080p tv purchased a 5 year in home contract with Tweeter Sevice net 1/2008 lamp fixed and picture is once again great but now the 73...
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
Sep 03, 2011 | Mitsubishi WD-73833 73" HDTV
Green Lines with Picture behind
Could be serious...but first check the screen modes (for split screen, format, etc) to be sure the tv is set up properly for the picture you are trying to watch. Switch the input to a DVD or something similar. Is it the same? If not, you have a mode/resolution problem with the tuner and perhaps some other device.
Jun 28, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
No picture
The lamps life span is 1 - 3yrs, Purchase your lamp directly from JVC.com $199 they back up there products. Good luck
Jan 27, 2009 | JVC HD-52G786 52" Rear Projection HDTV
Mitsubishi 57" DLP. Replaced bulb, now picture is hazy.
Cleaning th mirror and lense will remove the haze. This oldel is much older that 2 years though.
Jan 24, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Dull almost Foggy picture.
you need to take the screws out from around the screen in the back, on edges, go to the front and take the screws out from the bottom of the screen, should be 4 or 6 in the front, pick up on the screen and lift off, only about 8 pounds, now clean the little mirror in front of the projector, and clean the dust off the projector lence, that will solve it, iv had to do this on about 50 of thease tv's
Jan 08, 2009 | Mitsubishi WD-52327 52" Rear Projection...
Tv brightness
I just bought an e 62525 on craigslist for $300 dollars. The guy had it in his garage because of a degraded picture... white out haze and virtually no black ... I surfed for similar issues most referring to the light engine. However; going back to basics. I removed the front panel assembly (approximately 16 screws including the center panel surrounding the card/rca ports in the front). The main mirror was spotless (in itself missleading) but the projection lense and the smaller mirror were frosted over with 3+ years of fine dust. I cleaned them with a simple cloth. I also noted that the foam insert surrounding the lense had gaps due to age which allowed excessive light sepage (the white out problem). I repositioned the foam as best I could. Then simply stuffed a black cloth over the foam but firmly arround the lense (keeping the foam intact as well). This blocked "all" light sepage. Bottom line is that I now have a picture quality that is flat out incredible! This is one bad mutha (shut yo mouth) tv. P.S. I'm just an average guy with an electric screw driver.
Nov 26, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Toshiba 52HMX95 DLP has weird gray think line
DLP TVs work projecting light throught a tube covered with mirrors, called the light tunnel.
The gray shadow it is something in the middle of the light tunnel, probably a mirror that has gone out of place when you moved the TV.
Sep 01, 2008 | Toshiba 52HMX94 52" Rear Projection HDTV
Mitsubishi WD-52628 52" Projection HDTV Logo
224 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
