Question about Daewoo DSP4210GM 42 in. Plasma Television
I have a 42 inch Philips Brilliance 420p monitor which ive been using for the past 2 years as a Tv. Just recently it has been slow starting up and keeps going onto standby - eventually after clicking it on/off for about an hour it comes on and works perfectly well. Any ideas?
I have just bought a 42" brilliance and was wondering if you can use it as tv.. so thanks, you answer my question, Is there anything extra I need to get?
Posted on Mar 02, 2010
MY SCREEN INSIDE THE TV APPEARS TO BE CRACKED WHEN YOU TURN THE TV ON. IS IT FEASIBLE AND COST EFFICIENT TO REPAIR
It may look like it is cracked but it isn't. A plasma panel can't function if cracked as it would evacuate the gases contained in the panel. What you are seeing is most likely delamination of the screen. This sometimes happens on its own but usually occurs when the TV is moved or stored incorrectly. The elements of the panel actually detach themselves from each other and the bonding between them is what you see. This is assuming the glass screen on the outside portion of the panel hasn't been cracked.
Joe
Nov 08, 2010 | Philips Brilliance 420P 42 in EDTVReady...
Can i use a philips 42" brilliance monitor as a tv? if so what do i need to get in order to get it going?
If you have a computer all you need to do is purchase a HDTV tuner card for it and install, This will not only let you use it as a TV but still allow you to use all your computers native features. Also most tuner cards come with remotes which make the deal even better.
Mar 02, 2010 | Daewoo DSP4210GM 42 in. Plasma Television
Philips Brilliance 200w6cs Backlight off Green LED ONN
Check to see at one of the pin on the inverter board has 12vdc feeding it. No bad capacitors? Pictures?
Nov 29, 2009 | Philips Brilliance 200WP7ES - Flat panel...
Having problems turning on 2 year old Phillips
Philips TVs tend to have issues with bad capacitors in their power supplies. Failing capacitors tend to have slightly different ESR (equivalent series resistance) values when they have been left off, versus after they are warmed up and charged up. Either a new power supply board or replacement of the faulty capacitors will fix the problem.
Oct 20, 2009 | Philips 42PF9630A 42 in. Plasma Television
Picture not as good as i expected
First, did the satellite company install an HD receiver? Second, are you using either component or HDMI cables from receiver to TV?  Still there are two factors that would produce your problem.  1. Color calibration 2. Signal strength
Proper color calibration is what makes SD actually GOOD on HDTVs. Low signal strength will create  a slow data situation. Slow data will not provide enough information per second for the TV to display a complete, error free picture so your TV has to interpolate or "guess" what colors should go in the pixels that it didn't get the data for.
Feb 16, 2009 | Philips 42PFL3603D 42 in. LCD TV
Philips crt 201b4 monitor
your tactile buttons need to be changed.
Jan 15, 2008 | Philips Brilliance 109S Monitor
Monitor hookup
http://www.eserviceinfo.com/downloadsm/4253/philips_107b.html
this is the manual please go through it
this will solve your problem
 good luck.
Oct 17, 2007 | Philips Brilliance 107B 17" CRT Monitor
Daewoo DSP4210GM 42 in. Plasma Television Logo
360 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
