Question about Canon ImageClass D880 Copier
Canon imageClass D880: paper jam warning but no paper jam
Paper jam warning but no paper jammed in machine
used to be able to clear by removing toner cartridge and re-inserting
this fix no longer working
please help.
checkitright
  • 1362 Answers
SOURCE: Canon ImageClass MP730 - Clear paper jam
Were you doing duplex? take out the duplex and look in side and UNDER it
Posted on Nov 19, 2007
SOURCE: Paper jam
unplug printer from wall and plug back in somtimes this forces trapped paper out of machine as it wrams up.
also remove paper drawer to make sure paper isnt trapped in this area
Posted on Jan 15, 2008
SOURCE: "Clear paper jam" error, but there is no jam!
Thanks, tried all the maintenance options including cleaning the rollers. What I have found worked very well was to bin the printer and purchase an HP model!
Posted on Apr 06, 2008
SOURCE: toner not set insert toner message
Yes that paper trick also worked for me. Thanks for putting it up!
Posted on Nov 09, 2008
  • 66 Answers
SOURCE: D880 Imageclass - paper jam - accordioned in
the jam is in the fuser assembly. you will have to have a technician fix this. the fuser will probably need to be replaced.
Posted on Apr 13, 2009
Can i use cardstock paper in my canon imageclass d880?
There maybe an adjustment on the rollers for different types of paper grades. If so adjust it for heavier paper weight.
Mar 02, 2012 | Canon imageCLASS D880 All-In-One Laser...
Paper jam in canon d880, Have tried every way to get paper out, but can't. Need to know what to do?
Make sure to blow off the optical device near the print head.
It may not have a paper jam at all.
Apr 07, 2010 | Canon imageCLASS D880 All-In-One Laser...
Paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Mar 30, 2009 | Canon imageCLASS D880 All-In-One Laser...
Paper will not feed without jamming.
A cust. brought this one in this morning.
The paper was jamming just before the toner cart. and the machine was damaging IU's
The back cartridge seating guide plate had snapped loose from the wall.
I popped it back into the wall, secured it and now it's working.
Mar 17, 2009 | Canon ImageClass D880 Copier
Paper jam that I cant get at
the paper must be jammed in the fixing assembly.
you are gonna have to remove some screws to remove the plastic covers. once you took them off proceed to unscrew what ever needed in order to free the fixing assembly, which is the one located in the upper back part of your copier. once you released the fixing assembly release the springs and remove the metal stoppers. now you should be able to remove the paper jam. good luck!
Jan 27, 2009 | Canon ImageClass D880 Copier
Message, paper jam
DON'T WORRY GENTLEMEN! FIRST U LOOK OUT THE PAPER IN FUSING UNIT & FEEDING UNIT ELSE CHECK FUSING- HOME POSITION SENSOR,REGISTRATION SENSOR,PICK UP SENSOR.I TELL CONFIDENTLY UR PROBLEM CLEAR..... BY......SELVA-SINGA.
Nov 25, 2008 | Canon ImageClass D880 Copier
Cannot find paper jam ...
We have a D780, which is probably very similar to your unit. Have you removed your toner cartridge and inspected to see if any paper is in the paper path? 95% of the time that is where the paper jam is.
Oct 21, 2008 | Canon ImageClass D880 Copier
Canon Imageclass D880 all-in-one
The area you are describing is the fuser exit rollers. Most likely the upper and lower rollers are worn out and the paper jammed there. You will need a technician with the background on repairing this machine to fix it. This is a major repair.
Jul 27, 2007 | Canon imageCLASS D880 All-In-One Laser...
Canon ImageClass D880 Copier Logo
131 people viewed this question
old marine
old marine
