Question about Electronics - Others
I have loaded photos from my old phone onto my scan disk. I have room for more photo's on it, so I put it in my new phone. The adapter will no longer give me the option of loading more photos. It just shows me the photos on the disk.
Figured out how to transfer more photos rom cell phone.On my new phone I had to go to MANAGE YOUR PICTURES. On the old one it was automatic.
Thanks for the follow up!
Posted on Feb 05, 2010
Lights for 480v photo cell control, the blue one, come on and stay on, any suggestions, or reasons this would happen? Is longer than 5 minutes
Unknown if this is new installation, or old installation that went bad.
Old install, then check voltage is correct for rating plate, check that line power is not under-voltage, check that photo control receives enough light by shining 120Volt light bulb onto photo eye, replace photo eye
New install, check wiring. Photo cell has 3 wires, For example Black White and Red.
Black and White connect to power source, and Red goes to load.
http://waterheatertimer.org/How-to-install-and-troubleshoot-photo-eye.html
May 01, 2012 | Hardware & Accessories
GT-S3670 trying to download photos onto my computer using san disk
Hello there,
If the scan disk already have the photo on it, then it is easy to download pictures from it to your computer, all you need to do so is a scan disk trans flash adapter also known as the memory card reader. You will insert your memory card into the scan disk if it is the small memory card. then you connect the scan disk into the computer through the SD slot on the computer and then the computer will read its drivers and then you can open file to view folders on the memory card. from there you will be able to transfer your pictures to the computer.
If your computer does not have the SD slot, then you can use the USB type of memory card reader to carry out the operation.
Thank you for using fixya.
Caseytech
Jun 27, 2011 | Samsung S3650 Corby / S3650 Genio Touch...
I love my new scanner, but everytime I scan a new photo, the ones on the disc load again into my computer. Is there any way to just load the new photos as I scan as I already have them on my hard drive.
The software that came with this scanner doesn't mark or tag any existing photos as having been read or viewed, and will upload all photos on the storage disk every time you connect it. The software's also not that easy to use when it comes to moving/deleting files. Here's what I do:
- With the scanner connected to your computer, view the device's storage disk in My Computer/Computer in Windows, or Finder in OSX
- Find the old images on the disk; look for a folder labeled DCIM and open it
- From here, you can cut and paste the images to wherever you'd like on your computer, or you can delete them permanently off your scanner
Mar 18, 2011 | VuPoint PDSST410VP
I have taken photos off the 4 gb disk and stored them on my computer. I would like to add new photos and don't seem top be able to understand how to do that. I have a folder of bird s that I would like to...
to put photos onto your disk is the reverse of taking the photos off. all you do is drag them from your computer folder into the folder on your disk. simple!
if you tried that but it didn't work then maybe your disk is full- in which case you will need to delete some of the items on there to make room.
To see if the disk is full:
1) on a pc go to the disk and right click, choose properties and it should tell you in a new window.
2) on a mac highlight the disk and then (in the top left hand bar) go to File and choose Get Info. This can also be done using the short cut 'cmd' and 'I'
hope that helps
Jan 05, 2011 | SanDisk 2GB microSD Memory Card
The computer no longer sees my 320 gb hard drive, do i need to download new drivers? if ao where do i find them. i store all my photo's and music on this hard drive
Possibilities:
1. dead USB port on your computer -- try another port
2. try a different USB cable
3. try your external drive on some other computer, to see if it works at all
4. open the casing, and separate the disk-drive from the USB-to-disk-drive adapter. Connect the disk-drive as a "slave" disk-drive, thus bypassing that adapter, to see if the adapter has failed, or if the disk-drive itself has failed
5. Google-search for a commercial "data recovery service" -- such companies can disassemble your disk-drive, and fix it, just long-enough to copy all your photos/music onto a brand-new disk-drive.
Jan 25, 2010 | SimpleTech 320GB SimpleDrive External by...
Iwant to load my photos from my phone onto my
hello, i think you don't need the disk for you to transfer photos onto your computer, just plug in the cable that comes with the phone, and up you go.
Jun 12, 2009 | Sony Ericsson K850i Mobile Phone
Fuji Finepix Z won't load photos onto my computer
check the memory disc it might be full in which case it is best to save the pics onto your computer and then wipe the disc for room to take more pics.
Jun 25, 2008 | Fuji FinePix Z10fd Digital Camera
Retrieving accidentally deleted digital photos from memory card (user error)
I would search google for "file recovery" software and run that on your microSD disk, just like you would a floppy or hard disk and see if it will find anything.
May 31, 2008 | Motorola Mobility RAZR V3
CAN'T ERASE PHOTOS
you used to much room on your cd rom nothing you can do but use a new cd.
Dec 23, 2007 | Sony Mavica MVC-CD400 Digital Camera
Electronics - Others Logo
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
