Question about Kitchen Ranges
My kenmore electric range model 790 is displaying a F10 code which i believe it means it's overheating. can you help with this problem
  • caratolley Feb 05, 2010
    the complete model # is 790.96122403. where would the EOC and RTD be located and do you have any info on obtaining these parts. thanks
  • Kitchen Ranges Master
  • 8,220 Answers
Frigidaire stove
(F10 only) Check RTD Sensor Probe & replace if necessary.
If oven is overheating, disconnect power. If oven continues to
overheat when the power is reapplied, replace EOC. Severe
overheating may require the entire oven to be replaced should
damage be extensive.
Posted on Feb 04, 2010
  • 4 more comments
  • Dan Webster
    Dan Webster Feb 04, 2010
    EOC= that there electronic oven control
  • Dan Webster
    Note: Fault codes are not a foolproof system. Never assume that a part has failed based on a displayed
    fault code. An example would be if the EOC is displaying F30 (open sensor), the failure could be caused
    by a loose connection or faulty wire harness between the EOC and sensor or the sensor could simply
    be unplugged.
  • Dan Webster
    Dan Webster Feb 05, 2010
    Manual ?
  • Dan Webster
  • Dan Webster
    The EOC is the electronic oven control
  • Dan Webster
    The RTD resistance temperature device is the sensor.
My Kenmore 790 Electric Range has the code nCAL on the display. What does this mean?
This usually indicates an electronic oven control board failure. It could also indicate a failure of the sensor probe, one of the elements, or the wiring. Try turning off the power for a while, 10 minutes or longer. If the problem persists when power is reapplied and none of the keys respond, you need to unplug the range (or shut off the power at the circuit breaker). Then usually you need to replace the oven control board and overlay. If you post the full model number of your range, I may be able to check for the appropriate replacement part.
I hope this helps. Kenmore appliances with 790 were manufactured by Whirlpool.
Oct 25, 2016 | Kenmore Kitchen Ranges
F10 error on my Kenmore range model 790 94321 302
Better off just telling us what it does or doesn't do. There is no way to know all codes on everything. You could Google it and find out
Mar 01, 2015 | Kenmore Kitchen Ranges
What is a F10 error code?
Oct 14, 2012 | Kitchen Ranges
On a sears kenmore electric range 790, my mom accidently held the time of day display off by pressing the clock button and holding for more that 15 seconds. (page 13-bottom, if you have a manual). She...
My kenmore electric range model 790 bake element don't work ,and every time I try to use it only the upper element work to preheat and it start to beeb and give me sign of( f 10) . A .A
Oct 05, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
My Kenmore oven, model 790, displays and beeps the F10 Fault
June 8, 2010
Same thing happened to mine this morning....cut the circuit breaker for a hour....open oven and let it cool....
mine stopped, finally. Dont know if its a long term fix yet.. but at least it stopped the beeping.
May 06, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Oven doesn't work. Display F30 code. Gas Range model: 790-78579405. First time usage for oven. All stove burners does work. Some blogs mentioned "reset" red buttom but couldn't find it from the back metal...
Part of the model number 790 says, that the range is made by Fridgidaire. F30 means the sensor is bad and/or main board. There is no red button. You can find you part here: www3.sears.com
Kenmore range repair in orange county, ca
Feb 11, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore oven error code f10
on that type of range F10 indicates a problem within the electronic control, but it could possible be caused by a faulty temperature sensor.
I would recommend service from a technician
May 27, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
What is error code F10 on model #790 electric range?
Tiger.......I have a Kenmore Model 790 as well, and am getting the F10 Error code. It says in the manual that it is either the RTD (Resistance Temperature Detector) or the EOC (Electronic Oven Control), but I am trying to find troubleshooting tips myself, as I do not want to pay $130 for a tech to come to my house. I know you can press the oven (off) button to stop the beeping momentarily, but the manual also says that the oven may need to be reprogrammed.....which is what I'm trying to find how to do. Sorry I couldn't give you a quick fix solution, but I'm am still searching.
Jul 07, 2008 | Kenmore Kitchen Ranges
Problem with a different range...
Tom, generally a f1 code implies a control problem. The tech sheet gives 3 possible causes. 1. A shorted keypad, solution to replace electronic control. 2. Controls internal checksum has become corrupt, solution is to unplug for 30 seconds, if the code comes back, replace the electronic control. 3. Control has sensed a overheating condition, relay on the board may have shorted out. Each one recommends replacing the control board. The part I have for this model number is 316127903. Says it's grey. Catriver..post back.
Oct 24, 2006 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Kitchen Ranges Logo
878 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
